Hi
I have one problem when i connect the sketch to network
my topology is the next
arduino 1+ ethenet sheld : 192.168.1.75
raspberry : 192.168.1.67
mosquitto
1474658886: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting
1474658886: Using default config.
1474658886: Opening ipv4 listen socket on port 1883.
1474658886: Error: Address already in use
openhab
14:50:21.826 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler ‘openHAB-job-scheduler’ initialized from specified file: ‘/etc/openhab/quartz.properties’
14:50:21.828 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
14:50:21.831 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
14:50:21.843 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file ‘/usr/share/openhab/configurations/openhab_default.cfg’.
14:50:21.847 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file ‘/etc/openhab/configurations/openhab.cfg’.
14:50:22.049 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at ‘/usr/share/openhab/webapps/static/uuid’ with content ‘59fbe0a3-e726-42d9-baba-8fbe9fc28f3d’
14:50:22.054 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file ‘/usr/share/openhab/webapps/static/version’ with content ‘1.8.3’
14:50:22.057 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.3).
14:50:22.319 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
14:50:26.346 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered ‘persistence’ configuration parser
14:50:26.393 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
14:50:26.481 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
14:50:26.531 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
14:50:26.544 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
14:50:26.574 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service…
14:50:26.727 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:53 ] - Service Discovery initialization completed.
14:50:26.738 [INFO ] [.io.transport.mqtt.MqttService:108 ] - MQTT Service initialization completed.
14:50:26.739 [INFO ] [o.i.t.m.i.MqttBrokerConnection:114 ] - Starting MQTT broker connection ‘mymosquitto’
14:50:26.747 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:294 ] - Creating new client for ‘tcp://192.168.1.67:1883’ using id ‘openhab_123’ and file store ‘/tmp/mymosquitto’
14:50:45.950 [INFO ] [.o.io.habmin.HABminApplication:182 ] - Started HABmin REST API at /services/habmin
14:50:45.951 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server._tcp.local. at port 8080
14:50:48.699 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server-ssl._tcp.local. at port 8443
14:50:51.377 [DEBUG] [.a.mqtt.internal.MqttActivator:34 ] - Mqtt action has been started.
14:50:51.400 [DEBUG] [.zwave.internal.ZWaveActivator:36 ] - Z-Wave binding started. Version 1.8.0.201508211938
14:50:51.454 [DEBUG] [.z.internal.ZWaveActiveBinding:175 ] - ConverterHandler not initialised. Polling disabled.
14:50:51.457 [INFO ] [.z.internal.ZWaveActiveBinding:317 ] - ZWave ‘updated’ with null config
14:50:51.463 [DEBUG] [.b.mqtt.internal.MqttActivator:34 ] - MQTT binding has been started.
14:50:51.494 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Temp (Type=NumberItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
14:50:51.502 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ] - Loaded MQTT config for item ‘Temp’ : 1 subscribers, 0 publishers
14:50:51.505 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ] - Starting message consumer for broker ‘mymosquitto’ on topic ‘home/temperature’
14:50:51.517 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Hum (Type=NumberItem, State=Uninitialized)’ with ‘MqttGenericBindingProvider’ reader.
14:50:51.519 [DEBUG] [b.mqtt.internal.MqttItemConfig:72 ] - Loaded MQTT config for item ‘Hum’ : 1 subscribers, 0 publishers
14:50:51.521 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ] - Starting message consumer for broker ‘mymosquitto’ on topic ‘home/humedad’
14:50:51.537 [DEBUG] [m.internal.MqttEventBusBinding:68 ] - MQTT: Activating event bus binding.
14:50:51.560 [DEBUG] [o.p.m.i.MqttPersistenceService:100 ] - Deactivating MQTT Persistence
14:50:51.563 [WARN ] [o.p.m.i.MqttPersistenceService:123 ] - mqtt-persistence:broker
14:50:51.565 [WARN ] [o.p.m.i.MqttPersistenceService:123 ] - mqtt-persistence:topic
14:50:51.566 [WARN ] [o.p.m.i.MqttPersistenceService:123 ] - mqtt-persistence:message
14:50:51.569 [DEBUG] [o.p.m.i.MqttPersistenceService:81 ] - Configuration updated for MQTT Persistence.
14:50:51.571 [DEBUG] [o.p.m.i.MqttPersistenceService:84 ] - Configuration incomplete. Cannot start yet.
14:50:51.581 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing mqtt persistence service.
14:50:51.589 [DEBUG] [c.internal.ModelRepositoryImpl:64 ] - Configuration model ‘mqtt.persist’ can not be found
14:50:51.594 [DEBUG] [.m.internal.MqttitudeActivator:33 ] - Mqttitude binding has been started.
14:50:51.627 [DEBUG] [.b.m.internal.MqttitudeBinding:84 ] - Activating Mqttitude binding
Configuration for openhab.cfg and mqtt
mqtt:mymosquitto.url=tcp://192.168.1.67:1883
mqtt:mymosquitto.clientId=openhab_123
When the openhab service is started , it create one directory with the clientid of mosquitto
drwxr-xr-x 2 openhab openhab 4096 Sep 23 14:50 openhab_123-tcp1921681671883
pi@raspberrypi:/tmp/mymosquitto $
but when i connect the arduino to network . appear the problem : <>
and this directory is removed
pi@raspberrypi:/tmp/mymosquitto $ ls -l
total 0
15:01:07.484 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ] - Starting message consumer for broker ‘mymosquitto’ on topic ‘home/temperature’
15:01:07.487 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ] - Starting message consumer for broker ‘mymosquitto’ on topic ‘home/humedad’
15:01:08.029 [ERROR] [o.i.t.m.i.MqttBrokerConnection:536 ] - MQTT connection to broker was lost
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:138) [mqtt-client-0.4.0.jar:na]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_65]
Caused by: java.io.EOFException: null
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[na:1.8.0_65]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:56) ~[na:na]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:100) [mqtt-client-0.4.0.jar:na]
… 1 common frames omitted
15:01:08.030 [ERROR] [o.i.t.m.i.MqttBrokerConnection:540 ] - MQTT connection to ‘mymosquitto’ was lost: Connection lost : ReasonCode 32109 : Cause : null
15:01:08.032 [INFO ] [o.i.t.m.i.MqttBrokerConnection:547 ] - Starting connection helper to periodically try restore connection to broker ‘mymosquitto’
Any idea where is the problem..
Best regards!!!
