Mqtt command not working from openhab but mosquitto_pub is working
I am trying to ON/OFF relay using mqtt with openhab.Relay is connected with nodemcu esp8266.Mqtt client is able to turn off/on the led but openhab item is not.
Below is my mqttDemo.sitemap.
sitemap mqttDemo label=“MQTT Demo” {
Frame label=“Enocean Devices” {
Switch item=switch2 label=“Switch 2”
home.items
// EnOcean devices
Switch switch2 {mqtt=“>[broker:esp8266/led_control:command:ON:1],>[broker:esp8266/led_control:command:OFF:0]”}
mqtt.cfg
broker.url=tcp://192.168.0.106:1883
broker.user=openhabian
broker.pwd=redhat
Below command is also working fine
mosquitto_pub -h 192.168.0.106 -u openhabian -P redhat -t esp8266/led_control -m 0
mqtt binding is also installed
kindly help me out
Welcome to the openHAB forum!
Which MQTT binding are you using? The used syntax is for MQTT 1 version, the actual binding is MQTT 2.4 for the stable release.
Hi Jurgen,
I am using binding-mqtt - 2.4.0
Regards,
Rishi
You have to use the actual syntax, read Here
Can you exactly tell me full syntax that I need to add in items.one more question I have configured mqtt from paper UI and status is online.Still I need to add mqtt.cfg under services.
I am stuck here just to turn on/off the relay and can not move forward until this does not resolve.
Rishi
What you have probably setup via PaperUI is the MQTT Broker Thing.
Next you need to create a Generic MQTT Thing via PaperUI, which connects to the above Broker.
On this Thing create a new Channel of type Swich which subscribes to a MQTT command topic ( most probable something like: esp8266/led_control)
I can’t say which state topic to use your case.
