I just tried to install the MQTT binding on a fresh install of OH2.5 on RPI. It gives me the following error. What does it mean and how can I solve it?
Thanks,
Bart
[ERROR] [raf.deployer.features.osgi.Activator] - BundleContext is no longer valid
java.lang.IllegalStateException: BundleContext is no longer valid
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:989) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.addBundleListener(BundleContextImpl.java:312) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.karaf.deployer.features.FeatureDeploymentListener.init(FeatureDeploymentListener.java:89) ~[?:?]
at org.apache.karaf.deployer.features.osgi.Activator$DeploymentFinishedListener.deploymentEvent(Activator.java:86) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.callListeners(FeaturesServiceImpl.java:321) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1067) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_152]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
None, the broker is in a different machine. Only installed the binding. It gives this error and I cannot add any broker as a thing (no things exist, most likely due to the binding not being properly installed)
It cleans cache and tmp files and contents are for ram and quick OH access. After doing this OH will take a few minuetes to restart.
Something not valid with the bundle.
I forgot to mention before stopping and cleaning the cache to uninstall the mqtt binding. After cleaning cache and OH is fully restarted then reinstall the binding.
@bartsnijder: Please post back the results as this is the second mqtt issue I’ve seen in the past few hours.
I removed the binding and added it again (without clearing the cache). Now all is ok.
Good that it works but somewhat disturbing that certain wow give different results.
Thanks for the help!
