I’m getting the above error, and I think it’s probably because it can’t map my text to a number. My item looks like this:
Number Alarm_State “Alarm State [MAP(alarmmode.map):%s]” { mqtt=“<[localbroker:/AlarmMode:command:MAP(alarmmode.map)], >[localbroker:/AlarmModeSet:command:*:MAP(alarmmode.map)]”}
alarmmode.map looks like this:
Disarm mode=0
Away mode=1
Home mode=2
but this gives me this error when I add a message to the queue:
2016-01-16 17:44:57.904 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘Disarm mode’ in the file ‘alarmmode.map’.
2016-01-16 17:44:57.904 [WARN ] [.c.i.events.EventPublisherImpl] - given command is NULL, couldn’t post command to ‘Alarm_State’
When I make alarmmode.map look like this (which I think is probably the correct way):
0=Disarm mode
1=Away mode
2=Home mode
I still get the same error:
2016-01-16 17:47:16.197 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘Disarm mode’ in the file ‘alarmmode.map’.
2016-01-16 17:47:16.198 [WARN ] [.c.i.events.EventPublisherImpl] - given command is NULL, couldn’t post command to ‘Alarm_State’
Changing the state will only add a message to the queue if I use the second type of map (number->text).
Also whats the difference between state and command? I know I can use either as part of the binding, and I’ve guessed command is what I need, but I don’t know what the difference is.
Ta
Ross
