I’m wondering anyone has seen this before. My mosquitto broker seems to go offline about every minute or so, for no apparent reason, it terminates and then starts again, clients are disconnected, and they reconnect. not sure what the deal is.
1586288339: New client connected from 127.0.0.1 as Hub:001 (c0, k15, u’xxxxxxxx’).
1586288339: Sending CONNACK to Hub:001 (1, 0)
1586288354: Received PINGREQ from Hub:001
1586288354: Sending PINGRESP to Hub:001
1586288369: Received PINGREQ from Hub:001
1586288369: Sending PINGRESP to Hub:001
1586288384: Received PINGREQ from Hub:001
1586288384: Sending PINGRESP to Hub:001
1586288399: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1586288399: Received PINGREQ from Hub:001
1586288399: Sending PINGRESP to Hub:001
1586288414: Received PINGREQ from Hub:001
1586288414: Sending PINGRESP to Hub:001
1586288429: mosquitto version 1.4.15 terminating
> 1586288431: mosquitto version 1.4.15 (build date 2019-01-08 23:46:33-0800) starting1586288431: Config loaded from /etc/mosquitto/mosquitto.conf.
1586288431: Opening ipv4 listen socket on port 1883.
1586288431: Opening ipv6 listen socket on port 1883.
1586288432: New connection from 127.0.0.1 on port 1883.
1586288432: Client Hub:001 disconnected.
1586288432: New client connected from 127.0.0.1 Hub:001 (c0, k15, u’xxxxxx’).
if I stop mosquitto and start with in verbose mode “mosquitto -v” this behavior seems to stop. but anytime mosquitto is starts on reboot with systemctl I get this behavior. any thoughts on this?
thanks much++
