i tried to configure my mosquitto broker with this config:
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
listener 8883
certfile /etc/mosquitto/certs/mosquitto.crt
keyfile /etc/mosquitto/certs/mosquitto.key
cafile /etc/mosquitto/ca_certificates/ca.crt
#allow_anonymous true
require_certificate true
password_file /etc/mosquitto/passwd
include_dir /etc/mosquitto/conf.d
but as result i get
Active: failed (Result: exit-code) since Sun 2022-08-07 18:12:47 CEST; 4s ago
mosquitto.service: Scheduled restart job, restart counter is at 5.
Aug 07 18:12:47 smarthome systemd[1]: Stopped Mosquitto MQTT Broker.
Aug 07 18:12:47 smarthome systemd[1]: mosquitto.service: Start request repeated too quickly.
Aug 07 18:12:47 smarthome systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Aug 07 18:12:47 smarthome systemd[1]: Failed to start Mosquitto MQTT Broker.
