julianb
(Julian Balles)
March 1, 2016, 9:58pm
1
Hello !
im tying to make a MQTT Switch.
my MQTT.sitemap looks like this:
Code:
sitemap MQTT label="mqtt"
Frame label="MQTT" {
Switch item=mqttsw1 label="MQTT Switch 1"
the Items File:
Code:
Switch mqttsw1 {mqtt=">[mosquitto:/home:command:ON:1],>[mosquitto:/home:command:OFF:0]"}
The openhab.cfg:
Code:
mqtt:mosquitto.url=tcp://192.168.178.78:1883
with the IP adress of my pi where Mosquitto is installed
With MQTT.fx I’m tying to see my messages “0” and “1” but nothing is there.
Neither on the /home feed or “#”.
When i use mosqitto_sub / mosquitto_pup
i can see my MQTT Messages in MQTT.fx.
Got the MQTT binding in the addons folder.
Where is my mistake ?
openHAB version 1.8.1
Mosquitto v3.1
Raspberry Pi 2 Model B
THX for Help & sorry for my bad written english.
watou
(John Cocula)
March 1, 2016, 10:02pm
2
Did you install the MQTT binding JAR, not the action JAR?
julianb
(Julian Balles)
March 1, 2016, 10:07pm
3
yes got the “org.openhab.binding.mqtt-1.8.1.jar” in the addons folder.
is it enough to just have it there or do i need to do something with it ?
watou
(John Cocula)
March 1, 2016, 10:09pm
4
Is mosquitto set to listen for connections on that interface, 192.168.178.78, or is it just listening on 127.0.0.1 (or localhost)?
julianb
(Julian Balles)
March 1, 2016, 10:14pm
5
thx for your fast anwers.
mosquitto is running on my Pi. And I can communicate with mosquitto over MQTT.fx with my laptop while using 192.168.178.78:1883 in the mqtt.fx setup.
maybe i dont understand your question. where can i check to give you an answer ?
watou
(John Cocula)
March 1, 2016, 10:28pm
6
So your openHAB configuration is intending to send 1 when the switch is turned on, and 0 when it’s turned off, and no subscribers are seeing those messages when you change the switch in the UI?
If you know that a client is reaching the broker on a different system via 192.168.178.78, then there’s no need to check that. Is /etc/mosquitto/mosquitto.conf or a .conf file in /etc/mosquitto/conf.d set to listen for plain TCP connections on any other ports?
Another avenue is to enable DEBUG logging for the binding and looking in /var/log/openhab/openhab.log. Add the line:
<logger name="org.openhab.binding.mqtt" level="DEBUG" additivity="false">
to logback.xml.
julianb
(Julian Balles)
March 1, 2016, 11:09pm
7
yes im intending to make a relay module.
but from openhab there are no messages on the mosqitto server.
i edited the config file of mosqitto & added:
bind_address 192.168.178.78
Port 1883 should be used anyway.
still no connection between openhab & mosqitto
here is my logfile after i added the logger line:
openhab_log.xml (336.8 KB)
thanks again! i will answer again later today.
watou
(John Cocula)
March 2, 2016, 12:06am
8
Caused by: java.net.ConnectException: Connection refused
From your openHAB server, the IP address you specified to reach the MQTT broker
is responding that it has nothing listening on port 1883.
julianb
(Julian Balles)
March 2, 2016, 5:04am
9
well my intentions were to start step by step so i dont really have anythings listening to mosquitto other than MQTT.fx on my laptop.
i will try to connect an ESP8266 to Mosquitto later today so I have a client listening.
for fast and easy MQTT debug, use the MyMQTT app on android, I mentioned it in another thread. Its very handy to test pub and sub with ease
julianb
(Julian Balles)
March 2, 2016, 9:36am
11
Hey Stuart.
I got that App on my Android. But isnt it basically the same as MQTT.fx?
Didnt bother to monitor Mosquitto with it during my tests yesterday. but i will try today.
Used MQTT.fx to monitor the “/#” feed.
julianb
(Julian Balles)
March 2, 2016, 7:07pm
12
so i configured an esp8266 to listen to “inTopic” on 192.168.178.78:1883
Via MQTT.fx or mosquitto_pub -h 192.168.178.78 -t 'inTopic' -m 'TEST'
i can communicate with the ESP over Mosquitto.
So I changed my itemes file:
Switch mqttsw1 {mqtt=">[mosquitto:inTopic:command:ON:1],>[mosquitto:inTopic:command:OFF:0]"}
BUT Still no messages on Mosquitto via openHAB.
I tought sending binary values with mqtt via openhab should be pretty easy… well well how wrong
watou
(John Cocula)
March 2, 2016, 7:41pm
13
Did you get another
in the log?
julianb
(Julian Balles)
March 2, 2016, 7:52pm
14
somehow the logfile stops at 2016-03-01.
whats the reason for this ? how can i fix this ?
btw my bindings are all 1.8.1 but in the log it say openHAB runtime v1.8.0 has started. could there be an issue ?
i used this tutorial to install openhab: https://klenzel.de/3094
so the “wget” method not apt-get install.
java was already installed. i use the latest rasbian jessie.
julianb
(Julian Balles)
March 2, 2016, 8:05pm
15
i have a 2016_03_02.request.log file.
2016_03_02.xml (34.0 KB)
Julian, were you able to fix the issue? I’m running to the same issue using Openhab 1.8.3.I have a few mosquitto clients sub/pub with no issue.
sihui
(SiHui)
June 10, 2016, 6:17pm
17
His problem was solved with a setup from scratch, take a look here:
sihui:
This discussion was continued over private message, for future reference: the system (Raspbian Jessie) was set up from scratch using the following tutorial and now works fine with mosquitto and mqtt: Login via ssh pi@raspberrypi:~ $ sudo apt-get update pi@raspberrypi:~ $ sudo apt-get upgrade install mosquitto: pi@raspberrypi:~ $ wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key pi@raspberrypi:~ $ sudo apt-key add mosquitto-repo.gpg.key pi@raspberrypi:~ $ cd /etc/apt/sources.lis…
julianb
(Julian Balles)
June 11, 2016, 5:21pm
18
can confirm that a resetup with the official tutorials worked
