Mqtt - autodiscover stability / dead switches
Hi, not sure what went wrong but i Was on a 4.2.2 and sudennly all things from mqtt binding are somehow dead.
  1. Very high cpu usage by java during startup, log full of
2024-11-09 15:44:23.476 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.502 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.528 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.548 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.582 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.595 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.623 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.641 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.653 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.681 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.698 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.719 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.745 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.777 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.805 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.828 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:23.857 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:44:26.714 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887': {thing/channel=Type description mqtt:ha-trigger for mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887:0x6c5cb1fffefc7887_5Faction_5Fbrightness_5Fmove_5Fto_5Flevel_5Fdevice_5Fautomation#action not found, although we checked the presence before.}
2024-11-09 15:44:26.731 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887': {thing/channel=Type description mqtt:ha-trigger for mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887:0x6c5cb1fffefc7887_5Faction_5Fbrightness_5Fmove_5Fto_5Flevel_5Fdevice_5Fautomation#action not found, although we checked the presence before.}
2024-11-09 15:47:03.793 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13895180725c9:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13895180725c9': {thing/channel=Type description mqtt:0xa4c13895180725c9_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13895180725c9:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13895180725c9:0xa4c13895180725c9_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:47:03.802 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'localhost' with clientid 08508b81-98fb-4b8a-a122-38da2a75cf8b
2024-11-09 15:47:04.243 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:04.676 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:0xa4c138e145340ee0_5Fcountdown_5Fl2_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fcountdown_5Fl2_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:04.915 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0x003c84fffed749a9:c1d3dc6fc0:zigbee2mqtt_5F0x003c84fffed749a9': {thing/channel=Type description mqtt:0x003c84fffed749a9_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0x003c84fffed749a9:c1d3dc6fc0:zigbee2mqtt_5F0x003c84fffed749a9:0x003c84fffed749a9_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:05.389 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138bed9123aa9:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138bed9123aa9': {thing/channel=Type description mqtt:0xa4c138bed9123aa9_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138bed9123aa9:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138bed9123aa9:0xa4c138bed9123aa9_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:07.128 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138aac3ca6836:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138aac3ca6836': {thing/channel=Type description mqtt:0xa4c138aac3ca6836_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138aac3ca6836:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138aac3ca6836:0xa4c138aac3ca6836_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:07.263 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138623bbb3f56:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138623bbb3f56': {thing/channel=Type description mqtt:0xa4c138623bbb3f56_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138623bbb3f56:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138623bbb3f56:0xa4c138623bbb3f56_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:07.281 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d0f3847c7d:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d0f3847c7d': {thing/channel=Type description mqtt:0xa4c138d0f3847c7d_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d0f3847c7d:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d0f3847c7d:0xa4c138d0f3847c7d_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:07.295 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381ab36275ff:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381ab36275ff': {thing/channel=Type description mqtt:0xa4c1381ab36275ff_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381ab36275ff:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381ab36275ff:0xa4c1381ab36275ff_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:47:07.547 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f6d11c9fda:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f6d11c9fda': {thing/channel=Type description mqtt:0xa4c138f6d11c9fda_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f6d11c9fda:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f6d11c9fda:0xa4c138f6d11c9fda_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.128 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.139 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:47:09.163 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.166 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:47:09.184 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.199 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:47:09.204 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.220 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:47:09.232 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.241 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fcountdown_5Fl1_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:47:09.272 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.281 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:0xa4c13855d98c2358_5Findicator_5Fmode_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Findicator_5Fmode_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.297 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e145340ee0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e145340ee0:0xa4c138e145340ee0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.339 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13855d98c2358:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13855d98c2358:0xa4c13855d98c2358_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.372 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386da4fca951:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386da4fca951': {thing/channel=Type description mqtt:0xa4c1386da4fca951_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386da4fca951:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386da4fca951:0xa4c1386da4fca951_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.380 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13844ac9f9b04:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13844ac9f9b04': {thing/channel=Type description mqtt:0xa4c13844ac9f9b04_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13844ac9f9b04:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13844ac9f9b04:0xa4c13844ac9f9b04_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.383 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383326dc5b3f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383326dc5b3f': {thing/channel=Type description mqtt:0xa4c1383326dc5b3f_5Faction_5F1_5Fdouble_5Fdevice_5Fautomation_action for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383326dc5b3f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383326dc5b3f:0xa4c1383326dc5b3f_5Faction_5F1_5Fdouble_5Fdevice_5Fautomation#action not found, although we checked the presence before.}
2024-11-09 15:47:09.520 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384130e55127:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384130e55127': {thing/channel=Type description mqtt:0xa4c1384130e55127_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384130e55127:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384130e55127:0xa4c1384130e55127_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:09.690 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e2f05ad5e4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e2f05ad5e4': {thing/channel=Type description mqtt:0xa4c138e2f05ad5e4_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e2f05ad5e4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e2f05ad5e4:0xa4c138e2f05ad5e4_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:11.545 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381ab36275ff:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381ab36275ff': {thing/channel=Type description mqtt:0xa4c1381ab36275ff_5Fcountdown_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381ab36275ff:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381ab36275ff:0xa4c1381ab36275ff_5Fcountdown_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:47:11.552 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:0xa4c1383d6d1f8663_5Fcountdown_5Fl1_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fcountdown_5Fl1_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:47:11.626 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4': {thing/channel=Type description mqtt:0xa4c1385dcca2ccd4_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4:0xa4c1385dcca2ccd4_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:47:11.680 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386d4ee45954:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386d4ee45954': {thing/channel=Type description mqtt:0xa4c1386d4ee45954_5Faction_5F1_5Fdouble_5Fdevice_5Fautomation_action for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386d4ee45954:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386d4ee45954:0xa4c1386d4ee45954_5Faction_5F1_5Fdouble_5Fdevice_5Fautomation#action not found, although we checked the presence before.}
2024-11-09 15:47:11.700 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173': {thing/channel=Type description mqtt:0xa4c1386470391173_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173:0xa4c1386470391173_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:47:11.808 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138279e10a535:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138279e10a535': {thing/channel=Type description mqtt:0xa4c138279e10a535_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138279e10a535:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138279e10a535:0xa4c138279e10a535_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:13.792 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138635f74d06f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138635f74d06f': {thing/channel=Type description mqtt:0xa4c138635f74d06f_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138635f74d06f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138635f74d06f:0xa4c138635f74d06f_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:14.141 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6': {thing/channel=Type description mqtt:0xa4c1384c527363d6_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6:0xa4c1384c527363d6_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:47:14.257 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0x00124b0024c8eb54:c1d3dc6fc0:zigbee2mqtt_5F0x00124b0024c8eb54': {thing/channel=Type description mqtt:0x00124b0024c8eb54_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0x00124b0024c8eb54:c1d3dc6fc0:zigbee2mqtt_5F0x00124b0024c8eb54:0x00124b0024c8eb54_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:14.363 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1382675725b6e:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1382675725b6e': {thing/channel=Type description mqtt:0xa4c1382675725b6e_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1382675725b6e:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1382675725b6e:0xa4c1382675725b6e_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:14.433 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13899d16c63cc:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13899d16c63cc': {thing/channel=Type description mqtt:0xa4c13899d16c63cc_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13899d16c63cc:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13899d16c63cc:0xa4c13899d16c63cc_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.805 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.829 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.851 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13826532c9403:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13826532c9403': {thing/channel=Type description mqtt:0xa4c13826532c9403_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13826532c9403:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13826532c9403:0xa4c13826532c9403_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.860 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.887 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.916 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.943 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.968 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:15.991 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383d6d1f8663:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383d6d1f8663:0xa4c1383d6d1f8663_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.130 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4': {thing/channel=Type description mqtt:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.157 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4': {thing/channel=Type description mqtt:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.165 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173': {thing/channel=Type description mqtt:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.181 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4': {thing/channel=Type description mqtt:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.225 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4': {thing/channel=Type description mqtt:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1385dcca2ccd4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1385dcca2ccd4:0xa4c1385dcca2ccd4_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.234 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173': {thing/channel=Type description mqtt:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.266 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173': {thing/channel=Type description mqtt:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.309 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173': {thing/channel=Type description mqtt:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.357 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173': {thing/channel=Type description mqtt:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386470391173:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386470391173:0xa4c1386470391173_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:47:16.364 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c': {thing/channel=Type description mqtt:0xa4c138f606b3852c_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c:0xa4c138f606b3852c_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:48:14.865 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:0xa4c138f145094db8_5Fcountdown_5Fl2_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fcountdown_5Fl2_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:48:15.264 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1389cb3cf460f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1389cb3cf460f': {thing/channel=Type description mqtt:0xa4c1389cb3cf460f_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1389cb3cf460f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1389cb3cf460f:0xa4c1389cb3cf460f_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:15.530 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2024-11-09 15:48:19.047 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6': {thing/channel=Type description mqtt:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:20.217 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.io.monitor.internal.EventLogger@59608628' takes more than 5000ms.
2024-11-09 15:48:22.083 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2024-11-09 15:48:25.909 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388ee161a6c2:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388ee161a6c2': {thing/channel=Type description mqtt:0xa4c1388ee161a6c2_5Fbacklight_5Fmode_5Fzigbee2mqtt_select for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388ee161a6c2:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388ee161a6c2:0xa4c1388ee161a6c2_5Fbacklight_5Fmode_5Fzigbee2mqtt#select not found, although we checked the presence before.}
2024-11-09 15:48:26.232 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13826532c9403:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13826532c9403' takes more than 5000ms.
2024-11-09 15:48:26.233 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13899d16c63cc:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13899d16c63cc' takes more than 5000ms.
2024-11-09 15:48:26.260 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512': {thing/channel=Type description mqtt:0xa4c1381c8efa8512_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512:0xa4c1381c8efa8512_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:48:26.303 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c': {thing/channel=Type description mqtt:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.312 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c': {thing/channel=Type description mqtt:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.317 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6': {thing/channel=Type description mqtt:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.369 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6': {thing/channel=Type description mqtt:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.374 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13846fbd6cefd:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13846fbd6cefd': {thing/channel=Type description mqtt:0xa4c13846fbd6cefd_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13846fbd6cefd:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13846fbd6cefd:0xa4c13846fbd6cefd_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.385 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c': {thing/channel=Type description mqtt:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.422 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6': {thing/channel=Type description mqtt:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.441 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c': {thing/channel=Type description mqtt:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.463 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6': {thing/channel=Type description mqtt:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.475 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c': {thing/channel=Type description mqtt:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f606b3852c:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f606b3852c:0xa4c138f606b3852c_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:26.512 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6': {thing/channel=Type description mqtt:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384c527363d6:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384c527363d6:0xa4c1384c527363d6_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:28.754 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:0xa4c1388e97d9c808_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:29.868 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138ce6547984f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138ce6547984f': {thing/channel=Type description mqtt:0xa4c138ce6547984f_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138ce6547984f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138ce6547984f:0xa4c138ce6547984f_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:48:31.840 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512' takes more than 5000ms.
2024-11-09 15:48:31.868 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:31.869 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388ee161a6c2:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388ee161a6c2': {thing/channel=Type description mqtt:0xa4c1388ee161a6c2_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388ee161a6c2:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388ee161a6c2:0xa4c1388ee161a6c2_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:32.855 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:0xa4c138f145094db8_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:32.902 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8': {thing/channel=Type description mqtt:0xa4c138110584ecb8_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8:0xa4c138110584ecb8_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:48:32.904 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e9e32158fa:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e9e32158fa': {thing/channel=Type description mqtt:0xa4c138e9e32158fa_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e9e32158fa:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e9e32158fa:0xa4c138e9e32158fa_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:32.924 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:0xa4c138f145094db8_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:32.961 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:0xa4c138f145094db8_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:32.992 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.046 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.069 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.091 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.119 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.140 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.160 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.180 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138f145094db8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138f145094db8:0xa4c138f145094db8_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.698 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512': {thing/channel=Type description mqtt:0xa4c1381c8efa8512_5Fcountdown_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512:0xa4c1381c8efa8512_5Fcountdown_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:48:33.703 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13827aac43723:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13827aac43723': {thing/channel=Type description mqtt:0xa4c13827aac43723_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c13827aac43723:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13827aac43723:0xa4c13827aac43723_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:33.732 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512': {thing/channel=Type description mqtt:0xa4c1381c8efa8512_5Findicator_5Fmode_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512:0xa4c1381c8efa8512_5Findicator_5Fmode_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:35.051 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019': {thing/channel=Type description mqtt:0xa4c1383913a50019_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019:0xa4c1383913a50019_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:48:35.192 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1380166606c03:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1380166606c03': {thing/channel=Type description mqtt:0xa4c1380166606c03_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1380166606c03:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1380166606c03:0xa4c1380166606c03_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:35.281 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512': {thing/channel=Type description mqtt:0xa4c1381c8efa8512_5Findicator_5Fmode_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1381c8efa8512:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1381c8efa8512:0xa4c1381c8efa8512_5Findicator_5Fmode_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:35.282 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138ce6547984f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138ce6547984f': {thing/channel=Type description mqtt:0xa4c138ce6547984f_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138ce6547984f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138ce6547984f:0xa4c138ce6547984f_5Fpower_5Foutage_5Fmemory_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:36.152 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1382cdc641282:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1382cdc641282': {thing/channel=Type description mqtt:0xa4c1382cdc641282_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1382cdc641282:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1382cdc641282:0xa4c1382cdc641282_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:36.225 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0': {thing/channel=Type description mqtt:0xa4c138d2d94622c0_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0:0xa4c138d2d94622c0_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:48:37.679 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:0xa4c1388e97d9c808_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:37.726 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:37.747 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:37.770 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:37.777 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887': {thing/channel=Type description mqtt:ha-trigger for mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887:0x6c5cb1fffefc7887_5Faction_5Fbrightness_5Fmove_5Fto_5Flevel_5Fdevice_5Fautomation#action not found, although we checked the presence before.}
2024-11-09 15:48:37.796 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fcountdown_5Fl2_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:37.820 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:37.842 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.221 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.247 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.250 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8': {thing/channel=Type description mqtt:0xa4c138110584ecb8_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8:0xa4c138110584ecb8_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.267 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.285 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.343 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.364 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.364 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8': {thing/channel=Type description mqtt:0xa4c138110584ecb8_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8:0xa4c138110584ecb8_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.392 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fcountdown_5Fl1_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.395 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8': {thing/channel=Type description mqtt:0xa4c138110584ecb8_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138110584ecb8:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138110584ecb8:0xa4c138110584ecb8_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.406 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.433 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.469 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.509 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388e97d9c808:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388e97d9c808:0xa4c1388e97d9c808_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.533 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0': {thing/channel=Type description mqtt:ha-string-advanced for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386a3a7438a0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386a3a7438a0:0xa4c1386a3a7438a0_5Fpower_5Fon_5Fbehavior_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.613 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138ff90bd4080:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138ff90bd4080': {thing/channel=Type description mqtt:0xa4c138ff90bd4080_5Flast_5Fseen_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138ff90bd4080:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138ff90bd4080:0xa4c138ff90bd4080_5Flast_5Fseen_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:38.861 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46': {thing/channel=Type description mqtt:0xa4c1388efe100b46_5Fchild_5Flock_5Fzigbee2mqtt_lock for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46:0xa4c1388efe100b46_5Fchild_5Flock_5Fzigbee2mqtt#lock not found, although we checked the presence before.}
2024-11-09 15:48:40.799 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019': {thing/channel=Type description mqtt:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:48:40.886 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019': {thing/channel=Type description mqtt:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:48:40.913 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019': {thing/channel=Type description mqtt:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:48:40.929 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019': {thing/channel=Type description mqtt:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt_number for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383913a50019:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383913a50019:0xa4c1383913a50019_5Fcountdown_5Fzigbee2mqtt#number not found, although we checked the presence before.}
2024-11-09 15:48:44.645 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887': {thing/channel=Type description mqtt:ha-trigger for mqtt:homeassistant_zigbee2mqtt_5F0x6c5cb1fffefc7887:c1d3dc6fc0:zigbee2mqtt_5F0x6c5cb1fffefc7887:0x6c5cb1fffefc7887_5Faction_5Fbrightness_5Fmove_5Fto_5Flevel_5Fdevice_5Fautomation#action not found, although we checked the presence before.}
2024-11-09 15:48:44.655 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0': {thing/channel=Type description mqtt:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:44.673 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46': {thing/channel=Type description mqtt:0xa4c1388efe100b46_5Findicator_5Fmode_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46:0xa4c1388efe100b46_5Findicator_5Fmode_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:44.678 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0': {thing/channel=Type description mqtt:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:44.706 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0': {thing/channel=Type description mqtt:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:44.709 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46': {thing/channel=Type description mqtt:0xa4c1388efe100b46_5Findicator_5Fmode_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46:0xa4c1388efe100b46_5Findicator_5Fmode_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:44.725 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0': {thing/channel=Type description mqtt:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c138d2d94622c0:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138d2d94622c0:0xa4c138d2d94622c0_5Fcountdown_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:44.726 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for new thing during update 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46': {thing/channel=Type description mqtt:0xa4c1388efe100b46_5Findicator_5Fmode_5Fzigbee2mqtt_sensor for mqtt:homeassistant_zigbee2mqtt_5F0xa4c1388efe100b46:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1388efe100b46:0xa4c1388efe100b46_5Findicator_5Fmode_5Fzigbee2mqtt#sensor not found, although we checked the presence before.}
2024-11-09 15:48:46.241 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
I manage somehow to stabilize it but all of my things lost connections to items (mqtt thinkg - channel- item).
All of my over 60 things are now not linked to items at all. Not sure what to do now and if there is a way to solve it without doing it again manually.
My steps just befor the crush:
1/ 4.2.2 with one localhost mqtt broker running mosquitto all of my mqtt thing vere using only this broker
2/ I added a second localhost mqtt broker with different UID ( to put the story short → i have some addition rules with fixed uid for broker, and didnt want to change whole my rules) co i doubled the broker configuration.
3/ The stability / high cpu usage and errors from the mqtt binding started.
4/ I removed the newly added broker, rebooted, cleared openhab cache and somehow it is ok
5/ All of my things lost their connections to items (both things and items are there, and those things were and still are connected with the first (and still existing) broker.
any ideas how to solve it?
i have a backup file: org.openhab.core.thing.link.ItemChannelLink.json containing the proper links, maybe i can use it ?
Take a look at the Things. Are the still connected to the correct Bridge?
i can’t solve this issue - every update (now to 5.0) i am getting the same trobles. What i did wrong i think
1/ one mqtt broker added from a file
2/ second mqtt broker added from web GUI
both pointing to the same mqtt server broker everythink crashed, i realized it and change the uid
now i am uploading a thing. file with:
cat /etc/openhab/things/axprothings.disabled
Bridge mqtt:broker:c1d3dc6fc0 [host="localhost", secure=false]
    Thing topic Zigbee2mqtt  "zigbee bridge" {
        Channels:
        Type switch : state "State" [
            stateTopic = "zigbee2mqtt/bridge/state",
            off="offline",
            on="online"
        Type switch : permitJoin "Permit join" [
            stateTopic = "zigbee2mqtt/bridge/config",
            transformationPattern="JSONPATH:$.permit_join",
            commandTopic="zigbee2mqtt/bridge/config/permit_join",
            off="false",
            on="true"
        Type number : logLevel "Log level" [
            transformationPattern="JSONPATH:$.log_level∩MAP:num2loglevel.map",
            commandTopic="zigbee2mqtt/bridge/config/log_level",
            transformationPatternOut="MAP:num2loglevel.map"
and get errors that the broker uid already exist, what i check - it’s really there even if i remove these thing file.
after removing it my thinkgs (zigbee2mqtt things) are going crazy:
2025-07-30 14:34:25.792 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138aac3ca6836' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-30 14:34:25.806 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1386da4fca951:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1386da4fca951' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-30 14:34:25.825 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c13844ac9f9b04:c1d3dc6fc0:zigbee2mqtt_5F0xa4c13844ac9f9b04' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-30 14:34:25.840 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1383326dc5b3f:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1383326dc5b3f' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-30 14:34:25.862 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c1384130e55127:c1d3dc6fc0:zigbee2mqtt_5F0xa4c1384130e55127' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-30 14:34:25.884 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant_zigbee2mqtt_5F0xa4c138e2f05ad5e4:c1d3dc6fc0:zigbee2mqtt_5F0xa4c138e2f05ad5e4' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
My idea is to remove the things and re-create them using new 5.0 openhab logic, but the webgui is still freezing.
i cant even disable this things (these was my idea to get rid of the lags and delays. I did it from a jssc script and disabled most of these faulty things, but still after a while the GUI is somehow freezing.
Not sure what is wrong bad i thing the root problem is that i added duplicated mqtt brokers one from a file and one from GUI and rename the broker from a file to the same uid.
Keeping the webgui broker bridge (which uid is configure in things i get handler missing, but the mqtt addon and broker which matich id is there.
I am trying to disable manually alle things and then i will try to enable them one after another with no lags… i hope.
not sure if my information is helpful for you but i need some help to make it stable
Ok i disabled 99% of things. My host is fine, running smothly without delays. Whole openhab instance is veryyyy slow:
WebGui very slow
openhab-cli console - very slow
logs showing a lot of timeouts i will try to disable other addons, uninstall them and check. So not sure if this is a issue with things/mqtt or some kind of general issue with performance.
2025-07-30 15:19:50.881 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellyplus1-d0ef76d8e9a8: INFO: New firmware available: current version: 1.3.3-, new version: 1.6.2
2025-07-30 15:21:26.005 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@712876a1' takes more than 5000ms.
2025-07-30 15:21:31.947 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 15:21:33.774 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:21:36.120 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'localhost'. Next attempt in 60000ms
2025-07-30 15:21:36.844 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'localhost' with clientid bd86f5f8-35c4-4bfd-908e-c656d1535317
2025-07-30 15:21:41.295 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '{"state":"online"}' from channel 'mqtt:topic:c1d3dc6fc0:14700ff164:availability#zigbee2mqtt_2FWall_5FPlug_5F1_2Favailability' not supported by type 'OnOffValue': No enum constant org.openhab.core.library.types.OnOffType.{"state":"online"}
2025-07-30 15:21:41.603 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '{"state":"online"}' from channel 'mqtt:topic:c1d3dc6fc0:3e45e6b489:availability#zigbee2mqtt_2FWall_5FPlug_5F2_2Favailability' not supported by type 'OnOffValue': No enum constant org.openhab.core.library.types.OnOffType.{"state":"online"}
2025-07-30 15:21:42.630 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:22:30.759 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 15:22:33.042 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:22:36.634 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:24:00.462 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 15:24:02.714 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:24:06.874 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellyplus1-d0ef76d8e9a8: INFO: New firmware available: current version: 1.3.3-, new version: 1.6.2
2025-07-30 15:24:19.831 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:24:22.240 [WARN ] [qtt.generic.AbstractMQTTThingHandler] - unsubscription on disposal failed for mqtt:topic:c1d3dc6fc0:e875d20e12:
java.util.concurrent.TimeoutException: null
        at java.util.concurrent.CompletableFuture.timedGet(CompletableFuture.java:1960) ~[?:?]
        at java.util.concurrent.CompletableFuture.get(CompletableFuture.java:2095) ~[?:?]
        at org.openhab.binding.mqtt.generic.AbstractMQTTThingHandler.dispose(AbstractMQTTThingHandler.java:248) ~[?:?]
        at org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler.dispose(GenericMQTTThingHandler.java:106) ~[?:?]
        at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?]
        at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?]
        at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:149) ~[?:?]
        at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) ~[?:?]
        at java.util.concurrent.FutureTask.run(FutureTask.java:317) ~[?:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) ~[?:?]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) ~[?:?]
        at java.lang.Thread.run(Thread.java:1583) [?:?]
2025-07-30 15:24:27.599 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing 'mqtt:topic:c1d3dc6fc0:e875d20e12' takes more than 5000ms.
2025-07-30 15:25:46.778 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.io.monitor.internal.EventLogger@334b8da6' takes more than 5000ms.
2025-07-30 15:25:46.998 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 15:25:47.666 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:25:57.046 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:26:45.912 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Stopped without executing or closing null
2025-07-30 15:29:04.509 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 15:29:06.190 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:29:07.114 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.io.monitor.internal.EventLogger@334b8da6' takes more than 5000ms.
2025-07-30 15:29:31.176 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:29:59.411 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellyplus1-d0ef76d8e9a8: INFO: New firmware available: current version: 1.3.3-, new version: 1.6.2
2025-07-30 15:33:08.929 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 15:33:11.484 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 15:33:11.646 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.io.monitor.internal.EventLogger@334b8da6' takes more than 5000ms.
2025-07-30 15:33:18.807 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
For the first time which over 15 different openha instances i don’t know what to do to fix the issue i managed to delete all the things, clear all log warnings but there is still sth which is causing the openhab to be non responsive. Even the karaf console is so slow i cant do nothing there. All rules, timers, things are disabled and the problem still exist. Host computer is fine, memory cpu is less thatn 10% other apps on the host are working OK.
It’s a bit in cycle - not responsice for 3-4 minutes, then i can do a little by web and again not responsive at all.
Log are pretty clear all the time
2025-07-30 19:37:37.302 [INFO ] [org.openhab.core.Activator          ] - Starting openHAB 5.0.0 (Release Build)
2025-07-30 19:37:40.657 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Warsaw'.
2025-07-30 19:37:40.698 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '54.27047935533515,18.562098741531376'.
2025-07-30 19:37:40.708 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'pl_PL'.
2025-07-30 19:37:58.276 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://10.8.0.15:8080/'s Observer
2025-07-30 19:38:01.107 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://10.8.0.15:8080/'s Observer
2025-07-30 19:38:16.614 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'teede.items'
2025-07-30 19:38:18.485 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'axpro.items'
2025-07-30 19:38:20.753 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'gate.items'
2025-07-30 19:38:24.485 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dom.sitemap'
2025-07-30 19:38:51.427 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2025-07-30 19:39:20.903 [WARN ] [ty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@3c62e938[provider=null,keyStore=null,trustStore=null]
2025-07-30 19:39:20.909 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@3c62e938[provider=null,keyStore=null,trustStore=null]
2025-07-30 19:39:21.443 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 192.168.5.137/22, truncating to /24, some addresses might be lost
2025-07-30 19:39:23.659 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager started at http(s)://192.168.5.137:8080/shelly/manager
2025-07-30 19:39:33.418 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 19:40:02.992 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing 'http:url:145d362559'.
2025-07-30 19:40:03.199 [INFO ] [nding.http.internal.HttpThingHandler] - Using the secure client for thing 'http:url:4fc2a4e08f'.
2025-07-30 19:40:08.811 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellyplus1-d0ef76d8e9a8: INFO: New firmware available: current version: 1.3.3-, new version: 1.6.2
2025-07-30 19:40:09.591 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'mqtt:broker:986f8a6a42' takes more than 5000ms.
2025-07-30 19:40:14.130 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid 902de356-43db-4552-a6f8-00f04ac1cbd9
2025-07-30 19:41:09.760 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2025-07-30 19:41:12.524 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/gate_3b.js'
2025-07-30 19:41:43.837 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Gate_3button
2025-07-30 19:41:44.523 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/gate_4b.js'
2025-07-30 19:41:48.741 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Gate_4button
2025-07-30 19:41:48.771 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/gate_button.js'
2025-07-30 19:41:53.040 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Gate_button
2025-07-30 19:41:53.075 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/tedee.js'
2025-07-30 19:42:06.017 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Tede
2025-07-30 19:42:06.087 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Tede_map
2025-07-30 19:42:06.129 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/teede_rejes.js'
2025-07-30 19:42:17.567 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Tede pokaz callbacki
2025-07-30 19:42:17.594 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/things.offline.js'
2025-07-30 19:42:21.146 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Things offline
2025-07-30 19:43:25.239 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 19:43:26.987 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 19:43:39.144 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 19:44:45.966 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-07-30 19:44:48.592 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
2025-07-30 19:44:51.952 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 41...d0, base URL = http://localhost:8080)
the slowdown are inline with the cloud connector going offline and back online. The localhost connection to mqtt is also slow
i deleted all autodisvoered mqtt things and created them again. It took 3 hours to finde and add them from inbox to things. They are there but still not working
normal genereic mqtt is working OK, but these homeassistant autodiscovery not. Similar issue
2025-07-31 00:24:09.170 [DEBUG] [ric.internal.MqttThingHandlerFactory] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.generic.internal.MqttThingHandlerFactory(435)] : For dependency $004, optional: false; to bind: [[RefPair: ref: [{org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge}={service.id=620, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge, component.id=436}] service: [null]]]
2025-07-31 00:24:09.174 [DEBUG] [ric.internal.MqttThingHandlerFactory] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.generic.internal.MqttThingHandlerFactory(435)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2025-07-31 00:24:09.207 [DEBUG] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(436)] : Checking constructor public org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge()
2025-07-31 00:24:09.212 [DEBUG] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(436)] : Found constructor with 0 arguments : public org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge()
2025-07-31 00:24:09.225 [DEBUG] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(436)] : This thread collected dependencies
2025-07-31 00:24:09.228 [DEBUG] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(436)] : getService (single component manager) dependencies collected.
2025-07-31 00:24:09.232 [DEBUG] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(436)] : Querying state satisfied
2025-07-31 00:24:09.245 [DEBUG] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(436)] : Querying state satisfied
2025-07-31 00:24:09.249 [DEBUG] [t.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.mqtt.homeassistant:5.0.0 (314)[org.openhab.binding.mqtt.homeassistant.internal.HomeAssistantPythonBridge(436)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2025-07-31 00:24:45.384 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Gate_3button
2025-07-31 00:24:46.008 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/gate_4b.js'
2025-07-31 00:24:47.756 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bf76f9a159b6e4ecddjuaw' to inbox.
2025-07-31 00:24:48.013 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bff8864a3a5c63dcednlg0' to inbox.
2025-07-31 00:24:48.138 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bfb80f70b6e3a8a205e0ru' to inbox.
2025-07-31 00:24:48.266 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bf7dabfdc9928ce2a2ukhc' to inbox.
2025-07-31 00:24:48.456 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:10358584e8db848f4fa1' to inbox.
2025-07-31 00:24:48.627 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bfedb01611f8728ccdae7l' to inbox.
2025-07-31 00:24:48.869 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bf23ee7a583ed28ff8ru6v' to inbox.
2025-07-31 00:24:49.017 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bf127415b851c1203fxgw0' to inbox.
2025-07-31 00:24:49.199 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tuya:tuyaDevice:bfee59edd5849ac1090hbd' to inbox.
2025-07-31 00:25:01.041 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-switch
2025-07-31 00:25:01.061 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string-advanced
2025-07-31 00:25:01.070 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string
2025-07-31 00:25:01.080 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-switch
2025-07-31 00:25:01.087 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string
2025-07-31 00:25:01.093 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-switch-advanced
2025-07-31 00:25:01.101 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string
2025-07-31 00:25:07.315 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Gate_4button
2025-07-31 00:25:07.347 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/gate_button.js'
2025-07-31 00:25:22.082 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Gate_button
2025-07-31 00:25:22.133 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/tedee.js'
2025-07-31 00:25:24.884 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-switch
2025-07-31 00:25:24.891 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-number
2025-07-31 00:25:24.908 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string
2025-07-31 00:25:24.925 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string-advanced
2025-07-31 00:25:24.931 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-number-advanced
2025-07-31 00:25:24.941 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-number
2025-07-31 00:25:24.946 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-number
2025-07-31 00:25:24.960 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-number
2025-07-31 00:25:24.965 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-number
2025-07-31 00:25:24.975 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-switch
2025-07-31 00:25:24.980 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string
2025-07-31 00:25:40.494 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Tede
2025-07-31 00:25:40.543 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Tede_map
2025-07-31 00:25:40.566 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/teede_rejes.js'
2025-07-31 00:25:48.869 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Tede pokaz callbacki
2025-07-31 00:25:48.895 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/things.offline.js'
2025-07-31 00:25:57.969 [INFO ] [.openhab.automation.openhab-js.rules] - Adding rule: Things offline
2025-07-31 00:26:27.540 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-string-advanced
2025-07-31 00:26:28.426 [WARN ] [ore.internal.thing.ThingTypeResource] - Cannot find channel type: mqtt:ha-number-advanced
2025-07-31 00:26:56.539 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.561 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.570 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.580 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.592 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.623 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.642 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.656 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.666 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.681 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.694 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.709 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.719 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.735 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.748 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.765 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:56.784 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.793 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.812 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.834 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.917 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.933 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382cdc641282' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.952 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.963 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386d4ee45954' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.975 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13844ac9f9b04' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:58.989 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138635f74d06f' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:59.004 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:59.019 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13826532c9403' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:59.034 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384130e55127' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:59.046 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d0f3847c7d' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:26:59.059 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e9e32158fa' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.811 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.827 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138bed9123aa9' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.848 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388ee161a6c2' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.868 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.885 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13827aac43723' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.910 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1389cb3cf460f' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.927 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.952 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.973 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:03.992 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:04.019 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:04.026 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13899d16c63cc' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:04.032 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:04.049 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x00124b0024c8eb54' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:04.057 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-07-31 00:27:04.070 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
maybe this?
MQTT Binding (Home Assistant)
  • Thing types and channel IDs for things created prior to 4.3.0 have been significantly restructured and simplified. Items will need to be re-linked. Delete and re-create your Things to also have a simplified Thing Type ID in your Thing IDs.
  • All scene components on a device are now exposed as a single String channel, with the scene name or object ID as its value. Existing Items and rules will need to be re-worked.
  • Devices that use custom payloads or states now have that abstracted, so users should only use the default payloads. Rules and UIs may need to be updated for some devices.
i saw that, but i re-created the things from scratch on 5.0.0 using autodiscovery.
During the night it seems that the first error is gone (handler_missing) a
2025-07-31 00:46:21.470 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.494 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.512 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.529 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.553 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.572 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.595 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.612 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.628 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.644 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.679 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:46:21.701 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from UNINITIALIZED (HANDLER_MISSING_ERROR): Handler factory not found to UNINITIALIZED (NOT_YET_READY)
2025-07-31 00:47:04.718 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:47:29.732 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:47:46.892 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:47:55.735 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:48:03.373 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:48:12.962 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:48:21.649 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:48:28.894 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:48:35.938 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:48:44.061 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:48:50.882 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:49:05.252 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:49:12.390 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:49:20.391 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:49:26.659 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:49:32.549 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing
2025-07-31 00:52:40.541 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:52:46.835 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:52:58.181 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to OFFLINE
2025-07-31 00:53:05.111 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:53:11.988 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:53:18.562 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:53:25.376 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13899d16c63cc' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:53:32.546 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:53:38.758 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x00124b0024c8eb54' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:53:44.879 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:53:56.581 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:54:08.924 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:54:14.527 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:54:20.546 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:54:50.762 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:55:21.811 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:55:28.268 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 00:55:56.819 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNINITIALIZED (NOT_YET_READY) to INITIALIZING
2025-07-31 00:56:36.526 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 00:56:42.508 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Java heap space
2025-07-31 01:01:26.096 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 01:03:04.566 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 01:06:33.803 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 01:08:38.043 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 01:22:00.167 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bf1400cac8076044e9aqay' changed from ONLINE to OFFLINE
2025-07-31 01:23:47.618 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bfefac79694c77ecf24xbz' changed from ONLINE to OFFLINE
2025-07-31 01:25:02.554 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bf1400cac8076044e9aqay' changed from OFFLINE to ONLINE
2025-07-31 01:33:02.667 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bf1400cac8076044e9aqay' changed from ONLINE to OFFLINE
2025-07-31 01:45:15.506 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bfefac79694c77ecf24xbz' changed from OFFLINE to ONLINE
2025-07-31 01:51:41.645 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bfefac79694c77ecf24xbz' changed from ONLINE to OFFLINE
2025-07-31 02:13:51.086 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bfefac79694c77ecf24xbz' changed from OFFLINE to ONLINE
2025-07-31 02:13:51.703 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bfefac79694c77ecf24xbz' changed from ONLINE to OFFLINE
2025-07-31 02:14:02.741 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bfefac79694c77ecf24xbz' changed from OFFLINE to ONLINE
2025-07-31 02:14:03.356 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:tuyaDevice:bf1400cac8076044e9aqay' changed from OFFLINE to ONLINE
2025-07-31 02:14:03.471 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplus1:d0ef76d8e9a8' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Unexpected error: WebSocket connection closed abnormally
2025-07-31 02:14:03.619 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 02:14:15.308 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from INITIALIZING to UNKNOWN
2025-07-31 02:14:15.581 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from INITIALIZING to UNKNOWN
2025-07-31 02:14:27.705 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:14:27.914 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:14:28.067 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from INITIALIZING to UNKNOWN
2025-07-31 02:14:38.683 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from INITIALIZING to UNKNOWN
2025-07-31 02:14:38.927 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from INITIALIZING to UNKNOWN
2025-07-31 02:14:44.861 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:14:51.193 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:14:51.464 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:15:06.242 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 02:15:38.223 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' changed from INITIALIZING to UNKNOWN
2025-07-31 02:15:50.864 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:16:35.151 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388ee161a6c2' changed from INITIALIZING to UNKNOWN
2025-07-31 02:16:46.731 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388ee161a6c2' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:17:07.248 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from INITIALIZING to UNKNOWN
2025-07-31 02:17:19.882 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:17:25.553 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' changed from INITIALIZING to UNKNOWN
2025-07-31 02:17:25.606 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from INITIALIZING to UNKNOWN
2025-07-31 02:17:39.066 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:17:39.087 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:17:39.637 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from INITIALIZING to UNKNOWN
2025-07-31 02:17:50.741 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:17:58.329 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from INITIALIZING to UNKNOWN
2025-07-31 02:17:58.534 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from INITIALIZING to UNKNOWN
2025-07-31 02:18:10.523 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:18:10.579 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:18:11.775 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from INITIALIZING to UNKNOWN
2025-07-31 02:18:23.619 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:18:24.154 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from INITIALIZING to UNKNOWN
2025-07-31 02:18:24.178 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from INITIALIZING to UNKNOWN
2025-07-31 02:18:35.659 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:18:35.673 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:18:43.806 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' changed from INITIALIZING to UNKNOWN
2025-07-31 02:18:55.592 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:19:00.947 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from INITIALIZING to UNKNOWN
2025-07-31 02:19:01.158 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 02:19:07.403 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13899d16c63cc' changed from INITIALIZING to UNKNOWN
2025-07-31 02:19:12.775 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' changed from INITIALIZING to UNKNOWN
2025-07-31 02:19:12.790 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:19:18.680 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13899d16c63cc' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:19:24.957 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:19:30.775 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' changed from INITIALIZING to UNKNOWN
2025-07-31 02:19:42.390 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:19:49.335 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d0f3847c7d' changed from INITIALIZING to UNKNOWN
2025-07-31 02:20:00.871 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d0f3847c7d' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:20:01.007 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:20:01.115 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:20:01.286 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 02:20:12.807 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:20:12.858 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:20:16.942 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384130e55127' changed from INITIALIZING to UNKNOWN
2025-07-31 02:20:28.074 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384130e55127' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:20:28.475 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from INITIALIZING to UNKNOWN
2025-07-31 02:20:40.605 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:20:41.078 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:20:53.096 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:21:12.302 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382cdc641282' changed from INITIALIZING to UNKNOWN
2025-07-31 02:21:25.106 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382cdc641282' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:21:43.389 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e9e32158fa' changed from INITIALIZING to UNKNOWN
2025-07-31 02:21:53.516 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e9e32158fa' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:21:58.263 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from INITIALIZING to UNKNOWN
2025-07-31 02:22:10.381 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:22:34.829 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x00124b0024c8eb54' changed from INITIALIZING to UNKNOWN
2025-07-31 02:22:44.864 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x00124b0024c8eb54' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:22:58.193 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13827aac43723' changed from INITIALIZING to UNKNOWN
2025-07-31 02:23:08.660 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13827aac43723' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:23:26.857 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from INITIALIZING to UNKNOWN
2025-07-31 02:23:32.458 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:23:32.521 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from INITIALIZING to UNKNOWN
2025-07-31 02:23:37.104 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from INITIALIZING to UNKNOWN
2025-07-31 02:23:37.114 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:23:42.940 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:23:42.980 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:23:48.959 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:23:54.190 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from INITIALIZING to UNKNOWN
2025-07-31 02:24:05.636 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:06.240 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 02:24:11.957 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from INITIALIZING to UNKNOWN
2025-07-31 02:24:12.179 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:24:23.602 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:23.618 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:29.316 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e9e32158fa' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:24:34.964 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:24:35.099 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from INITIALIZING to UNKNOWN
2025-07-31 02:24:40.131 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e9e32158fa' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:46.471 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:46.493 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:46.576 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:24:46.604 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1389cb3cf460f' changed from INITIALIZING to UNKNOWN
2025-07-31 02:24:46.636 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:24:46.730 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:24:59.075 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:59.109 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:59.115 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1389cb3cf460f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:24:59.119 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:25:05.058 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1389cb3cf460f' changed from INITIALIZING to UNKNOWN
2025-07-31 02:25:11.841 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 02:25:16.651 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1389cb3cf460f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:25:16.950 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' changed from INITIALIZING to UNKNOWN
2025-07-31 02:25:17.004 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138bed9123aa9' changed from INITIALIZING to UNKNOWN
2025-07-31 02:25:28.213 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138bed9123aa9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:25:28.238 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:25:34.244 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' changed from INITIALIZING to UNKNOWN
2025-07-31 02:25:34.298 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:25:34.365 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from INITIALIZING to UNKNOWN
2025-07-31 02:25:45.179 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:25:45.211 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:25:45.220 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:25:46.125 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386d4ee45954' changed from INITIALIZING to UNKNOWN
2025-07-31 02:25:58.105 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386d4ee45954' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:26:10.198 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13844ac9f9b04' changed from INITIALIZING to UNKNOWN
2025-07-31 02:26:22.757 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13844ac9f9b04' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:26:23.851 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from INITIALIZING to UNKNOWN
2025-07-31 02:26:24.106 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:26:24.162 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:26:24.204 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:26:24.231 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:26:35.966 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:26:35.987 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:26:35.996 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:26:36.022 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:26:36.039 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:26:49.272 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:26:49.626 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138635f74d06f' changed from INITIALIZING to UNKNOWN
2025-07-31 02:26:49.696 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13826532c9403' changed from INITIALIZING to UNKNOWN
2025-07-31 02:26:49.763 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:26:49.891 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138bed9123aa9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:26:49.895 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d0f3847c7d' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:27:00.910 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:00.955 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138635f74d06f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:00.959 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d0f3847c7d' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:00.965 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:00.969 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138bed9123aa9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:00.974 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13826532c9403' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:01.388 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:27:01.409 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:27:01.437 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:27:13.284 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:13.303 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:13.349 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:13.496 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from INITIALIZING to UNKNOWN
2025-07-31 02:27:22.899 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:27:28.942 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:29.139 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:27:35.213 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:52.049 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:27:58.264 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:27:58.289 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:03.573 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:03.585 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:09.410 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:15.798 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:21.828 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:32.924 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:33.268 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138635f74d06f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:38.591 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:38.783 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:38.796 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:38.950 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382cdc641282' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:44.595 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138635f74d06f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:50.753 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:50.778 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382cdc641282' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:28:51.067 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:51.423 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:28:57.372 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:29:03.185 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:29:03.570 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:29:03.600 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:29:10.332 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 02:29:16.835 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:29:23.324 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:29:29.375 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:29:29.672 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388ee161a6c2' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:29:30.065 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:29:36.589 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:29:42.262 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:29:42.286 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388ee161a6c2' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:29:48.226 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:29:54.101 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:00.596 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:00.772 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from OFFLINE to UNKNOWN
2025-07-31 02:30:06.605 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:12.631 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:12.821 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 02:30:12.860 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13844ac9f9b04' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:18.911 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:25.293 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13844ac9f9b04' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:25.316 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:25.479 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384130e55127' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:30.507 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:30.615 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:36.703 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384130e55127' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:36.765 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:36.911 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:42.523 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:42.778 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13826532c9403' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:43.197 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:30:49.772 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:56.037 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:56.050 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13826532c9403' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:30:56.198 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13827aac43723' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:31:08.834 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13827aac43723' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:31:17.003 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:31:17.035 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:31:17.148 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:31:17.159 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:31:42.269 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:31:48.888 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:31:55.712 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:31:55.749 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:09.076 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:09.193 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:09.304 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:09.452 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:09.472 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:14.597 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:14.732 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:20.597 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:26.659 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:26.946 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:32.035 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1389cb3cf460f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:32.325 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:38.332 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:44.164 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1389cb3cf460f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:44.174 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:44.368 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:50.453 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138bed9123aa9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:32:56.251 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13846fbd6cefd' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:32:56.802 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:33:02.705 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138bed9123aa9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:33:08.542 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:33:14.749 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:33:21.531 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:33:26.829 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:33:32.866 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:33:39.073 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d0f3847c7d' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:33:39.219 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:33:39.577 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e9e32158fa' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:33:51.186 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e9e32158fa' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:33:51.228 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d0f3847c7d' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:33:51.247 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:33:57.785 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x00124b0024c8eb54' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:33:58.150 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:34:03.487 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:34:03.753 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 02:34:09.203 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386470391173' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:34:09.228 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x00124b0024c8eb54' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:34:15.356 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:34:16.171 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:34:28.508 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383913a50019' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:34:28.729 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:34:28.742 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:34:41.326 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:34:48.283 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:34:54.178 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ce6547984f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:35:00.341 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:35:00.927 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:35:07.384 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 02:35:13.426 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:35:19.358 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:35:25.458 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:35:31.395 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13895180725c9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:35:37.697 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:35:49.376 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:35:55.394 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:36:01.675 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138d2d94622c0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:36:07.620 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:36:19.915 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:36:19.930 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:36:26.262 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138635f74d06f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:36:31.888 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e145340ee0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:36:31.942 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13855d98c2358' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:36:38.914 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138635f74d06f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:36:39.445 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:36:51.159 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:36:51.174 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138110584ecb8' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:36:51.719 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:36:51.776 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:03.533 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:03.592 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381c8efa8512' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:03.688 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:10.265 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382cdc641282' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:15.603 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:15.886 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:15.908 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386da4fca951' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:16.306 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:22.270 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382cdc641282' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:28.780 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:28.899 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:35.374 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:41.426 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1385dcca2ccd4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:41.705 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:37:41.731 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386a3a7438a0' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:47.371 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1381ab36275ff' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:37:53.800 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13899d16c63cc' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:00.278 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:05.607 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13899d16c63cc' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:05.818 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388ee161a6c2' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:11.575 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:11.767 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:18.784 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388ee161a6c2' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:19.418 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:19.465 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:25.638 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138ff90bd4080' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:32.045 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:32.070 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388e97d9c808' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:32.308 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384130e55127' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:32.650 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:39.077 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:38:44.837 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1380166606c03' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:44.853 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384130e55127' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:51.400 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:38:57.052 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:02.402 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:08.684 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f606b3852c' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:09.214 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 02:39:14.989 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:20.848 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:20.866 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:26.636 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:26.664 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:37.248 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x6c5cb1fffefc7887' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:37.278 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f145094db8' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:37.521 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386d4ee45954' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:43.869 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:43.888 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:43.984 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:49.502 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386d4ee45954' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:55.699 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0x003c84fffed749a9' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:55.967 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:55.975 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:39:55.993 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383326dc5b3f' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:39:56.069 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386d4ee45954' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:40:07.511 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xe8e07efffec2d475' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:40:07.517 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1386d4ee45954' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:40:14.817 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2025-07-31 02:42:29.084 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:42:35.030 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:42:41.080 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:42:47.459 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1382675725b6e' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:42:48.154 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13844ac9f9b04' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:00.420 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13844ac9f9b04' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:43:00.712 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13827aac43723' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:13.485 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13827aac43723' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:43:26.407 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:26.426 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:26.450 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13826532c9403' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:37.922 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:43:37.955 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138623bbb3f56' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:43:37.999 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c13826532c9403' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:43:38.583 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:44.453 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:44.486 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5Fbridge_5F0xe8e07efffec2e1e6' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:43:49.051 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138aac3ca6836' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:43:49.570 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:55.261 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:43:55.291 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:44:00.479 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138f6d11c9fda' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:44:06.632 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:44:06.683 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138e2f05ad5e4' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:44:07.009 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:44:13.551 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tuya:project:c41908412a' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2025-07-31 02:44:19.009 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1383d6d1f8663' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics
2025-07-31 02:44:19.084 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1384c527363d6' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:44:19.340 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c138279e10a535' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
2025-07-31 02:44:19.367 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:homeassistant:986f8a6a42:zigbee2mqtt_5F0xa4c1388efe100b46' changed from OFFLINE (COMMUNICATION_ERROR): Did not receive all required topics to UNKNOWN
It seems all mqtt generic devices are working, but this homeassitant not. i am on trace for mqtt and mqtt:homeassistant and don’t know why the “handler is missing” for those devices
The log mentions Java Heap Space. Either your heap size is too small for your setup, or something is leaking memory.
You can try to increase the java heap space if you haven’t already.
yes i know but it was only one issue of such kind, never happened again. There is still issue with these auto discovered home assitant things. I think there is the memory leak/slow down.
Current logs:
https://github.com/openhab/openhab-addons/issues/19087
Did you check cpu and or memory usage over time? With and without mqtt.ha enabled?
This could give a clear insights into a leak
Yes, i did CPU is rather not more than 90% one core, mem 65% not more for java process. So ok it’s slow, but after they finally initialize… i got not working things with “did not received all required topics”
during startup:
:~ $ top |grep java
    626 openhab   20   0 4638680 620796   7084 S 228.6  66.7  24:10.64 java
    626 openhab   20   0 4638680 620868   7084 S 104.9  66.7  24:13.84 java
    626 openhab   20   0 4638472 621016   7124 S 112.2  66.7  24:17.24 java
    626 openhab   20   0 4638472 623868   7052 S 313.9  67.1  24:26.75 java
    626 openhab   20   0 4637940 625316   6944 S 237.8  67.2  24:33.98 java
    626 openhab   20   0 4637940 625376   6944 S  98.3  67.2  24:36.96 java
    626 openhab   20   0 4637940 626252   7112 S 179.9  67.3  24:42.41 java
    626 openhab   20   0 4637940 628712   7128 S 313.5  67.6  24:51.94 java
    626 openhab   20   0 4637940 629412   7128 S 183.2  67.6  24:57.51 java
    626 openhab   20   0 4637940 629412   7128 S  99.7  67.6  25:00.53 java
    626 openhab   20   0 4640720 629988   7016 S 263.8  67.7  25:08.55 java
    626 openhab   20   0 4640512 630080   7016 S 223.4  67.7  25:15.32 java
    626 openhab   20   0 4640512 630100   7016 S  99.0  67.7  25:18.33 java
    626 openhab   20   0 4644800 629448   6700 S 129.7  67.7  25:22.26 java
    626 openhab   20   0 4646100 630048   6892 S 277.0  67.7  25:30.68 java
    626 openhab   20   0 4646100 630080   6912 S  99.3  67.7  25:33.70 java
    626 openhab   20   0 4646632 629584   6912 S 119.5  67.7  25:37.31 java
    626 openhab   20   0 4646632 629616   6984 S 251.0  67.7  25:44.94 java
    626 openhab   20   0 4646632 629628   6984 S  99.3  67.7  25:47.95 java
    626 openhab   20   0 4646632 629648   6984 S 109.2  67.7  25:51.26 java
    626 openhab   20   0 4646100 629652   7052 S 260.5  67.7  25:59.18 java
    626 openhab   20   0 4646100 629156   7052 S  95.2  67.6  26:02.17 java
    626 openhab   20   0 4646100 629148   7052 S 122.1  67.6  26:05.87 java
10 minutes after startup: i am not sure what is causing this cpu usage
$ top |grep java
626 openhab 20 0 4777172 686128 5196 S 90.0 73.7 33:33.26 java
626 openhab 20 0 4777172 681356 5208 S 160.8 73.2 33:38.31 java
626 openhab 20 0 4777704 679792 5244 S 118.2 73.1 33:41.89 java
626 openhab 20 0 4777704 679896 5244 S 98.3 73.1 33:44.87 java
626 openhab 20 0 4777704 681612 5052 S 138.2 73.3 33:49.07 java
626 openhab 20 0 4777912 660584 4976 S 111.6 71.0 33:52.45 java
626 openhab 20 0 4777912 661596 4248 S 133.3 71.1 33:56.49 java
626 openhab 20 0 4777704 644176 4408 S 99.0 69.2 33:59.49 java
The same setup was working < 5.0.0 maybe not at super speed but without noticable delays, i even turned off all rules/pwm/pids. just pure thinkgs and mqtt messages. indedd there is a lot of them because zigbee devices are spamming a lot, but still it was fine earlier. The CPU was never so high during a normall usage (after startup)
So when the system is essentially “idle,” openHAB is still using significant CPU? You can use top -h -p <pid of openHAB> and it will list the individual threads that are using a lot of CPU. If the top threads are GC threads, and they’re constantly running without ever taking a break, then it’s definitely memory issues slowing everything down. !Memory issue could indicate a memory leak, or needing to give the JVM memory. Also… are you going in to swap for the machine as a no whole?
I’ve had memory issues of my own in the past, with it going into that GC thrashing mode once every day or two, and then after restarting openHAB it would be fine again. Then I upgraded my machine to have a lot more memory, and I doubled the JVM heap size and I’ve not noticed any issues at all anymore, even after many days without a restart. So I’m hesitant to immediately suspect a memory leak, but it’s definitely possible. I’m not really familiar with any Java memory debugging tools, so I would have to learn them. My time has been very limited lately though for the automation hobby - work has been busy, and I have two slow-but-long semi-crisis I’m dealing with at home.
For comparison purposes (though it’s likely not a linear relationship, due to how big the Python base of the binding is), I currently have 344 home assistant things, with many of them having like 100 channels. And recently I had over 100 more than that (they’ve been migrated to use the new dedicated zwavejs binding). My max heap size is 16GB. I likely don’t need to have it that big, but I have 96GB on the machine now so I was quite generous. Before I upgraded I was only giving it 4GB and it was semi-stable.
Thank you! everything is stable for:
1/ generic mqtt things.
2/ Small amount (10) HA things. They initiate after reboot and working well.
3/ Big amount (40 HA things - whole system is freezing and its not possible to initialize these things.
When i disable them and enable 1-2 manualy, and repeat it i can initiate all of them with a success. My sugestion on githab is to change the biding to limit maximum concurrent initializations because they can freez the system and cause issue like mine (whole system freezed and no possibility to use GUI at all.
I have same issue with MQTT Homeassistant running on OH 5.0.0. I have recreated the thing and then recreated it via auto-discovery, but the thing stays in state UNKNOWN.
This worked with same setup on OH 4.3.3.
try to disable and re-enable the “Currently One” and check if it goes online
I have tried that, but status will still be UNKNOWN for ever.
TRACE log from re-discovery:
openhab> log:tail org.openhab.binding.mqtt
22:37:24.928 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.931 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.933 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.935 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:return_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.938 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.939 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:power_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.941 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.943 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.946 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.948 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:total_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.950 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.953 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.955 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.957 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Rh_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.960 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:time_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.962 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.964 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.966 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:boot_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/config
22:37:24.969 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Qh_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.971 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.974 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.978 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.979 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.983 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.984 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.987 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.989 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:37:24.991 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:returned_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:39:12.440 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : ServiceFactory.ungetService()
22:39:12.443 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : getting deactivate: deactivate
22:39:12.446 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Locating method deactivate in class org.openhab.binding.mqtt.internal.action.MQTTActions
22:39:12.453 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Declared Method org.openhab.binding.mqtt.internal.action.MQTTActions.deactivate([interface org.osgi.service.component.ComponentContext]) not found
22:39:12.460 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Locating method deactivate in class java.lang.Object
22:39:12.470 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Declared Method java.lang.Object.deactivate([interface org.osgi.service.component.ComponentContext]) not found
22:39:12.473 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : deactivate method [deactivate] not found, ignoring
22:39:12.476 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : DependencyManager: osgi.ds.satisfying.condition close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@248e77f1 at tracking count 1 refpairs: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
22:39:12.480 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Querying state active
22:39:12.483 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Changed state from active to satisfied
22:39:20.753 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.awtrixlight.internal.discovery.AwtrixLightDiscoveryService@15ed8adc to discovery topic awtrix/+/stats on broker mqtt:broker:2f94473178
22:39:20.755 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@58a2294c to discovery topic homeassistant/# on broker mqtt:broker:2f94473178
22:39:20.757 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.ruuvigateway.internal.discovery.RuuviGatewayDiscoveryService@4abd80f1 to discovery topic ruuvi/# on broker mqtt:broker:2f94473178
22:39:20.758 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.espmilighthub.internal.discovery.EspMilightHubDiscoveryService@3c746e59 to discovery topic milight/states/# on broker mqtt:broker:2f94473178
22:39:20.760 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.homie.internal.discovery.Homie300Discovery@72bd53c0 to discovery topic +/+/$homie on broker mqtt:broker:2f94473178
22:39:20.762 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : ServiceFactory.getService()
22:39:20.764 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : This thread collected dependencies
22:39:20.766 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : getService (ServiceFactory) dependencies collected.
22:39:20.767 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Querying state satisfied
22:39:20.770 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
22:39:20.772 [DEBUG] [ding.mqtt.internal.action.MQTTActions] - bundle org.openhab.binding.mqtt:5.0.0 (326)[org.openhab.binding.mqtt.internal.action.MQTTActions(411)] : Changed state from satisfied to active
22:39:20.813 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.awtrixlight.internal.discovery.AwtrixLightDiscoveryService@15ed8adc to discovery topic awtrix/+/stats on broker mqtt:broker:2f94473178
22:39:20.816 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@58a2294c to discovery topic homeassistant/# on broker mqtt:broker:2f94473178
22:39:20.831 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.ruuvigateway.internal.discovery.RuuviGatewayDiscoveryService@4abd80f1 to discovery topic ruuvi/# on broker mqtt:broker:2f94473178
22:39:20.840 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.homie.internal.discovery.Homie300Discovery@72bd53c0 to discovery topic +/+/$homie on broker mqtt:broker:2f94473178
22:39:20.845 [TRACE] [ng.mqtt.handler.AbstractBrokerHandler] - Subscribed org.openhab.binding.mqtt.espmilighthub.internal.discovery.EspMilightHubDiscoveryService@3c746e59 to discovery topic milight/states/# on broker mqtt:broker:2f94473178
22:40:25.048 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/U2_d0dd1e79cf58
22:40:25.056 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/P2_d0dd1e79cf58
22:40:25.074 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/return_d0dd1e79cf58
22:40:25.365 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/I1_d0dd1e79cf58
22:40:25.396 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/P3_d0dd1e79cf58
22:40:25.826 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/total_d0dd1e79cf58
22:40:25.852 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/power_d0dd1e79cf58
22:40:26.193 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R1_d0dd1e79cf58
22:40:26.294 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R_d0dd1e79cf58
22:40:26.687 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R2_d0dd1e79cf58
22:40:26.726 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Rh_d0dd1e79cf58
22:40:27.098 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/I2_d0dd1e79cf58
22:40:27.165 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q3_d0dd1e79cf58
22:40:27.893 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/P1_d0dd1e79cf58
22:40:27.900 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q2_d0dd1e79cf58
22:40:28.262 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q_d0dd1e79cf58
22:40:28.269 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/L2_d0dd1e79cf58
22:40:28.558 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/returned_d0dd1e79cf58
22:40:28.558 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/U1_d0dd1e79cf58
22:40:28.961 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/L3_d0dd1e79cf58
22:40:28.974 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/time_d0dd1e79cf58
22:40:28.991 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q1_d0dd1e79cf58
22:40:29.003 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/boot_d0dd1e79cf58
22:40:29.022 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R3_d0dd1e79cf58
22:40:29.044 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/U3_d0dd1e79cf58
22:40:29.067 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/L1_d0dd1e79cf58
22:40:29.098 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/I3_d0dd1e79cf58
22:40:29.125 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Qh_d0dd1e79cf58
22:40:31.130 [DEBUG] [nal.handler.HomeAssistantThingHandler] - Migrating Home Assistant thing mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58 from generic type to dynamic type mqtt:homeassistant_C1_5Fd0dd1e79cf58
22:40:31.172 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.175 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.181 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:return_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.182 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.188 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.189 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:power_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.191 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.195 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.198 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.201 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:total_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.202 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.204 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.207 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Rh_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.210 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.214 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:time_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.217 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.219 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:boot_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/config
22:40:31.221 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.227 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Qh_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.228 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.230 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.232 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.234 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.238 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I1_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.240 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.245 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I2_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.250 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:returned_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.254 [DEBUG] [hab.binding.mqtt.generic.ChannelState] - Unsubscribed channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I3_d0dd1e79cf58 from topic: currently/one/d0dd1e79cf58/state
22:40:31.465 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/U2_d0dd1e79cf58
22:40:31.477 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/return_d0dd1e79cf58
22:40:31.612 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Qh_d0dd1e79cf58
22:40:31.613 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/power_d0dd1e79cf58
22:40:31.674 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/L3_d0dd1e79cf58
22:40:31.674 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R_d0dd1e79cf58
22:40:31.728 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/time_d0dd1e79cf58
22:40:31.746 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Rh_d0dd1e79cf58
22:40:31.796 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q1_d0dd1e79cf58
22:40:31.827 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q3_d0dd1e79cf58
22:40:31.866 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/boot_d0dd1e79cf58
22:40:31.923 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/P1_d0dd1e79cf58
22:40:31.966 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R3_d0dd1e79cf58
22:40:31.979 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/L2_d0dd1e79cf58
22:40:32.029 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/U3_d0dd1e79cf58
22:40:32.029 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/U1_d0dd1e79cf58
22:40:32.073 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/L1_d0dd1e79cf58
22:40:32.086 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/P3_d0dd1e79cf58
22:40:32.100 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/I3_d0dd1e79cf58
22:40:32.303 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/P2_d0dd1e79cf58
22:40:32.324 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/total_d0dd1e79cf58
22:40:32.341 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R1_d0dd1e79cf58
22:40:32.361 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/R2_d0dd1e79cf58
22:40:32.376 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/I2_d0dd1e79cf58
22:40:32.391 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q2_d0dd1e79cf58
22:40:32.408 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/Q_d0dd1e79cf58
22:40:32.427 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/returned_d0dd1e79cf58
22:40:32.443 [TRACE] [assistant.internal.DiscoverComponents] - Found HomeAssistant component sensor/I1_d0dd1e79cf58
22:40:34.448 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:boot_d0dd1e79cf58
22:40:34.449 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:boot_d0dd1e79cf58
22:40:34.451 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I1_d0dd1e79cf58
22:40:34.452 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I1_d0dd1e79cf58
22:40:34.454 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I2_d0dd1e79cf58
22:40:34.455 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I2_d0dd1e79cf58
22:40:34.457 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I3_d0dd1e79cf58
22:40:34.458 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:I3_d0dd1e79cf58
22:40:34.460 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L1_d0dd1e79cf58
22:40:34.461 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L1_d0dd1e79cf58
22:40:34.462 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L2_d0dd1e79cf58
22:40:34.463 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L2_d0dd1e79cf58
22:40:34.465 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L3_d0dd1e79cf58
22:40:34.466 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:L3_d0dd1e79cf58
22:40:34.467 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P1_d0dd1e79cf58
22:40:34.468 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P1_d0dd1e79cf58
22:40:34.469 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P2_d0dd1e79cf58
22:40:34.470 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P2_d0dd1e79cf58
22:40:34.471 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P3_d0dd1e79cf58
22:40:34.472 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:P3_d0dd1e79cf58
22:40:34.474 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q1_d0dd1e79cf58
22:40:34.475 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q1_d0dd1e79cf58
22:40:34.476 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q2_d0dd1e79cf58
22:40:34.477 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q2_d0dd1e79cf58
22:40:34.479 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q3_d0dd1e79cf58
22:40:34.480 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q3_d0dd1e79cf58
22:40:34.481 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R1_d0dd1e79cf58
22:40:34.482 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R1_d0dd1e79cf58
22:40:34.483 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R2_d0dd1e79cf58
22:40:34.484 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R2_d0dd1e79cf58
22:40:34.486 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R3_d0dd1e79cf58
22:40:34.487 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R3_d0dd1e79cf58
22:40:34.488 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R_d0dd1e79cf58
22:40:34.489 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:R_d0dd1e79cf58
22:40:34.490 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Qh_d0dd1e79cf58
22:40:34.492 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Qh_d0dd1e79cf58
22:40:34.493 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q_d0dd1e79cf58
22:40:34.495 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Q_d0dd1e79cf58
22:40:34.497 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Rh_d0dd1e79cf58
22:40:34.498 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:Rh_d0dd1e79cf58
22:40:34.499 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:returned_d0dd1e79cf58
22:40:34.501 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:returned_d0dd1e79cf58
22:40:34.502 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:return_d0dd1e79cf58
22:40:34.503 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:return_d0dd1e79cf58
22:40:34.504 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:time_d0dd1e79cf58
22:40:34.505 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:time_d0dd1e79cf58
22:40:34.506 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U1_d0dd1e79cf58
22:40:34.507 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U1_d0dd1e79cf58
22:40:34.509 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U2_d0dd1e79cf58
22:40:34.510 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U2_d0dd1e79cf58
22:40:34.512 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U3_d0dd1e79cf58
22:40:34.513 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:U3_d0dd1e79cf58
22:40:34.514 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:total_d0dd1e79cf58
22:40:34.516 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:total_d0dd1e79cf58
22:40:34.517 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:power_d0dd1e79cf58
22:40:34.518 [DEBUG] [c.MqttChannelStateDescriptionProvider] - Adding state description for channel mqtt:homeassistant:2f94473178:C1_5Fd0dd1e79cf58:power_d0dd1e79cf58
This text will be hidden
After rebooting OH, recreating both MQTT broker and re-discovery of Currently One, the thing finally went ONLINE. :slight_smile:
Hello, i think i miss something important with MQTT binding… there is no MQTT home assistant component in 5.1. What happened?
Was it removed if yes why ? i am not sure what happened. @lsiepel maybe u know ?
