i try to move my openhab docker to a new machine. I moved the docker volumes and it starts up without errors - but the web-service doesn’t serve anything - while the ports show to be assigned: The logs doesn’t show any trace of an error.
that’s my docker-compose.yml file
services:
openhab:
image: "openhab/openhab:3.4.4"
# user: root
restart: always
network_mode: host
# ports:
# - "8080:8080/tcp"
# - "8443:8443/tcp"
dns:
- 192.168.176.1
- 8.8.4.4
# dns_search: lan
volumes:
- "/etc/localtime:/etc/localtime:ro"
# - "/etc/timezone:/etc/timezone:ro"
- "openhab_addons:/openhab/addons"
- "openhab_conf:/openhab/conf"
- "openhab_userdata:/openhab/userdata"
- "openhab_java:/openhab/.java"
# devices:
# - /dev/ttyACM0:/dev/myzwavestick
environment:
# USER_ID: 112
# GROUP_ID: 119
CRYPTO_POLICY: unlimited
OPENHAB_HTTP_PORT: "8080"
OPENHAB_HTTPS_PORT: "8443"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin -Dlog4j2.formatMsgNoLookups=true"
volumes:
openhab_addons:
external: true
openhab_conf:
external: true
openhab_userdata:
external: true
openhab_java:
external: true
2023-06-19 08:36:59.220 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2023-06-19 08:36:59.233 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '50.32755706599748,8.539357423651381'.
2023-06-19 08:36:59.234 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2023-06-19 08:37:01.355 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '00_groups.items'
2023-06-19 08:37:01.485 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '13_network.items'
2023-06-19 08:37:01.493 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model '20_node_red.items'
2023-06-19 08:37:01.584 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2023-06-19 08:37:01.605 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2023-06-19 08:37:01.738 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'gosund.things'
2023-06-19 08:37:01.779 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'network.things'
2023-06-19 08:37:01.785 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'knx.things'
2023-06-19 08:37:04.793 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2023-06-19 08:37:07.253 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 169.254.18.175/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.254 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 169.254.242.124/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.254 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 169.254.219.1/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.255 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 169.254.107.143/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.255 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 169.254.160.173/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.256 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.26.0.1/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.256 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.24.0.1/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.256 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.23.0.1/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.257 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.21.0.1/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.257 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 169.254.64.252/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.257 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.20.0.1/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.258 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 169.254.173.167/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.258 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.18.0.1/16, truncating to /24, some addresses might be lost
2023-06-19 08:37:07.310 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-06-19 08:37:07.468 [INFO ] [rnal.service.RemoteControllerService] - Using SecureWebSocket interface
2023-06-19 08:37:07.567 [INFO ] [atmo.internal.servlet.WebhookServlet] - Registered Netatmo servlet at '/netatmo/webhook/5eefc5e53f61762e7c615a14'
2023-06-19 08:37:07.568 [INFO ] [atmo.internal.servlet.WebhookServlet] - Setting up WebHook at Netatmo to https://openhab.jru.me/netatmo/webhook/5eefc5e53f61762e7c615a14
2023-06-19 08:37:07.585 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.176.6' with clientid ad857f44-26ae-47c3-8c49-7117fe3a1c58
2023-06-19 08:37:07.788 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = e3...53, base URL = http://localhost:8080)
2023-06-19 08:37:08.316 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
A simple-fresh openhab-instance -works out like a charm - just the migrated volumes lead to no web-answers. I cleared the cache and tmp directorys - but no effect.
I switched openhab ports - no effect either.
i set debug in logs - but nothing to be seen.
I’m a bit out of my Ideas. Suggestions? Ideas?
Johannes
