Can anyone recommend a Z-wave motion/PIR and/or glass break sensor that can take wired power? I don’t want to have to chase down batteries all over my house every year or two (or worse, have a dead battery render my security system useless at the worst possible time…).
Hi George,
you can check it,
Model number:
US: ZWA012-A / ZWA042-A
AU: ZWA012-B / ZWA042-B
EU: ZWA012-C / ZWA042-C
Support External Power: Yes
VCC current: Max 500mA.
VCC: Max 3.6V.
However, the usability depends on your use case. The vibration sensor is quite sensitive. If the ZW100 is attached to the glass of your window/door, it might be triggered by normal (infra) sounds (not tested). It will definitely be triggered when the glass breaks. Tilting the window might trigger it.
Thanks, I’ll check those out!
