org.eclipse.paho.client.mqttv3.MqttException: Unable to connect to server
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:79) [209:org.openhab.io.transport.mqtt:1.12.0]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650) [209:org.openhab.io.transport.mqtt:1.12.0]
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:589) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:70) ~[?:?]
... 2 more
So i’m starting it with “mosquitto -d”, is this correct?
Mosquitto is installed through openhabian-config
BTW why do you need the mqtt ACTION binding for turning on and off a switch? I dont use that binding and have nearly a dozen esp’s working with OH via mqtt.
I may be wrong but I think the question was ask to see if you had it installed, if so then, uninstall it. The action binding has (or had?) a history of interfering with the mqtt binding. So unless you need it, uninstall both mqtt bindings, clean your cache and reinstall the mqtt binding only.
