If I write something to the topic using mosquitto_pub the switch changes from off to on or from on to off --> great
But if I press the switch within my sitemap the topic is set to âONâ --> not so great, I assumed that it should be 2 (based on the map file)
In the log file I get the following messages:
2020-01-19 13:22:26.185 [ome.event.ItemCommandEvent] - Item 'KG_Wohnraum_StarPower' received command OFF
2020-01-19 13:22:26.188 [nt.ItemStatePredictedEvent] - KG_Wohnraum_StarPower predicted to become OFF
2020-01-19 13:22:26.197 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Incoming payload 'ON' not supported by type 'NumberValue'
2020-01-19 13:22:26.197 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '2' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.
types.OnOffType.2
2020-01-19 13:22:26.212 [vent.ItemStateChangedEvent] - KG_Wohnraum_StarPower changed from ON to OFF
Youâre using a MAP, you donât want those as well.
Itâs not clear to me what order the binding does stuff in, but if tries to apply those before the MAP you might expect errors?
Thatâs exactly what it should do when you specify on=âONâ
(In case itâs not clear, the on= off = gets used both for inbound and outbound)
So, you need to remove that instruction.
Having done so, I would advise a binding restart to make sure it has picked up minor edits.
Then you can show us the current config and current problem, if any.
I removed the on/off parameter and performed a complete openhab restart (not just the binding).
If the current topic value is 2 and I press the switch I get the following log message:
2020-01-19 16:27:24.002 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command â2â not supported by type âOnOffValueâ: No enum constant org.eclipse.smarthome.core.library.
types.OnOffType.2
2020-01-19 16:27:24.015 [vent.ItemStateChangedEvent] - KG_Wohnraum_StarPowerTest changed from ON to OFF
and the value of the topic is changing to âONâ.
Iâm not sure what that means. You mean the last message payload on the topic was 2? From earlier comment, that has been correctly mapped to your openHAB Item having state ON,yes?
Which switch pressing are we talking about, something at the device or OH UI?
I assume youâve installed MAP transformation service, Iâs expect to see a more meaningful log if not.
Your âbidirectionalâ map file looks reasonable to me.
That partâs easy ;you have subscribed stateTopic to the same topic as commandTopic, so everything you command in openHAB is immediately (attempted to be) reflected back in the channel state, even if it doesnât fit.
That will happen regardless of any remote device also subscribing to or publishing to the topic.
Yes, the mapping from the broker towards openhab seems to work correct. If I publish anything to the broker (with mosquitto_pub) the value (on or off) is displayed correctly.
I am pressing the virtual button in the openhab UI.
I understood it, that the binding is working in the following way:
Value of an item is changed (e.g. button changed from ON to OFF)
Value is put through the transformationPattern method (then the value is e.g. 255)
The transformed value is published to the broker (e.g. 255 is published)
The transformed value is again received by openhab (e.g. 255 is received)
The received value is put into the transformationPatternOut method (e.g. 255 is transformed to OFF)
The received transformed value is put as new value into the item again (e.g. item is set to OFF while it was OFF)
When you poke an openHAB UI it sends a command to an Item. Commands are very distinct from Item states - although for a Switch they happen to have the same names.
So,
UI âbuttonâ sends command to OH Item.
Any binding channels linked to that Item get the command
(In general, but there are exceptional ways to configure some back to front)
The MQTT binding processes this command through transformationPatternOut then publishes to commandTopic
Thatâs the end of that, assuming all works. Note the Item state never changed.
So here, with OFF command we should get MAPped payload 255?
But meantime, OHâs autoupdate feature may kick in (itâs active by default)
This is like a dummy binding listening for commands and making predictions about the likely resulting state. Youâll see these predictions in your events.log.
Why? Because if you poke the UI you expect a response, not a long delay while messages are exchanged with some remote device. So itâs just guesswork for the sake of speed-up appearance. Doesnât involve MQTT at all.
Likely, your Item gets a fairly quick state update here, a guessed OFF.
Independently of all that, this channel of your happens to be subscribed to the identical topic by stateTopic. âSomeoneâ just published to that topic (you) so the broker will send the subscribed Thing a copy of your recent message.
Now the inbound transformationPattern will be used to process the payload into something hopefully suitable for a Switch type channel i.e. ON or OFF.
Here weâd expect to get 255 and MAP/convert to OFF, probably to no real effect if autoupdate has already updated Item state to OFF
So the flow and interaction with parameters is rather different, but so far as I can see your current config should work in practice.
To help diagnosis, you might temporarily change your commandTopic to something else to break the chain and figure whether the outbound or inbound leg is at issue.
Outbound MQTT transformation was pretty broken before 2.5, but you say you have that version.
I note youâve marked the topic to be retained at the broker, but I donât think this plays into this sequence? It might, if the remote device is also publishing to the same topic with or without retained. Who wins there, I wonder.
2020-01-19 18:48:41.353 [ome.event.ItemCommandEvent] - Item 'KG_Wohnraum_StarPowerTest' received command ON
2020-01-19 18:48:41.365 [nt.ItemStatePredictedEvent] - KG_Wohnraum_StarPowerTest predicted to become ON
2020-01-19 18:48:41.398 [vent.ItemStateChangedEvent] - KG_Wohnraum_StarPowerTest changed from OFF to ON
The animation_out topic is ALWAY âONâ, even if the sent command is OFF.
If I publish anything to animation_in (using mosquito_pub) openhab reacts as expected: 255 = OFF, every other number = ON.
The following output shows the list of installed mqtt components:
openhab> bundle:list | grep MQTT
223 x Active x 80 x 1.14.0 x openHAB MQTT Binding
232 x Active x 80 x 1.14.0 x openHAB MQTT Transport Bundle
251 x Active x 80 x 2.5.1 x openHAB Add-ons :: Bundles :: MQTT Broker Binding
252 x Active x 81 x 2.5.1 x openHAB Add-ons :: Bundles :: MQTT Things and Channels
253 x Active x 82 x 2.5.1 x openHAB Add-ons :: Bundles :: MQTT HomeAssistant Convention
254 x Active x 82 x 2.5.1 x openHAB Add-ons :: Bundles :: MQTT Homie Convention
255 x Active x 80 x 2.5.0 x openHAB Core :: Bundles :: MQTT Transport
Switch KG_Wohnraum_StarPowerTest
"Stern Status Test"
{channel="mqtt:topic:mosquitto:star:powertest2"}
Toggled the switch in the UI:
2020-01-19 22:07:35.785 [ome.event.ItemCommandEvent] - Item 'KG_Wohnraum_StarPowerTest' received command ON
2020-01-19 22:07:35.800 [nt.ItemStatePredictedEvent] - KG_Wohnraum_StarPowerTest predicted to become ON
2020-01-19 22:07:35.869 [vent.ItemStateChangedEvent] - KG_Wohnraum_StarPowerTest changed from OFF to ON
And sadly the result is always the same⊠the value of the topic is just âONâ.
2020-01-19 22:25:32.154 [ome.event.ItemCommandEvent] - Item 'KG_Wohnraum_StarPowerTest' received command OFF
2020-01-19 22:25:32.166 [nt.ItemStatePredictedEvent] - KG_Wohnraum_StarPowerTest predicted to become OFF
2020-01-19 22:25:32.168 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '0' with the file 'apple.map' : Target value not found in map for '0'
2020-01-19 22:25:32.226 [vent.ItemStateChangedEvent] - KG_Wohnraum_StarPowerTest changed from ON to OFF
2020-01-19 22:25:36.807 [ome.event.ItemCommandEvent] - Item 'KG_Wohnraum_StarPowerTest' received command ON
2020-01-19 22:25:36.810 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1' with the file 'apple.map' : Target value not found in map for '1'
And now I understand it even less
Where is the 1 or 0 coming from?
Aha ⊠now we see whatâs happening !!
Binding is âpre-transformingâ an OFF command to â0â etc.
With your original star_power.map that would score a âhitâ of course, by chance.
Armed with this knowledge you can fix your original problem for now with both a in-map as you had before, and an out-map mapping 0/1 to whatever you actually wanted.
But this is a binding bug. My guess is the on=/off= stuff is kicking in where it isnât wanted.
Okay, well we have simple test case; a Switch Item command fails to get mapped because it appears to auto transform to 0/1 before feeding to the wanted transform.
Who will raise a github issue? I am not an MQTT user. Do we know know if this worked at 2.5.0?
