That would indeed be a simpler approach and I did not see that there was a binding specifically for the Shellys. So thank you for that hint. But since I stumbled upon MQTT related things quite often recently I thougt this would be a good reason to more deeply understand how MQTT works. And after some reading, I think I got most of it. So now it’s time for practice
That would be possible, but the Items linked to this Thing’s Channels do exactly nothing, e.g do not change to UNDEF either.
I just found an older post referring to this Github issue saying it was actually broken for HomeAssistant Things (I’m using Generic MQTT Thing instead), but this could quite probably be related. Also that post and issue seems to confirm my understanding of the intention this setting has - Device offline (e.g. battery empty) → Thing OFFLINE in openHAB, even though the connection is still available through the MQTT broker and a potentially retained message.
