Version: 2.5.9 (Build)
Raspberry PI 4
Hi Team,
i just installed zigbee2mqtt with mosquitto and everything works without problems.
Now I finished my solarcontroller that publishes all data to the same mosquitto broker.
I just see the state descriptions and the subscription:
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature1
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature2
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature3
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature4
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature5
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature6
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature7
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature8
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:temperature9
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:switch1
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:switch2
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:switch3
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:switch4
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:frequency1
Adding state description for channel mqtt:topic:mosquitto:solarcontrol:frequency2
Subscribed channel mqtt:topic:mosquitto:solarcontrol:switch1 to topic: solarcontrol/rel/rel0
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature9 to topic: solarcontrol/temp/283AA73802000045
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature8 to topic: solarcontrol/temp/28F29438020000B1
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature7 to topic: solarcontrol/temp/106D57290208006C
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature6 to topic: solarcontrol/temp/RTD5
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature5 to topic: solarcontrol/temp/RTD4
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature4 to topic: solarcontrol/temp/RTD3
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature3 to topic: solarcontrol/temp/RTD2
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature1 to topic: solarcontrol/temp/RTD0
Subscribed channel mqtt:topic:mosquitto:solarcontrol:temperature2 to topic: solarcontrol/temp/RTD1
Subscribed channel mqtt:topic:mosquitto:solarcontrol:frequency1 to topic: solarcontrol/flow/flow0
Subscribed channel mqtt:topic:mosquitto:solarcontrol:frequency2 to topic: solarcontrol/flow/flow1
Subscribed channel mqtt:topic:mosquitto:solarcontrol:switch4 to topic: solarcontrol/rel/rel3
Subscribed channel mqtt:topic:mosquitto:solarcontrol:switch2 to topic: solarcontrol/rel/rel1
Subscribed channel mqtt:topic:mosquitto:solarcontrol:switch3 to topic: solarcontrol/rel/rel2
The PaperUI shows no panel, the BasicUI shows the panel without data.
I cannot solve the problem… Any Ideas?
Example of the Payloads:
The Device has
- 6 RTD Ports
- Onewire.
- 4 Relais
- 2 ports to messure impules from the flow sensors
Is it possible that one thing can only have one temperature port?
Thanks in advance
Jens
P.S.: Some Payloads of my device: (Homemade, RaspberryPi Zero)
solarcontrol/flow/flow1 b’{“sensorType”: “flow”, “id”: “flow1”, “name”: “flow1”, “flow”: 0, “time”: 1602800860663720071, “valid”: true}’
solarcontrol/rel/rel2 b’{“sensorType”: “rel”, “id”: “rel2”, “name”: “rel2”, “state”: “OFF”, “time”: 1602800901711503628, “valid”: true}’
solarcontrol/temp/RTD1 b’{“sensorType”: “rtd”, “id”: 1, “name”: “RTD1”, “resistence”: 997.052001953125, “temp”: -0.7397311196726588, “time”: 1602800944170003724, “valid”: true}’
solarcontrol/temp/28F29438020000B1 b’{“sensorType”: “owtemp”, “id”: “28F29438020000B1”, “name”: “28F29438020000B1”, “temp”: 25.125, “time”: 1602800990373456593, “valid”: true}’
