MQTT binary-sensor using HomeAssistant discovery
I’m trying to bind a binary_sensor (following HA discovery syntax) but it doesn’t map the true/false boolean to the OnOffType
Command 'True' from channel 'mqtt:homeassistant:x:y:z_online' not supported by type 'OnOffValue': No enum constant org.openhab.core.library.types.OnOffType.True
Here is the channel config
- id: z_online
    channelTypeUID: mqtt:ha-switch
    label: Inverter Online
    configuration:
      component: binary_sensor
        - '{"name": "Inverter Online", "unique_id": "z_online",
          "state_topic": "aps/x/y", "value_template": "{{
          value_json.online }}", "device": {"identifiers": ["y"],
          "name": "APS Inverter y", "manufacturer": "APsystems",
          "via_device": "x"}, "availability_topic": "aps/status",
          "payload_available": "online", "payload_not_available": "offline",
          "payload_on": "true", "payload_off": "false", "icon":
          "mdi:power-plug"}'
      nodeid: ""
      objectid:
        - aps_z_online
And the MQTT message
Topic: aps/x/y  QoS: 0
  "online": false
I’ve tried to use profile but it looks like the event doesn’t reach this step
Thanks for your help
Not an HA config user, but there have been other posts about availability, and you may need to configure your app to not include availability. I assume you just want to use payload_on and payload_off. Also “true” and “True” are not the same.
I use generic MQTT things and an example switch config (from code tab)
  - id: Maytag_Washer_Switch_n
    channelTypeUID: mqtt:switch
    label: Maytag Washer Switch
    description: Power Switch
    configuration:
      commandTopic: zwave1/Washer_-_11/switch_binary/endpoint_0/targetValue/set
      stateTopic: zwave1/Washer_-_11/switch_binary/endpoint_0/currentValue
      transformationPattern:
        - JSONPATH:$.value
      off: "false"
      on: "true"
