Long story short, I started playing with OH and home automation in general, so I set it up on my project Rpi, and now I’m looking to getting another Rpi and setting it up with the OH distro, as it’s here to stay.
How would I go about moving the OH installation between the 2 Rpis, with the minimal amount work regarding configuration?
Currently I make use of OH, Mosquitto, InfluxDB & Grafana, everthing is setup using PaperUI so I don’t have any sitemaps or .loose files.
Even though you found your solution this might not work all the time. e.g. you need specific drivers to get a device up and running.
My OH installation is now about 5 yo and I am still hesitating to start over with a fresh installation
I usually clone my sd card (moved to usb revently) and restore it to a new card/stick. So I can easily have a full backup and don’t need to bother which part failed.
I found the combination of raspibackup link and Pishrink link to be just the thing I need.
