I have a Raspberry Pi with openhab 2.5.1 at my Caravan. It is connected to my System at home by LTE and openvpn. After I losed my Internet connection an openvpn is reconnect later again, mqtt is not able to reconnect to the broker at my home.
If I restart openhab at my Caravan, all works fine.
The same problem if I restart my Raspberry and VPN needs some time to connect to the System at my home.
What can I do?
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_152]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
Caused by: com.hivemq.client.mqtt.exceptions.MqttSessionExpiredException: Session expired as connection was closed.
Caused by: com.hivemq.client.mqtt.exceptions.ConnectionClosedException: Server closed connection without DISCONNECT.
2020-02-20 09:09:29.066 [WARN ] [.transport.mqtt.MqttBrokerConnection] - Failed subscribing to topic stat/wohnwagen/gin_bar_rein
java.util.concurrent.CompletionException: com.hivemq.client.mqtt.exceptions.MqttSessionExpiredException: Session expired as connection was closed.
