After so many back/forth discussions with myself i now have to start with migration to MQTT2 binding (on 2.5.12). I found the old threat where someone explained shortly the steps. does not completely look the same but mostly.
happily i read that its possible to use both MQTT bindings in parallel which would make migration much more easy with less stress in fixing all at the same time…is that true.
As my broker thing does not go ONLINE at all.
Using that:
but not going online…simply localhost and 1883. and of course a new ID.
Any idea…maybe its not possible to use them in parallel???
According the initial post OH 2.5.12 is used hence not OH3 (which would be the latest).
Looking into the version 2 docs (here ) I don’t see this comment.
Good catch and sorry for the obvious faulty comment. It “used” to be so that you could use both bindings in parallel, hence the threads you did find. Can’t say when that change was introduced.
It was true at one point. I don’t think that’s still true. Sometime around 2.5.1 I think an incompatibility was introduced. In OH 3 the 1.x binding is not supported at all.
