we just noticed, that the MQTT binding seems not to work since “some” snapshots ago …
It does not even connect to the broker (activemq) anymore, as it always did before
The config files have never been changed …
The only message found in the openhab.log is during shutdown …
[INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'xxxx’
No related start/failure/error message anywhere ?!?!
Any ideas what else to check and how ?
(Tried start_debug, but does not show other info …)
There is just one (probably unrelated) error during startup “maybe” is has something to do with it ?
2017-06-24 10:17:12.552 [ERROR] [org.eclipse.smarthome.io.rest.sse ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sse
org.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:717)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:491)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:437)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:955)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1336)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://21.fwk149225732/javax/ws/rs/ext/RuntimeDelegate.class to bundleresource://21.fwk149225732/javax/ws/rs/ext/Run
timeDelegate.class
at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146)
at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120)
at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179)
at org.glassfish.jersey.media.sse.SseFeature.(SseFeature.java:62)
at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:44)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_91]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
… 14 more
It seems that something ist broken somewhere …
Benno
