Why my MQTT server was set up to fail from the start (mosquitto) after the reverse-proxy is configured in apache ? in addition, to re-activate it again, I have been obliged to put the mosquitto -v command in each process failure,.
Openhab with reverse proxy perfectly works, but mosquitto crashes sometimes. here is below the log from openhab-cli console
[ERROR] [openhab.io.transport.mqtt.MqttService] - Error starting broker connection
org.eclipse.paho.client.mqttv3.MqttException: Unable to connect to server
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:79) [221:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650) [221:org.openhab.io.transport.mqtt:1.11.0]
at java.lang.Thread.run(Thread.java:745) [?:?]
Caused by: java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:589) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:70) ~[?:?]
… 2 more
I’m not sure but it’s appeared to me that the problem is caused by the APIPA Address, because the RPI was randomly changing his address. So to fix it I reserved a static ip then mosquitto no longer stopped.
