MQTT broker as event bus: 1.x vs. 2.x
From what I gather from other confused users in various threads, the 1.x MQTT binding out of the box could push all events to a MQTT broker, so that it could act as an event bus - and the 2.x MQTT can’t (at least the one from 2.4). Is that assessment correct ?
I have read advice that, if event bus functionality is desired, the best course of action for now to use the 1.x MQTT binding. Can anyone confirm that ?
Is there a good way to let a 2.4 Openhab push all events to a MQTT broker ? I found this mqqteventbus.rules but it looks like a lot of rules for something that I expected to be a couple of “catch-all”… Should I use it anyway ?
Is some “dump all events to MQTT” event bus feature roadmapped for the 2.x MQTT binding ?
There is an easy way with mqtt2 but its a bit hidden right now, you ll find how to do it here Roadmap: MQTT binding - #12 by David_Graeff just click on the link and scroll to the part about synchronizing two instances
Thank you - I had read that thread and the MQTT broker synchronization recipe you allude to, but I had failed to catch how relevant they are to my questions.
So, it looks like the below rule is pretty much what I need:
rule "Publish all"
      Member of myGroupOfItems changed
   val actions = getActions("mqtt","mqtt:broker:myUnsecureBroker")
   actions.publishMQTT("allItems/"+triggeringItem.name,triggeringItem.state.toString)
Except of course that I’ll need to define a group - from what I understand from threads here, there is no built-in “all items” group… Wouldn’t such thing be useful ?
Sure. But the old rule syntax is not extended anymore. openHAB is a bit in flux at the moment.
It is probably possible with the new Java scripting support in openHAB (Jython, Javascript syntax)
you can give HABApp a try. It’s a rule engine for home automation in python I am using to easily create rules.
I have included an example rule which does exactly what you want without further configuration changes.
I would love to get some feedback :slight_smile:
I rewrote the mqtt2 eventbus rules to work with the awesome jython decorators from @5iver if you want to use those
from core.rules import rule
from core.triggers import when
@rule("Publish all")
@when("Member of OutItems changed")
def MQTTPublishOut(event):
    output1 = event.itemName
    output2 = str(event.itemState)
    actions.get("mqtt","mqtt:broker:f79d2a84").publishMQTT("allItemsout/"+output1,output2)
@rule("Receive all")
@when("Channel mqtt:broker:f79d2a84:TriggerIn triggered")
def MQTTPublishIn(event):
    input1 = event.event
    input2 = input1.split("/")
    input3 = input2[1].split("#")
    events.sendCommand(input3[0], input3[1])
Right now you need to comment out two lines in the triggers.py for it too work, see here Simplified Jython rule definition (similar to Rules DSL) using a universal decorator - #154 by JGKK
As the publish channel of the MQTT2 Binding is declared as a State channel and not a trigger channel, see here Simplified Jython rule definition (similar to Rules DSL) using a universal decorator - #155 by 5iver
Is this on purpose @David_Graeff?
There has already been a bug report opened by @5iver.
I’m currently clueless why that is, as the xml description file clearly marks trigger channels as type “trigger”. Will investigate when the integration tests work again on the addons repo.
For reference…
https://github.com/openhab/openhab2-addons/issues/5410
What about using the persistence for the outgoing messages? That could be an “elegant” way of addressing the point, without having to define a group as it is possible to use the * wildcard.
Just my two cents.
