is anything useful in the logs?
read again the examples that Thom posted, You will get it working
(it seems that your broker connection is fine)
[19:34:12] openhabian@openHABianPi:~$ lsof -i :1883
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
mosquitto 7105 openhabian 5u IPv4 21570 0t0 TCP localhost:40962->localhost:1883 (ESTABLISHED)
ANYWAY… these are my settings now:
sonoff device TH16:
Client Id = OH2MQTT
Topic = sonoff1
Full Topic = tasmota/%topic%/%prefix%/
items (according to @ThomDietrich) :
Switch Sonoff_TH16A "Balkonmagic" <stars> {mqtt=">[broker:tasmota/sonoff1/cmnd/POWER:command:*:default], <[broker:tasmota/sonoff1/stat/POWER:state:default]"}
Number Sonoff_TH16A_RSSI "Balkonmagic RSSI [%d %%]" {mqtt="<[broker:tasmota/sonoff1/tele/STATE:state:JSONPATH($.Wifi.RSSI)]"}
Switch Sonoff_TH16A_Unreach "Balkonmagic unreachable" <siren> {mqtt="<[broker:tasmota/sonoff1/tele/LWT:state:MAP(unreach.map)]"}
mqtt.cfg:
[19:59:02] openhabian@openHABianPi:~$ cat /var/lib/openhab2/config/org/openhab/mqtt.config
mqttson.clientId="openHAB2"
mqttson.url="tcp://127.0.0.1:1883"
service.pid="org.openhab.mqtt"
So.. does it work?
I feel like both of you should take a step back. For example in your posting the Client Id = OH2MQTT - Do you know what this means? Your setting doesn’t make much sense, you should just leave it with the default setting. Next your Topic setting. Why sonoff1? Give it a meaningful name, something you can work with (e.g. “sonoff-coridorlight”, not too long, no underscore).
Your config looks okay. You can again leave the client Id setting commented to have a random one generated. I take it your broker doesn’t provide authentication? If you’ve installed via openHABian setting up a password was offered.
After you’ve set up everything do a test. You could for example restart openHAB, then wait a few minutes and check the log for mqtt related messages. It should look similar to this one:
[21:22:34] openhabian@openHABianPiW66a:~$ grep "mqtt" /var/log/openhab2/*
/var/log/openhab2/openhab.log:2017-07-22 16:52:19.891 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
/var/log/openhab2/openhab.log:2017-07-22 16:52:19.893 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
/var/log/openhab2/openhab.log:2017-07-22 17:13:40.344 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
/var/log/openhab2/openhab.log:2017-07-22 17:15:24.084 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
/var/log/openhab2/openhab.log:2017-07-22 17:15:24.089 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
sadly it doesn’t
Client id - it’s the id i’m connecting to the broker?
which part of the (mqtt.cfg?) setting doesn’t make sense?
why sonoff1? because for now i have two sonoff devices and this is the one i’m testing with (i’m not sure where the device will be installed later, so a meaningful name would be hard to find)
[quote=“ThomDietrich, post:43, topic:31993”]
[/quote]didn’t set auth.
reboot:
2017-07-22 23:28:41.980 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:146)[197:org.openhab.io.transport.mqtt:1.10.0]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:65)[197:org.openhab.io.transport.mqtt:1.10.0]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:107)[197:org.openhab.io.transport.mqtt:1.10.0]
2017-07-22 23:28:41.998 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mqttson' was lost: Connection lost : ReasonCode 32109 : Cause : null
2017-07-22 23:28:41.999 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mqttson'
2017-07-22 23:28:52.002 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttson'
2017-07-22 23:28:55.288 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-22 23:28:55.289 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mqttson'
2017-07-22 23:30:04.375 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-07-22 23:30:04.387 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttson'
2 mqtt broker configs… did you clear /var/lib/openhab2/config/org/openhab/mqtt.config ?
Since when is this really needed? I personally never had to mess around in these files…
followed these steps (again), same result:
2017-07-23 09:11:55.159 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:79)[197:org.openhab.io.transport.mqtt:1.10.0]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650)[197:org.openhab.io.transport.mqtt:1.10.0]
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:70)[197:org.openhab.io.transport.mqtt:1.10.0]
2017-07-23 09:12:13.307 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-23 09:12:13.308 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mqttson'
2017-07-23 09:13:21.659 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-07-23 09:13:21.664 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttson'
‘broker’ is stopping, but it never starts…?
[09:18:39] openhabian@openHABianPi:~$ grep "'broker'" /var/log/openhab2/openhab.log
2017-07-21 22:56:56.786 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-21 23:02:55.915 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-22 09:01:43.367 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-22 12:30:50.985 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-22 20:03:20.494 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-23 09:09:37.596 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
I have never seen this before…
question: do you have the MQTT Action addon installed?
check something please within the openHAB console (post the output):
config:list "(service.pid=org.openhab.mqtt)"
config:list |grep -i broker
You can also increase the log levels to see if something more interesting comes up:
log:set TRACE org.openhab.binding.mqtt
log:set TRACE org.openhab.io.transport.mqtt
yes. just uninstalled it, but log doesn’t change.
[quote]check something please within the openHAB console (post the output):
```[/quote]
```php
openhab> config:list "(service.pid=org.openhab.mqtt)"
Pid: org.openhab.mqtt
BundleLocation: mvn:org.openhab.io/org.openhab.io.transport.mqtt/1.10.0
Properties:
mqttson.clientId = openHAB2
mqttson.url = tcp://127.0.0.1:1883
service.pid = org.openhab.mqtt
openhab> config:list |grep -i broker
openhab>
done
restart OH2 after uninstalling the action addon.
There is a logged bug about this (the action addon does not allow the mqtt binding to connect)
this doesn’t explain the 2nd connection… and I don’t see anything wrong in your console output… still a mystery where this 2nd connection is coming from…
log was the same after reboot.
now reboot with TRACE log:
2017-07-23 09:35:43.476 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
2017-07-23 09:35:43.490 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mqttson' was lost: Connection lost : ReasonCode 32109 : Cause : null
2017-07-23 09:35:43.492 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mqttson'
2017-07-23 09:35:53.498 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttson'
2017-07-23 09:35:56.595 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent UNREGISTERING - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding mqtt.genericbindingprovider, component.id=178, service.id=314, service.bundleid=193, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 09:35:56.597 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent UNREGISTERING - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=180, service.id=315, service.bundleid=193, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 09:35:56.604 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent UNREGISTERING - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=179, service.id=317, service.bundleid=193, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 09:35:56.609 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STOPPING - org.openhab.binding.mqtt
2017-07-23 09:35:56.610 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been stopped.
2017-07-23 09:35:56.611 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STOPPED - org.openhab.binding.mqtt
2017-07-23 09:35:56.632 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent UNREGISTERING - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=192, service.id=313, service.bundleid=197, service.scope=bundle} - org.openhab.io.transport.mqtt
2017-07-23 09:35:56.634 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Stopping MQTT Service...
2017-07-23 09:35:56.635 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-23 09:35:56.635 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Closing connection to broker 'broker'
2017-07-23 09:35:56.636 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'mqttson'
2017-07-23 09:35:56.636 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Closing connection to broker 'mqttson'
2017-07-23 09:35:56.637 [DEBUG] [penhab.io.transport.mqtt.MqttService] - MQTT Service stopped.
2017-07-23 09:35:56.639 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STOPPING - org.openhab.io.transport.mqtt
2017-07-23 09:35:56.641 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STOPPED - org.openhab.io.transport.mqtt
2017-07-23 09:37:04.318 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTING - org.openhab.binding.mqtt
2017-07-23 09:37:04.332 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been started.
2017-07-23 09:37:04.334 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTED - org.openhab.binding.mqtt
2017-07-23 09:37:05.318 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTING - org.openhab.io.transport.mqtt
2017-07-23 09:37:05.350 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Starting MQTT Service...
2017-07-23 09:37:05.380 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=180, service.id=315, service.bundleid=193, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 09:37:05.386 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.genericbindingprovider, component.id=178, service.id=314, service.bundleid=193, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 09:37:05.412 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Sonoff_TH16A' : 1 subscribers, 1 publishers
2017-07-23 09:37:05.458 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Sonoff_TH16A_RSSI' : 1 subscribers, 0 publishers
2017-07-23 09:37:05.466 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Sonoff_TH16A_Unreach' : 1 subscribers, 0 publishers
2017-07-23 09:37:05.486 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - MQTT: Activating event bus binding.
2017-07-23 09:37:05.492 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=179, service.id=317, service.bundleid=193, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 09:37:05.506 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent REGISTERED - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=192, service.id=313, service.bundleid=197, service.scope=bundle} - org.openhab.io.transport.mqtt
2017-07-23 09:37:05.510 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTED - org.openhab.io.transport.mqtt
2017-07-23 09:37:05.524 [TRACE] [ng.mqtt.internal.MqttEventBusBinding] - No mqtt-eventbus properties configured.
2017-07-23 09:37:05.530 [TRACE] [penhab.io.transport.mqtt.MqttService] - Processing property: mqttson.clientId = openHAB2
2017-07-23 09:37:05.531 [TRACE] [penhab.io.transport.mqtt.MqttService] - Processing property: mqttson.url = tcp://127.0.0.1:1883
2017-07-23 09:37:05.533 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-07-23 09:37:05.539 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - No url defined for MQTT broker connection 'broker'. Not starting.
2017-07-23 09:37:05.540 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttson'
2017-07-23 09:37:05.561 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'tcp://127.0.0.1:1883' using id 'openHAB2' and file store '/var/lib/openhab2/tmp/mqttson'
nuking is not an option. cost me a day last time to get it working again ![]()
so… no messages regarding Starting MQTT broker connection for the 2nd ‘broker’ config in the log? (only for the correct ‘mqttson’)?
..but… logged messages about Stopping broker connection for the 2nd ‘broker’ config…
while nothing shows up as trying to start a 2nd connection (and no configs can be found)… this 2nd connection is actually initiated from openHAB towards the broker that conflicts with the correct 1st one, not allowing the binding to establish a correct link… so nothing MQTT related works…
I am about to give up ![]()
Last try:
stop OH2
clear the contents of your /var/lib/openhab2/tmp/ & /var/lib/openhab2/cache/ dirs
start OH2
rm -ir /var/lib/openhab2/tmp/*
rm -ir /var/lib/openhab2/cache/*
Ps: Is there a /var/lib/openhab2/tmp/broker dir in there?
except this one:
no:
[09:53:44] root@openHABianPi:/var/lib/openhab2/tmp# ls -l
total 48
drwxrwxr-x+ 2 openhab openhabian 4096 Jun 30 20:34 bundles
drwxrwxr-x+ 2 openhab openhab 4096 Jul 14 13:17 fileinstall-2615193637295698452
drwxrwxr-x+ 2 openhab openhab 4096 Jul 14 13:17 fileinstall--4291590336138452965
drwxrwxr-x+ 2 openhab openhab 4096 Jul 13 13:44 fileinstall--610255515732200476
drwxrwxr-x+ 2 openhab openhabian 4096 Jun 30 22:45 fileinstall-9003287045152143424
-rw-rw-r-- 1 openhab openhabian 3 Jul 23 09:36 karaf.pid
drwxrwxr-x+ 2 openhab openhabian 4096 Jul 23 09:37 libNRJavaSerial_HF_openhab_0
-rw-rw-r-- 1 openhab openhabian 0 Jun 30 20:34 lock
drwxrwxr-x+ 2 openhab openhab 4096 Jul 20 22:47 mqtt1
drwxrwxr-x+ 2 openhab openhabian 4096 Jul 20 22:53 mqtt_service
drwxrwxr-x+ 2 openhab openhab 4096 Jul 23 09:53 mqttson
drwxrwxr-x+ 3 openhab openhabian 4096 Jun 30 20:36 mvn
-rw-rw-r-- 1 openhab openhabian 5 Jul 23 09:36 port
omg - how many times do i have to confirm the remove command???
I gave you the safe option…
there is always the dangerous option (not interactive… but force remove)
rm -rf /var/lib/openhab2/tmp/*
rm -rf /var/lib/openhab2/cache/*
where in HELL is this config stored??? I can’t understand where this is coming from…
Is there any other kind of config file that holds such info (about a broker) in your /etc/openhab2/ subfolders?
cd /etc/openhab2/services/
grep broker *
check also the other subfolders
another trick would be to set the url configuration property manually for this broker guy:
config:property-set -p org.openhab.mqtt broker.url tcp://192.168.0.1:1883
or try
config:property-delete -p org.openhab.mqtt broker.url
(basically, set a fake url for this guy so he doesn’t cause errors)
but this doesn’t make sense since this config property didn’t show up when you did config:list
alright, removed everything in those to folders and rebooted:
2017-07-23 10:04:01.099 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent INSTALLED - org.openhab.binding.mqtt
2017-07-23 10:04:01.546 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent INSTALLED - org.openhab.io.transport.mqtt
2017-07-23 10:04:06.346 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent RESOLVED - org.openhab.io.transport.mqtt
2017-07-23 10:04:06.352 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent RESOLVED - org.openhab.binding.mqtt
2017-07-23 10:04:06.888 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent [unknown:512] - org.openhab.io.transport.mqtt
2017-07-23 10:04:07.273 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTING - org.openhab.io.transport.mqtt
2017-07-23 10:04:07.284 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTED - org.openhab.io.transport.mqtt
2017-07-23 10:04:07.295 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Starting MQTT Service...
2017-07-23 10:04:07.307 [TRACE] [penhab.io.transport.mqtt.MqttService] - Processing property: mqttson.clientId = openHAB2
2017-07-23 10:04:07.309 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent REGISTERED - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=151, service.id=281, service.bundleid=199, service.scope=bundle} - org.openhab.io.transport.mqtt
2017-07-23 10:04:07.319 [TRACE] [penhab.io.transport.mqtt.MqttService] - Processing property: mqttson.url = tcp://127.0.0.1:1883
2017-07-23 10:04:07.320 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-07-23 10:04:07.322 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttson'
2017-07-23 10:04:07.355 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'tcp://127.0.0.1:1883' using id 'openHAB2' and file store '/var/lib/openhab2/tmp/mqttson'
2017-07-23 10:04:13.229 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTING - org.openhab.binding.mqtt
2017-07-23 10:04:13.233 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been started.
2017-07-23 10:04:17.337 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Sonoff_TH16A' : 1 subscribers, 1 publishers
2017-07-23 10:04:17.358 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Sonoff_TH16A_RSSI' : 1 subscribers, 0 publishers
2017-07-23 10:04:17.362 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'Sonoff_TH16A_Unreach' : 1 subscribers, 0 publishers
2017-07-23 10:04:17.364 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.genericbindingprovider, component.id=177, service.id=305, service.bundleid=194, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 10:04:17.392 [DEBUG] [ng.mqtt.internal.MqttEventBusBinding] - MQTT: Activating event bus binding.
2017-07-23 10:04:17.397 [TRACE] [ng.mqtt.internal.MqttEventBusBinding] - No mqtt-eventbus properties configured.
2017-07-23 10:04:17.400 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.mqtt-eventbus, component.name=org.openhab.binding.mqtt.eventbus, component.id=178, service.id=307, service.bundleid=194, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 10:04:17.412 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=179, service.id=308, service.bundleid=194, service.scope=bundle} - org.openhab.binding.mqtt
2017-07-23 10:04:17.414 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTED - org.openhab.binding.mqtt
I have never seen a config about a binding being stored in these 2 folders (cache & tmp)…
this would be the first if the error goes away after clearing them…
nothing with ‘broker’ since reboot:
[10:15:58] openhabian@openHABianPi:/etc/openhab2$ grep "'broker'" /var/log/openhab2/openhab.log
2017-07-23 09:22:38.028 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-23 09:30:01.406 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-23 09:53:19.499 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-07-23 09:53:19.500 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Closing connection to broker 'broker'
