Mosquitto errors
You can test the Mosquitto MQTT Broker with the following commands:
Open a ssh login in one window and subscribe to all topics under openhab:
mosquitto_sub -u openhab -P habopen -t openhab/#
Open another ssh login in another window and publish a message (e.g. ON) to a topic (e.g. command) under openhab:
mosquitto_pub -u openhab -P habopen -t openhab/command -m ON
On the first window with the subscription, you should see the published message (ON)
Does this simple test work? (if yes: your MQTT Broker is working fine and you need to check the openHAB2 configuration of the MQTT Binding again)
Ps: You will need to have apt-get install mosquitto-clients for these pub & sub commands to work.
