MQTT Channel string not working
Raspberry PI Openhab 3
MQTT binding 3
My channel “mqtt:topic:b8be661fe1:slaapkamer_wireless_wall_switch:action” can produce 3 strings “single_right”, “single_left” and “single_both”
I can see this in my event.log
2021-01-20 22:18:14.821 [INFO ] [openhab.event.ChannelTriggeredEvent ] - mqtt:topic:b8be661fe1:slaapkamer_wireless_wall_switch:action triggered single_left
How do i use this in a rule to react to one of the values?
The rule below gives no error , but its not working
//Wireless 2 button switch
rule "lamp on/off"
    Channel "mqtt:topic:b8be661fe1:slaapkamer_wireless_wall_switch:action" triggered
    var actionName = "receivedEvent.getEvent"
    switch(actionName) {
        case "single_left": {
            StudeerkamerHuewhite_Dimmer.sendCommand(100)
			logInfo("test", "Light ON")
        case "single_right": {
            StudeerkamerHuewhite_Dimmer.sendCommand(0)
			logInfo("test", "Light OFF")
How do i get the value off my channel in my variable “actionName”
Something which might make this easier is to link your String Channel to a String Item, and then trigger when that Item has changed.
I think you can then use triggeringItem.state in your subsequent rule, i.e.
switch(triggeringItem.state) {
Scroll down to the DSL rule in the post below, where I do what you’re ultimately after, in a slightly different way:
This line of code sets actionName to the String “receivedEvent.getEvent”. That’s not meaningful. You want the actual string value from the event itself.
val actionName = receivedEvent
In OH 3 receivedEvent was changed from being an object that carries an event to just be the String value of the event.
But, if I were to set this up I’d do it in the Channel and use a mapping or JS transformation to convert the values to an appropriate Item state. Then there’s be no need for a rule at all.
Both of you explanations were very educational.
Thanks for that.
I’ve gotten it working with "val actionName = receivedEvent
I get the concept, but sometimes find it difficult to find the correct spelling (syntax) in DSL and other languages used in openhab
Thanks.
