Moved to oh-3.1.0, everything is ok except coordinator (xbee) goes offline after oh reloading.
This doesn’t happen in previous release (2.5.12)
Any idea?
Thank you
log file:
07:20:26.253 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B001CD5FCD9: Command for channel zigbee:device:ea63531109:00124b001cd5fcd9:00124B001CD5FCD9_1_switch → OFF [OnOffType]
07:20:26.264 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B001CD5FCD9: Coordinator handler not found. Cannot handle command without coordinator.
07:20:26.269 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:device:ea63531109:00124b001cd5fcd9’ changed from UNKNOWN to OFFLINE
07:20:59.004 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:20:00.001116+0300 to 2021-07-22T07:20:59.001561+0300
07:21:00.006 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:20:59.001561+0300 to 2021-07-22T07:21:00.002203+0300
07:21:40.779 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
07:21:40.781 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_port as no change
07:21:40.783 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_baud as no change
07:21:40.784 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_flowcontrol as no change
07:21:40.785 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Processing zigbee_initialise → true
07:21:40.786 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Processing zigbee_channel → 0.0
07:21:40.788 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_panid as no change
07:21:40.789 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_linkkey as no change
07:21:40.790 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_extendedpanid as no change
07:21:40.791 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networkkey as no change
07:21:40.793 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_meshupdateperiod as no change
07:21:40.803 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
07:21:40.819 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B00232071D6: ZigBee saving network state complete.
07:21:40.835 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 0013A20041483251: ZigBee saving network state complete.
07:21:40.858 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EBF5BD: ZigBee saving network state complete.
07:21:40.888 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EA198E: ZigBee saving network state complete.
07:21:40.912 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EC05FC: ZigBee saving network state complete.
07:21:40.922 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B001CD5FCD9: ZigBee saving network state complete.
07:21:40.938 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00158D0002FCF34C: ZigBee saving network state complete.
07:21:40.955 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EB35E1: ZigBee saving network state complete.
07:21:42.128 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Serial port ‘/dev/ttyUSB0’ closed.
07:21:42.134 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_xbee:ea63531109] closed.
07:21:42.137 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_xbee:ea63531109].
07:21:42.138 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Channel 0.0
07:21:42.140 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - PANID 92
07:21:42.141 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - EPANID 0000000000002018
07:21:42.142 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Network Key 6D7CA5648C890440AD5EBC354005974E
07:21:42.145 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
07:21:42.146 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=true
07:21:42.148 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Network Key String 6D7CA5648C890440AD5EBC354005974E
07:21:42.149 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Network key final array 6D7CA5648C890440AD5EBC354005974E
07:21:42.151 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
07:21:42.152 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initialising network
07:21:42.154 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Channel set to 11.
07:21:42.181 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
07:21:42.182 [DEBUG] [nding.zigbee.xbee.handler.XBeeHandler] - Initializing ZigBee XBee serial bridge handler.
07:21:42.184 [DEBUG] [nding.zigbee.xbee.handler.XBeeHandler] - ZigBee XBee Coordinator opening Port:’/dev/ttyUSB0’ PAN:5c, EPAN:0000000000002018, Channel:11
07:21:42.192 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
07:21:43.196 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
07:21:43.198 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
07:21:43.202 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
07:21:43.241 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B00232071D6: ZigBee reading network state complete.
07:21:43.261 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 0013A20041483251: ZigBee reading network state complete.
07:21:43.295 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EBF5BD: ZigBee reading network state complete.
07:21:43.323 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EA198E: ZigBee reading network state complete.
07:21:43.348 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EC05FC: ZigBee reading network state complete.
07:21:43.365 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B001CD5FCD9: ZigBee reading network state complete.
07:21:43.395 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00158D0002FCF34C: ZigBee reading network state complete.
07:21:43.418 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EB35E1: ZigBee reading network state complete.
07:21:43.421 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 115200 baud, flow control FLOWCONTROL_OUT_NONE.
07:21:43.488 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Serial port [/dev/ttyUSB0] is initialized.
07:21:44.024 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
07:21:44.044 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_15, PanID=92, EPanId=0000000000002018
07:21:44.046 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Link key initialise 5A6967426565416C6C69616E63653039
07:21:44.047 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Network key initialise 6D7CA5648C890440AD5EBC354005974E
07:21:44.065 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B00232071D6: ZigBee removing network state complete
07:21:44.067 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 0013A20041483251: ZigBee removing network state complete
07:21:44.069 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EBF5BD: ZigBee removing network state complete
07:21:44.070 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EA198E: ZigBee removing network state complete
07:21:44.071 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EC05FC: ZigBee removing network state complete
07:21:44.073 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B001CD5FCD9: ZigBee removing network state complete
07:21:44.075 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00158D0002FCF34C: ZigBee removing network state complete
07:21:44.076 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EB35E1: ZigBee removing network state complete
07:21:44.092 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee initialise done. channel=CHANNEL_00, PanId=92 EPanId=0000000000002018
07:21:44.093 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=ONLINE
07:21:44.156 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:coordinator_xbee:ea63531109’ changed from UNKNOWN to ONLINE
07:21:44.162 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00158D0002FCF34C: Coordinator status changed to ONLINE.
07:21:44.163 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00158D0002FCF34C: Coordinator is ONLINE. Starting device initialisation.
07:21:44.168 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EA198E: Coordinator status changed to ONLINE.
07:21:44.169 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EA198E: Coordinator is ONLINE. Starting device initialisation.
07:21:44.171 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EBF5BD: Coordinator status changed to ONLINE.
07:21:44.173 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EB35E1: Coordinator status changed to ONLINE.
07:21:44.174 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EBF5BD: Coordinator is ONLINE. Starting device initialisation.
07:21:44.181 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B001CD5FCD9: Coordinator status changed to ONLINE.
07:21:44.183 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B001CD5FCD9: Coordinator is ONLINE. Starting device initialisation.
07:21:44.179 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EC05FC: Coordinator status changed to ONLINE.
07:21:44.175 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EB35E1: Coordinator is ONLINE. Starting device initialisation.
07:21:44.185 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EC05FC: Coordinator is ONLINE. Starting device initialisation.
07:21:44.175 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00232071D6: Coordinator status changed to ONLINE.
07:21:44.186 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00232071D6: Coordinator is ONLINE. Starting device initialisation.
07:21:44.189 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00158D0002FCF34C: Node not found - deferring handler initialisation
07:21:44.195 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EBF5BD: Node not found - deferring handler initialisation
07:21:44.196 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B001CD5FCD9: Node not found - deferring handler initialisation
07:21:44.199 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00232071D6: Node not found - deferring handler initialisation
07:21:44.203 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EB35E1: Node not found - deferring handler initialisation
07:21:44.197 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:xiaomi_lumisensor-motion:ea63531109:00158d0002fcf34c’ changed from UNKNOWN to OFFLINE (GONE): Node is not found on network
07:21:44.205 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:device:ea63531109:00124b0022ebf5bd’ changed from UNKNOWN to OFFLINE (GONE): Node is not found on network
07:21:44.196 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EC05FC: Node not found - deferring handler initialisation
07:21:44.206 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:device:ea63531109:00124b001cd5fcd9’ changed from OFFLINE to OFFLINE (GONE): Node is not found on network
07:21:44.212 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:device:ea63531109:00124b00232071d6’ changed from UNKNOWN to OFFLINE (GONE): Node is not found on network
07:21:44.215 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:device:ea63531109:00124b0022ec05fc’ changed from UNKNOWN to OFFLINE (GONE): Node is not found on network
07:21:44.219 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EA198E: Node not found - deferring handler initialisation
07:21:44.222 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:device:ea63531109:00124b0022eb35e1’ changed from UNKNOWN to OFFLINE (GONE): Node is not found on network
07:21:44.226 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘zigbee:device:ea63531109:00124b0022ea198e’ changed from UNKNOWN to OFFLINE (GONE): Node is not found on network
07:21:44.359 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 0013A20041483251: ZigBee saving network state complete.
07:21:59.006 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:21:00.002203+0300 to 2021-07-22T07:21:59.001406+0300
07:22:00.004 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:21:59.001406+0300 to 2021-07-22T07:22:00.001619+0300
07:22:01.338 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 0013A20041483251: ZigBee saving network state complete.
07:22:06.675 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EBF5BD: Node updated - ZigBeeNode [state=ONLINE, IEEE=00124B0022EBF5BD, NWK=EEEC, endpoints=[]]
07:22:06.677 [WARN ] [.zsmartsystems.zigbee.ZigBeeExecutors] - Uncaught exception in thread NotificationService-thread-6
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.nodeUpdated(ZigBeeThingHandler.java:862) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.nodeAdded(ZigBeeThingHandler.java:805) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager$12.run(ZigBeeNetworkManager.java:1734) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
07:22:06.686 [INFO ] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EBF5BD: Starting ZigBee device discovery
07:22:06.687 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EBF5BD: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_xbee:ea63531109
07:22:06.689 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EBF5BD: Node discovery not complete
07:22:06.931 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EBF5BD: ZigBee saving network state complete.
07:22:08.591 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B00232071D6: Node updated - ZigBeeNode [state=ONLINE, IEEE=00124B00232071D6, NWK=8A97, endpoints=[]]
07:22:08.593 [WARN ] [.zsmartsystems.zigbee.ZigBeeExecutors] - Uncaught exception in thread NotificationService-thread-9
07:22:08.601 [INFO ] [gbee.discovery.ZigBeeDiscoveryService] - 00124B00232071D6: Starting ZigBee device discovery
07:22:08.602 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B00232071D6: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_xbee:ea63531109
07:22:08.604 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B00232071D6: Node discovery not complete
07:22:08.846 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B00232071D6: ZigBee saving network state complete.
07:22:20.082 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EB35E1: Node updated - ZigBeeNode [state=ONLINE, IEEE=00124B0022EB35E1, NWK=5AF7, endpoints=[]]
07:22:20.084 [WARN ] [.zsmartsystems.zigbee.ZigBeeExecutors] - Uncaught exception in thread NotificationService-thread-1
07:22:20.092 [INFO ] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EB35E1: Starting ZigBee device discovery
07:22:20.093 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EB35E1: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_xbee:ea63531109
07:22:20.095 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EB35E1: Node discovery not complete
07:22:20.340 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EB35E1: ZigBee saving network state complete.
07:22:59.003 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:22:00.001619+0300 to 2021-07-22T07:22:59.001099+0300
07:23:00.005 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:22:59.001099+0300 to 2021-07-22T07:23:00.001742+0300
07:23:23.920 [DEBUG] [ing.zigbee.handler.ZigBeeThingHandler] - 00124B0022EC05FC: Node updated - ZigBeeNode [state=ONLINE, IEEE=00124B0022EC05FC, NWK=C5BD, endpoints=[]]
07:23:23.922 [WARN ] [.zsmartsystems.zigbee.ZigBeeExecutors] - Uncaught exception in thread NotificationService-thread-2
07:23:23.937 [INFO ] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EC05FC: Starting ZigBee device discovery
07:23:23.938 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EC05FC: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_xbee:ea63531109
07:23:23.940 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - 00124B0022EC05FC: Node discovery not complete
07:23:24.176 [DEBUG] [nding.zigbee.internal.ZigBeeDataStore] - 00124B0022EC05FC: ZigBee saving network state complete.
07:23:59.003 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:23:00.001742+0300 to 2021-07-22T07:23:59.000945+0300
07:24:00.003 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Date_Time’ changed from 2021-07-22T07:23:59.000945+0300 to 2021-07-22T07:24:00.001258+0300
