MQTT 2.x Binding, Reading JSON data via MQTT Data from Tibber - MiniHowto using Paper-UI
I had initially some issues with the MQTT 2.x Binding and Tibber. Actually I have spent quite alot of time reading howtos, trying, failing etc. Hopefully this little guide will be useful for you, if you:
  1. want to read Tibber Energy Price into openhab2
  2. you want to learn a generic approach to import JSON into MQTT into OpenHab2
My goal was to get electric energy price in OpenHab2 using MQTT and trend them using Grafana. I archieved this goal :slight_smile:
A little background about the stuff involved:
What is Tibber: (norwegian) Power Company that provides electric energy price for the next hour via API (..). Smart(…)
What is MQTT: Message broker that allows communication via “publish” and “subscribe” methods.
Prequisites:
  1. Have a Tibber Account
  2. Installed and working MQTT openhab2 Binding (2.x) - if not: should be able to follow my steps here: Trouble with MQTT Bindings 2.x - eventsTriggered - Item stale - #8 by sirius324
Lets go:
  1. Activate Tibber API. You need the authorization token
    Google it or start here : Tibber Developer
  2. Create a script that communicates to API
Script that fetches energy price for the next hour and sends it to MQTT with subject “/TibberData”
#!/bin/bash
#Communication with Tibber
data=$(curl \-H "Authorization: Bearer OpenHabCommunityPostSendAllTheMoneyToChristianHehe" \-H "Content-Type: application/json" \-X POST \-d  '{ "query": "{viewer {homes {currentSubscription {priceInfo {current {total energy tax startsAt }}}}}}" }' https://api.tibber.com/v1-beta/gql)
tibberCurlErr=$?
if [ $tibberCurlErr -gt 0 ]; then
    echo "CURL failed to Tibber error code $tibberCurlErr" | logger
    exit 53
fi
echo "$data"
# Getting data to MQTT broker
mosquitto_pub -t /TibberData -m "$data"
Validation / Output example:
user@openhab:/usr/local/bin/openhab# ./tibber_hourly_price.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   271  100   167  100   104    480    299 --:--:-- --:--:-- --:--:--   479
{"data":{"viewer":{"homes":[{"currentSubscription":{"priceInfo":{"current":{"total":0.6031,"energy":0.4825,"tax":0.1206,"startsAt":"2018-12-08T10:00:00+01:00"}}}}]}}}
  1. Add a new Thing for this channel.
Configuration > Things > (+) > MQTTBinding > manually add > Generic MQTT Thing
Details see screenshot, basically give it a name and select your broker.
Note: If there is no broker - go back to PREREQUISITES(2) and fix it :slight_smile:
  1. Configure Channels for your input data. Examples below
    As you can see I have created two channels - one for the “price” (TibberDataNumber) and the StartDate (usually the next hour).
The json transformation that I used is
JSONPATH:$.data.viewer.homes[0].currentSubscription.priceInfo.current.total
Here is the second channel for the start time of the Energy Price:
The json transformation that I used is:
JSONPATH:$.data.viewer.homes[0].currentSubscription.priceInfo.current.startsAt
I wasn’t so used to writing JSON path transformations, but I had great help by using jqplay. A website that lets you test the transformations. Link: jq playground - note that there is a slight syntax difference in the start. :wink: (You don’t have to use this website - just as an example if you want to derive work off my little howto…)
Almost done - linking the MQTTBinding Channels to Items:
Example Item config:
If everything worked, you should be able to see something like this in Paper-UI Control:
Yay! You are done!!!
I use the data above to be trended in Grafana:
Sample Query config:
“If you found this post useful, please click the subscribe button…” :crazy_face:
Troubleshoot only: If you have something like “NAN” on your Items - then try this:
0) Example of my /var/log/openhab2/events.log
2018-12-08 06:00:18.207 [vent.ItemStateChangedEvent] - TibberHourlyEnergyPrice_TibberDataNumber changed from 0.5539 to 0.5666
  1. rerun your script that fetches data from Tibber (you see the JSON there- right?)
  2. Subscribe to MQTT yourself to validate that you see the data
mosquitto_sub -v -t '/TibberData' -d
Should show something like this:
Client mosqsub/13665-openhab received PUBLISH (d0, q0, r0, m0, '/TibberData', ... (166 bytes))
/TibberData {"data":{"viewer":{"homes":[{"currentSubscription":{"priceInfo":{"current":{"total":0.6031,"energy":0.4825,"tax":0.1206,"startsAt":"2018-12-08T10:00:00+01:00"}}}}]}}}
I normally use jsonpath.com
No syntax difference
Do you mean the like :heart: button?
Hehe… just tried to be funny :). But yes- the like button works for me ! :slight_smile:
Sorry, no www
