MQTT connection lost
nothing configured in mqtt-eventbus.cfg
[09:16:42] openhabian@openHABianPi:~$ lsof -i :1883
-bash: lsof: command not found
openHAB2 switch still not working (reading/writing).
apt-get install lsof
try the following:
0) switch to root (sudo su)
  1. stop the OH2 service (systemctl stop openhab2)
  2. move the mqtt.config file to another destination: mv /var/lib/openhab2/config/org/openhab/mqtt.config /root/)
  3. make sure that /etc/openhab2/services/mqtt.cfg is correctly configured
  4. start the OH2 service (systemctl start openhab2)
  5. check logs (openhab & mosquitto)
this points to the direction that this is an auto-generated clientId (using the processId and the hostname)
I am not sure if it’s coming from the openHAB2 mqtt binding connection… maybe it is (looks like it)
Something seems to be sending an empty clientId on a second connection…
I found the following info:
Yes…
It should be ( | ) due to CVE-2017-7650. Since Mosquitto 1.4.12, clients are not allowed to have a ‘#’, ‘+’, or ‘/’ in their username or client id.
Info:
i) Redirecting...
ii) regression because of CVE-2017-7650: clientid with / character · Issue #462 · eclipse-mosquitto/mosquitto · GitHub
iii) mosquitto/client/client_shared.c at master · eclipse-mosquitto/mosquitto · GitHub
cat /var/log/openhab2/openhab.log | grep mqtt
2017-07-22 12:32:45.726 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-07-22 12:32:45.732 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqttson'
1500717721: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1500719450: Client openHAB2 disconnected.
1500719522: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1500719565: New connection from 127.0.0.1 on port 1883.
hello all,
I made the changes of duplicated clientid, etc…
checked the netstat and now I have only one connection:
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:1883 127.0.0.1:38744 ESTABLISHED
tcp 0 0 10.0.0.101:1883 10.0.0.104:13727 ESTABLISHED
tcp6 0 0 127.0.0.1:38744 127.0.0.1:1883 ESTABLISHED
the mqtt.config (after the change):
raspberrypi.clientId=“openHAB2”
raspberrypi.pwd=“password”
raspberrypi.url=“tcp://127.0.0.1:1883”
raspberrypi.user=“openhabian”
service.pid=“org.openhab.mqtt”
the Mosquitto,log
1500718948: mosquitto version 1.4.14 (build date Mon, 10 Jul 2017 23:48:43 +010$
1500718948: Config loaded from /etc/mosquitto/mosquitto.conf.
1500718948: Opening ipv4 listen socket on port 1883.
1500718956: New connection from 10.0.0.104 on port 1883.
1500718956: New client connected from 10.0.0.104 as DVES_A7F83D (c1, k15, u’ope$
1500719029: New connection from 127.0.0.1 on port 1883.
1500719029: New client connected from 127.0.0.1 as openHAB2 (c1, k60, u’openhab$
1500719556: New connection from 10.0.0.100 on port 1883.
(the last connection is from MQTT fx)
After that I tried to publish the command at MQTT.fx but no response:
2017-07-22 07:33:33,040 INFO — MqttFX ClientModel : attempt to add PublishTopic
2017-07-22 07:33:33,041 INFO — MqttFX ClientModel : sucessfully published message to topic cmnd/sonoff-abajur/POWER off (QoS 1, Retained false)
so… did the mosqsub|1730-openHABian dissapear?
no response from what? (OH2 or the Sonoff?)
post your item config to check it
yes! (for now?)
EDIT: NO!
1500719565: New client connected from 127.0.0.1 as openHAB2 (c1, k60).
1500720088: New connection from 127.0.0.1 on port 1883.
1500720088: New client connected from 127.0.0.1 as mosqsub|7105-openHABian (c1, k60).
1500720244: New connection from 192.168.178.160 on port 1883.
still no communication with openHAB2 ?
[12:34:38] openhabian@openHABianPi:~$ mosquitto_sub -v -t 'tele/#' -t 'stat/#'
tele/sonoff/LWT Online
stat/sonoff/RESULT {"POWER":"OFF"}
stat/sonoff/POWER OFF
tele/sonoff/STATE {"Time":"2017-07-22T11:43:00", "Uptime":3, "Vcc":3.204, "POWER":"OFF", "Wifi":{"AP":1, "SSID":"NETGEAR47", "RSSI":32, "APMac":"80:2A:A8:4A:C7:AC"}}
thoughts: if the TOPIC is “sonoff1”, my item should be:
Switch Sonoff_TH16A "Sonoff Test" <light>
    { mqtt=">[broker:cmnd/sonoff1/POWER:command:*:default],
            <[broker:stat/sonoff1/POWER:state:default]" }
right?
'til now i have used the client id of the sonoff device…
changing (correcting) the item doesn’t help, still no signs in openhab.log…
[quote=“Dim, post:28, topic:31993”]
[/quote] no response from Sonoff. I don’t know how to see if could be any chance on OH2. But the log is below:
2017-07-22 07:23:49.078 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2017-07-22 07:23:49.083 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘raspberrypi’
2017-07-22 07:23:49.619 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-07-22 07:23:49.921 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-07-22 07:23:50.023 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
2017-07-22 07:23:50.026 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
the sonoff.item:
Switch Abajur_light “Abajur” (LR, gLight)
{ mqtt=“>[raspberrypi:cmnd/sonoff-abajur/POWER:command:ON:on], >[raspberrypi:cmnd/sonoff-abajur/POWER:command:OFF:off],
<[raspberrypi:stat/sonoff-abajur/POWER:state:default]” }
When I tried to move the switch at OH2, I got the following message:
2017-07-22 07:56:06.192 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2017-07-22 07:56:06.207 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘Abajur’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-07-22 07:56:06.211 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘Abajur’ for widget org.eclipse.smarthome.model.sitemap.Switch
2017-07-22 07:56:06.215 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2017-07-22 07:56:06.244 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - Exception while formatting value ‘93.25861’ of item LivingRoom_Light_RSSI with format ‘%d %%’: java.util.IllegalFormatConversionException: d != java.math.BigDecimal
:frowning:
anything useful with lsof -i :1883 ?
or ps -efwww |grep 7105 (that seems to be the process id)
checking your item now…
for starters, change broker to mqttson :slight_smile:
edit: check examples from here:
it should be something like:
Switch Sonoff_TH16A "Sonoff Test" <light> { mqtt=">[mqttson:cmnd/sonoff/power:command:*:default], <[mqttson:stat/sonoff1/power:state:default]" }
Hello, jumping in here because of the mentioning before.
Pay attention to the first topic level: cmnd vs. stat - that’s something I personally don’t like about the Tasmota default settings. This order can btw be changed in settings.
The config is in sync with what I’ve given as a template here.
Sooo from what I’ve read we are looking at two problems here. Why is there an additional connection with the clientID mosqsub|1234-openHABian and why is your openHAB not able to receive states and send commands.
  1. The additional connection is not present on my system
  2. @narf27 looking at this posting your setup is simply wrong. The topic name of your module is “sonoff”, you are subscribing to “sonoff1”. Change the topic of your module before adding it to openHAB! Also just as @Dim said, you need to use the right broker name. Please check your setup against this article: GitHub - arendst/Tasmota: Alternative firmware for ESP8266 and ESP32 based devices with easy configuration using webUI, OTA updates, automation using timers or rules, expandability and entirely local control over MQTT, HTTP, Serial or KNX. Full documentation at
this is driving me crazy :slight_smile:
anyway this thread is a mess with 2 different setups that we are trying to debug :stuck_out_tongue:
edit: You are right.. I didn’t see the first topic level :slight_smile:
Example setup Click to see fill image
→ Added to the Tasmota wiki
And the corresponding items configuration:
Switch BK_Balkonmagic "Balkonmagic" <stars> (BK,gLight)                           {mqtt=">[broker:tasmota/sonoff-A00EEA/cmnd/POWER:command:*:default], <[broker:tasmota/sonoff-A00EEA/stat/POWER:state:default]"}
Number BK_Balkonmagic_RSSI "Balkonmagic RSSI [%d %%]" (gRSSI)                     {mqtt="<[broker:tasmota/sonoff-A00EEA/tele/STATE:state:JSONPATH($.Wifi.RSSI)]"}
Switch BK_Balkonmagic_Unreach "Balkonmagic unreachable" <siren> (gUnreach)        {mqtt="<[broker:tasmota/sonoff-A00EEA/tele/LWT:state:MAP(unreach.map)]"}
@ThomDietrich , mine is quite the same. How is your Topic/ Full topic configuration??
Click the image :slight_smile:
@ThomDietrich thank you! Mine configuration is the same!!! :slight_smile:
@paulo9999 : you have some errors in your sitemap file
your item is defined as Abajur_light but your sitemap is complaining about an item named Abajur
post your items and sitemap contents to be checked :slight_smile:
@Dim:
thank you, sorry for this slight mistake, I’ve corrected it, now sitemap is ok but unfortunately things still isn’t working…
Paulo
