Hi everyone,
I am using openhabian in latest stable version and have an annoying problem with long delays in rules, even in very simple rules. So I thought of trying to install on windows and see if the delays are caused by my pi hardware.
My question is now, if I can restore my backup from openhabian in the windows version as well?
Hope someone can help me.
is openhab the only “service” that is running on the pi hardware ?
As far as I understand openhabian is designed for Linux ( especially for Debian/Ubuntu ) systems.
Thus I think you will not be able to run openhabian to restore the backup.
Once paths are stored in the backup files they will not work on the windows system as the directory delimiter is different on windows and on linux.
You can use openhab cli to copy (backup and restore) your openhabian config from rpi to windows. However, it will only “backup” you config, as well as files inside the /etc/openhab2/.
If you have other files you need, then you need to copy those manually.
Yes, I think the restore is smart enough to see that it’s dealing with a manually installed openHAB as opposed to an apt or yum installed openHAB and therefore it restores the files to the right locations.
