Mqtt binding + triggered/updated/changed + rules
I have a motion sensor setup in my things file
Thing topic BedroomRepeaterNode
		Channels:
			Type switch : MotionSensor "Bedroom Motion Sensor" [stateTopic = "mygateway1-out/200/1/1/0/16", on="1", off="0"  ]
I was trying to get my motionsensor rule to fire. The log kept saying when motion was detected that the corresponding item (below)
Switch MasterBedroom_MotionSensor_raw (gMotionSensorsRaw) { channel = "mqtt:topic:broker1:BedroomRepeaterNode:MotionSensor"  }
Had changed from 0 to 1. and so on.
So I had a rule setup. No matter what though, I couldn’t get said rule to trigger. I tried using changed, updated, updated from to , command ON ect. I even added all the different variations with this or that or this other thing.
Nothing.
But I did figure out that if I added the trigger=true i could get something what would fire.
		Channels:
			Type switch : MotionSensor "Bedroom Motion Sensor" [stateTopic = "mygateway1-out/200/1/1/0/16", on="1", off="0", trigger=true  ]
So then my rule became
rule "testing MotionSensor changed"
   Channel "mqtt:topic:broker1:BedroomRepeaterNode:MotionSensor" triggered 1
This worked. I was able to finish my rule and do more testing. Now, I am trying to stick to using design patterns. So I am trying to bring this in to my group rule.
rule "Raw Motion Sensor State Changed"
    Member of gMotionSensorsRaw received update  // from OFF to ON
So there is the problem… i don’t know if channel triggers can be grouped?..
Should i go back to just triggering on item changes? If so… is there something I am missing with the mqtt binding not triggering a rule to fire?
Thanks!
Maybe. It’s the Item that is important, so look in the events.logs for what it is doing.
For example, you mentioned a Switch type Item changing 0/1, but Switch types don’t do that, they’re ON/OFF
So here is my item, log when it changed and the rule (which unfortunately did not trigger)
Thing
		Channels:
Item referencing thing
Switch  testing_Motion    { channel="mqtt:topic:broker1:BedroomRepeaterNode:MotionSensor"}
Log entry when i walked in front of sensor
2019-10-20 13:08:14.092 [vent.ItemStateChangedEvent] - testing_Motion changed from OFF to ON
Rule that didn’t fire :confused:
    Item testing_Motion changed to ON
    logInfo("Testing Motion Rule", "IM HERE!!!")
I have these test items setup now so I can really muck it up now lol
Updated rule condition to
Log shows item changed from OFF to ON but still no entry saying IM HERE
2019-10-20 14:03:59.089 [vent.ItemStateChangedEvent] - testing_Motion changed from OFF to ON
Have you looked in openhab.log to see if your rule file loads?
Make sure there is only one rule (system wide) named “testing MotionSensor changed”
I am actively watching the openhab.log and events.log To ensure there is no duplicates I have renamed the rule to
rule “abc testing MotionSensor changed”
The rule is not firing. I have only been able to get it to fire when i used Channel triggered.
The item changing is just not firing.
2019-10-20 14:12:10.853 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.rules'
2019-10-20 14:12:13.380 [vent.ItemStateChangedEvent] - testing_Motion changed from ON to OFF
2019-10-20 14:12:24.597 [vent.ItemStateChangedEvent] - testing_Motion changed from OFF to ON
2019-10-20 14:13:07.145 [vent.ItemStateChangedEvent] - testing_Motion changed from ON to OFF
2019-10-20 14:13:17.811 [vent.ItemStateChangedEvent] - testing_Motion changed from OFF to ON
But no entry saying “im here”
Initially I only wanted it to fire when changed from OFF to ON. But now i have it set to fire on any change and still nothing.
even with
rule "abc testing MotionSensor changed"
    Item testing_Motion changed or
    Item testing_Motion received command or
    Item testing_Motion received update
I still get nothing
2019-10-20 14:16:19.019 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'test.rules'
2019-10-20 14:16:26.335 [vent.ItemStateChangedEvent] - testing_Motion changed from ON to OFF
2019-10-20 14:17:30.740 [vent.ItemStateChangedEvent] - MasterBedroom_LightLevel changed from 70 to 72
2019-10-20 14:17:30.741 [vent.ItemStateChangedEvent] - testing_AmbientLight changed from 70 to 72
2019-10-20 14:17:36.907 [vent.ItemStateChangedEvent] - testing_Motion changed from OFF to ON
2019-10-20 14:17:45.712 [vent.ItemStateChangedEvent] - MasterBedroom_LightLevel changed from 72 to 77
2019-10-20 14:17:45.713 [vent.ItemStateChangedEvent] - testing_AmbientLight changed from 72 to 77
Well, of course it works for everybody else. I would suggest a restart of openHAB, it’s not unknown for things to get in a knot after in flight editing.
Yeah I thought maybe that samething, especially with the mqtt binding. So i have done a few restarts today. Even a full reboot of the box about an hour ago.
Ill keep poking away
Cause a different visible event
rule "testing MotionSensor command"
    testing_Motion.sendCommand(OFF)
Your binding does not generate commands, of course, so there won’t be any triggers off that.
That doesn’t trigger either. So far, the only way I have been able to get this rule to trigger is either using the channel trigger. or if i do a manual curl command and send a command to the item. But the item being updated from the mqtt binding is just not triggering it.
Okay, make a new Item. Put it on your sitemap as a Switch. Write a new rule that responds to a change. All new mind, no editing your old ones.
When that works as seen in your logs, add the zwave channel to your new Item and see if that ackles. (you can have more than one Item linked to the same channel)
I suspect something screwy with your Item, like a definition from both PaperUI and from xxx.items file.
this isn’t zwave. this is mqtt.
I have created new configs for testing this.
Switch NewTest_Item { channel=“mqtt:topic:broker1:BedroomRepeaterNode:MotionSensor”}
rule "new item test command"
    Item NewTest_Item changed
    logError("Another test", "NewTest_Item")
Send 1/0/ON/OFF to the topic, log says it updated the item. but the rule does not execute
2019-10-20 17:47:29.936 [vent.ItemStateChangedEvent] - NewTest_Item changed from OFF to ON
2019-10-20 17:47:40.239 [vent.ItemStateChangedEvent] - NewTest_Item changed from ON to OFF
2019-10-20 17:48:59.622 [vent.ItemStateChangedEvent] - NewTest_Item changed from OFF to ON
I know other rules are firing. But they aren’t being triggered by items using mqtt.
Just seems like the mqtt binding state topic isn’t actually triggering rules. If i do a curl cli command and send the command of ON/OFF/1/0 the previous rule would fire.
I have even removed and reinstalled the mqtt binding.
This is not comparable to what the MQTT binding should do, so it doesn’t help.
In general, commands with openHAB are issued by UI or rules and the bindings process those on towards realdevices.
Data coming in from real devices is processed by bindings into updates for Items. (with some exceptions)
My suggestion was to make a new Item with no MQTT linkage at all and satidfy yourself you can trigger a rule from UI. So that you know the Item and the rule are good.
Only then to add your channel. It’s a diagnostic process to narrow your problem down, but of course you may follow any track you wish.
If a binding channel (MQTT or anyone else) causes a successful Item state change, it seems difficult to blame the binding for missed events.
I have no idea if this is how it is supposed to be. But I did finally get it to trigger. I had to add “postCommand=true” to the things file entry.
		Channels:
			Type switch : MotionSensor "Bedroom Motion Sensor" [stateTopic = "mygateway1-out/200/1/1/0/16", on="1", off="0" , postCommand=true ]
Then update my rule
    Item NewTest_Item received command ON
Now when the MQTT topic receives the update it triggers the rule now.
2019-10-20 18:39:42.595 [ome.event.ItemCommandEvent] - Item 'NewTest_Item' received command ON
2019-10-20 18:39:42.601 [nt.ItemStatePredictedEvent] - testing_Motion predicted to become ON
2019-10-20 18:39:42.595 [ERROR] [.smarthome.model.script.Another test] - NewTest_Item
I don’t know if that’s how it should be. Seems kind of odd, definitely seems like a state change from a sensor would be enough to actually trigger rules but for some reason it was not. I even upgraded from 2.4 to 2.5 to see if maybe something was just weird and got the same behavior.
Might have to spin up a docker image later of openhab and throw my configs in it to see if it’s the same there or if something is really wrong on my OH machine.
I have other bindings and what not that are triggering rules no problem. I see that stuff in the logs already.
But ill give this route a go as well.
What appears to be missing here (but perhaps just left off) is a change to the Item, as a consequence of autoupdate’s prediction. Perhaps it was already ON in this case.
If you are seeing changes, add yet another rule triggered from changed.
Well, not really. While MQTT binding does allow for this “command forcing” it is really intended for something like a keypad, where the usage is more like a UI “giving instructions” to openHAB.
The ordinary way of ‘stateTopic’ resulting in an update is meant for “device status” reporting.
Item is still the same
My sensor reports in current state every 5 seconds. So when it sends “0” i see it shows it’s off in mqttspy. I then send a message right behind it of 1 and prior to adding the postCommand=true it would show that the item updated. But the rule did not trigger. If you look at my previous logs above you will see I was sending info to update it to OFF then to ON then to OFF and nothing triggered.
I have not changed the item, but changed the trigger rule to now treat it as a command and with the postCommand=true when the 1 comes in its sending a the command to the item to be on. Just like what I was doing with curl.
I agree, i don’t think it should be like that. But for whatever reason the rules will not fire with the updated status. Even when I said don’t care if it’s updated to on or off, but ANY update write to the log, it still did not every trigger. This is the only way I have been able to get it to work.
I have a docker image spinning up right now pointed at the same configs :slight_smile: Lets see what it says about all this lol
Can you see your Thing with its channel in PaperUI? Is it actually ID as above, or
“mqtt:topic:BedroomRepeaterNode:MotionSensor”
