So I’ve transitioned from OH 2 to OH3 recently, I have had mlights set up since OH2 working good. Everything was working well in OH2, sending a command from OH to the lights as well as updates made from the remote showed in OH. Currently using OH 3.3.0
transitioned to OH3, everything works well, in terms of anything sent from openhab, such as turning on off lights, levels, color work well. Although it does not appear that any changes made with the remote are not showing in OH. in the past if I turned on a light with the remote the changes would be reflected in OH.
Nothing has changed in my espsetup:
MQTT topic pattern: milight/commands/:device_id/:device_type/:group_id
MQTT state topic pattern: milight/states/:device_id/:device_type/:group_id
Group state fields: state,level,hue,saturation,mode,color_temp,bulb_mode
MQTT for milight setup as this:
Things…
Bridge mqtt:broker:myBroker [ host=“localhost”, secure=false, password=“XXXXXXX”, qos=1, username=“XXXXXXX”]
Thing mqtt:rgb_cct:0x88E1 “Overhead” (mqtt:broker:myBroker) @ “MQTT”
Thing mqtt:rgb_cct:0x88E2 “Spot” (mqtt:broker:myBroker) @ “MQTT”
Thing mqtt:rgb_cct:0x88E3 “Wall” (mqtt:broker:myBroker) @ “MQTT”
Thing mqtt:rgb_cct:0x88E4 “Sink” (mqtt:broker:myBroker) @ “MQTT”Thing mqtt:rgb_cct:0xAE91 “Ceiling” (mqtt:broker:myBroker) @ “MQTT”
Thing mqtt:rgb_cct:0xAE92 “Accent” (mqtt:broker:myBroker) @ “MQTT”
Thing mqtt:rgb_cct:0xAE93 “Bedside” (mqtt:broker:myBroker) @ “MQTT”
Thing mqtt:rgb_cct:0xAE94 “Stars” (mqtt:broker:myBroker) @ “MQTT”
items:
// Living Room 1 - Overhead lights
Switch Overhead_light_switch “Overhead Light Switch” {channel=“mqtt:rgb_cct:0x88E1:level”}
Dimmer Overhead_light_temp “Overhead Light Temperature” {channel=“mqtt:rgb_cct:0x88E1:colourTemperature”}
Color Overhead_light_hue “Overhead Light Hue” {channel=“mqtt:rgb_cct:0x88E1:colour”}
Dimmer Overhead_light_level “Overhead Light” {channel=“mqtt:rgb_cct:0x88E1:level”}// Living Room 2 - Spot Lights
Switch spot_light_switch “Spot Light Switch” {channel=“mqtt:rgb_cct:0x88E2:level”}
Dimmer spot_light_temp “Spot Light Temperature” {channel=“mqtt:rgb_cct:0x88E2:colourTemperature”}
Color spot_light_hue “Spot Light Hue” {channel=“mqtt:rgb_cct:0x88E2:colour”}
Dimmer spot_light_level “Spot Light” {channel=“mqtt:rgb_cct:0x88E2:level”, ga=“light”}// Living Room 3 - Wall lights
Switch wall_light_switch “Wall Light Switch” { channel=“mqtt:rgb_cct:0x88E3:level” }
Dimmer wall_light_temp “Wall Light Temperature” { channel=“mqtt:rgb_cct:0x88E3:colourTemperature” }
Color wall_light_hue “Wall Light Hue” { channel=“mqtt:rgb_cct:0x88E3:colour” }
Dimmer wall_light_level “Wall Light” { channel=“mqtt:rgb_cct:0x88E3:level”, ga=“light” }// Living Room 4 - Sink lights
Switch sink_light_switch “Sink Light Switch” {channel=“mqtt:rgb_cct:0x88E4:level”}
Dimmer sink_light_temp “Sink Light Temperature” {channel=“mqtt:rgb_cct:0x88E4:colourTemperature”}
Color sink_light_hue “Sink Light Hue” {channel=“mqtt:rgb_cct:0x88E4:colour”}
Dimmer sink_light_level “Sink Light” {channel=“mqtt:rgb_cct:0x88E4:level”, ga=“light”}// Bedroom Room 1 - Ceiling lights
Switch ceiling_light_switch “Ceiling Light Switch” {channel=“mqtt:rgb_cct:0xAE91:level”}
Dimmer ceiling_light_temp “Ceiling Light Temperature” {channel=“mqtt:rgb_cct:0xAE91:colourTemperature”}
Color ceiling_light_hue “Ceiling Light Hue” {channel=“mqtt:rgb_cct:0xAE91:colour”}
Dimmer ceiling_light_level “Ceiling Light” {channel=“mqtt:rgb_cct:0xAE91:level”, ga=“light”}// Bedroom Room 2 - Accent Lights
Switch accent_light_switch “Accent Light Switch” {channel=“mqtt:rgb_cct:0xAE92:level”}
Dimmer accent_light_temp “Accent Light Temperature” {channel=“mqtt:rgb_cct:0xAE92:colourTemperature”}
Color accent_light_hue “Accent Light Hue” {channel=“mqtt:rgb_cct:0xAE92:colour”}
Dimmer accent_light_level “Accent Light” {channel=“mqtt:rgb_cct:0xAE92:level”, ga=“light”}// Bedroom Room 3 - Bedside lights
Switch bed_light_switch “Bedside Light Switch” {channel=“mqtt:rgb_cct:0xAE93:level”}
Dimmer bed_light_temp “Bedside Light Temperature” {channel=“mqtt:rgb_cct:0xAE93:colourTemperature”}
Color bed_light_hue “Bedside Light Hue” {channel=“mqtt:rgb_cct:0xAE93:colour”}
Dimmer bed_light_level “Bedside Light” {channel=“mqtt:rgb_cct:0xAE93:level”, ga=“light”}
One thing I note, and not sure it matters, but the MQTT updates seem to be different depending on if I’m doing it with the remote or from openhab.
For example, when i turn a specific light off and on via openhab the MQTT topic looks like this: I get two specific lines:
milight/commands/0x88E/rgb_cct/2 {“state”:“OFF”,“level”:0}
milight/states/0x88E/rgb_cct/2 {“state”:“OFF”,“level”:0,“color_temp”:370,“bulb_mode”:“white”}
milight/commands/0x88E/rgb_cct/2 {“state”:“ON”,“level”:62}
milight/states/0x88E/rgb_cct/2 {“state”:“ON”,“level”:62,“color_temp”:370,“bulb_mode”:“white”}
but when doing it with the remote, I get this:
milight/states/0x88E/rgb_cct/2 {“state”:“OFF”,“level”:62,“color_temp”:370,“bulb_mode”:“white”}
near as I can tell, I have everything setup correctly, just not sure what I might be missing.
thanks for any help anyone might have++
