MQTT 2.4 update, using outgoing value format
I have an old mqtt binding switch.items as
{mqtt=“>[broker:/ESP_Easy/gpio/12:command:ON:1],>[broker:/ESP_Easy/gpio/12:command:OFF:0]”}
I set up a new MQTT Item with a new channel. The Channel MQTT Command Topic should start off with
 /ESP_Easy/gpio/
What should the transform be? I have to transform the OFF to 0
thanks
Given that the 2.4 binding is now well over a year old now I’m not sure. With the 2.5 version of the binding there is a “Custom ON/OPEN” and “Custom OFF/CLOSED” field you can put the 1 and 0 into and it will transform as you require. Other alternatives include using the MAP transform to transform the ON/OFF to 1/0.
