Hi, I am using the Monoprice 10761 Amplifier, 39261 Matrix or Dayton DAX66 Amplifier binding with OH3 ( openHAB 3.4.1) setup on Docker (I have set up a separate OH3 on Openhabian on a RPi3 to see if I was just having an issue with Docker). I own the Monoprice 10761 Amp and I have purchased the Monoprice 6-Zone Home Audio RS-232 to IP Adapter. The premise of the adapter is basically it runs Ser2Net. I have also tried loading Ser2Net on a RPi3 and using my USB to RS232 cable to try and get this system to work, no luck there either. Through an android phone, I am able to control the amp through the Whole Home Audio app that basically talks to the IP Adapter, so that tells me it’s “working” or at least it’s setup somewhat accurate and I can control the Amp remotely.
My current problem is that when I type in the IP address and serial port 4999 and port 8080 and click save, the binding won’t connect. I have went to globalcache’s website and downloaded i-test and can confirm I can connect through that. Is there anything I’m missing as a dependency to get the binding to connect? Is there anyone who can share how they got their setup working? I’m more than willing to purchase different hardware to get it to work. I’m fairly new to the openHAB world and Linux world but have no issues diving into things.
2023-02-08 16:10:58.983 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'monopriceaudio:amplifier:fbce43231d' changed from OFFLINE (COMMUNICATION_ERROR): Reconnection failed to UNKNOWN
Thing setup:
UID: monopriceaudio:amplifier:fbce43231d
label: Monoprice 10761 Amplifier, 39261 Matrix or Dayton DAX66 Amplifier
thingTypeUID: monopriceaudio:amplifier
configuration:
numZones: 6
pollingInterval: 15
inputLabel6: Source 6
inputLabel4: Source 4
port: 8080
initialAllVolume: 10
inputLabel5: Source 5
inputLabel2: Source 2
inputLabel3: Source 3
host: 192.168.50.210
disableKeypadPolling: false
inputLabel1: Source 1
serialPort: “4999”
