I can’t get openhab to work with my mqtt broker. The broker is a Rpi with installed mqtt:
pip install paho-mqtt
The client is also a Rpi, with openhab installed and configured with item:
Switch node2_sw1 “sw2” (node2,all) {mqtt=">[mysensor:devices/admin/get:command:ON:1],>[mysensor:devices/admin/get:command:OFF:0]"}
Openhab runtime knows the switch is being toggled.
The Openhab MQTT binding was put in the addon folder.
Figure I might as well list the python code, which seems to be working
import paho.mqtt.client as paho
import RPi.GPIO as GPIO
import json, time
device credentials
device_id = ‘admin’ # * set your device id (will be the MQTT client username)
device_secret = ‘313131’ # * set your device secret (will be the MQTT client password)
random_client_id = ‘MQTT’ # * set a random client_id (max 23 char)
Board settings
buttonPin = 7
ledPin = 12
GPIO.setmode(GPIO.BOARD) # use P1 header pin numbering convention
GPIO.cleanup() # clean up resources
GPIO.setup(ledPin, GPIO.OUT) # led pin setup
GPIO.setup(buttonPin, GPIO.IN) # button pin setup
#GPIO.output(ledPin, GPIO.HIGH)
Callback events
connection event
def on_connect(client, data, flags, rc):
print('Connected, rc: ’ + str(rc))
subscription event
def on_subscribe(client, userdata, mid, gqos):
print('Subscribed: ’ + str(mid))
received message event
def on_message(client, obj, msg):
# get the JSON message
json_data = msg.payload
# check the status property value
print(json_data)
value = json.loads(json_data)[‘properties’][0][‘value’]
if value == ‘on’:
led_status = GPIO.HIGH
else:
led_status = GPIO.LOW
GPIO.output(ledPin, GPIO.LOW)
# confirm changes to Leylan
client.publish(out_topic, json_data)
MQTT settings
create the MQTT client
client = paho.Client(client_id=random_client_id, protocol=paho.MQTTv31)
* set a random string (max 23 chars)
assign event callbacks
client.on_message = on_message
client.on_connect = on_connect
client.on_subscribe = on_subscribe
device topics
in_topic = ‘devices/’ + device_id + ‘/get’ # receiving messages
out_topic = ‘devices/’ + device_id + ‘/set’ # publishing messages
client connection
client.username_pw_set(device_id, device_secret) # MQTT server credentials
client.connect(“10.10.10.105”) # MQTT server address
client.subscribe(in_topic, 0) # MQTT subscribtion (with QoS level 0)
Button logic
prev_status = GPIO.LOW
updated_at = 0 # the last time the output pin was toggled
debounce = 0.2 # the debounce time, increase if the output flickers
Continue the network loop, exit when an error occurs
rc = 0
while rc == 0:
rc = client.loop()
button = GPIO.input(buttonPin)
if button != prev_status and time.time() - updated_at > debounce:
prev_status = button
updated_at = time.time()
if button:
led_status = not led_status
button_payload = 'off'
if led_status == GPIO.HIGH:
button_payload = 'on'
# effectively update the light status
GPIO.output(ledPin, led_status)
payload = { 'properties': [{ 'id': '518be5a700045e1521000001', 'value': button_payload }] }
client.publish(out_topic, json.dumps(payload))
print('rc: ’ + str(rc))
