Dear all,
i have an existing pi4 setup that i did transfer to my new pi5 yesterday. mostly all works fine, after some minor fixing. except that i see this strange behaviour now about my MQTT connections. they come and go every few seconds.
I did completely backup-restore and i’m using config files, so its a 100% clone of MQTT config.
Also strange/in line the fact that it happens to external HiveMQ and my local Mosquitto instance…so its something about the binding/config of it.
Many Thanks for your help,
Norbert
2024-03-29 06:14:30.909 [INFO ] [rg.openhab.core.model.script.VenusGX] - MQTT Keep Alive Trigger
2024-03-29 06:14:40.384 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'broker.hivemq.com'. Next attempt in 60000ms
2024-03-29 06:14:40.384 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'broker.hivemq.com' with clientid a0b082d5eb75706969
2024-03-29 06:14:42.071 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.11'. Next attempt in 60000ms
2024-03-29 06:14:42.071 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.11' with clientid openhab99
2024-03-29 06:14:43.731 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.95'. Next attempt in 60000ms
2024-03-29 06:14:43.731 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.95' with clientid openhab
2024-03-29 06:14:54.049 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2024-03-29 06:15:00.482 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'broker.hivemq.com'. Next attempt in 60000ms
2024-03-29 06:15:00.482 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'broker.hivemq.com' with clientid a0b082d5eb75706969
2024-03-29 06:15:00.909 [WARN ] [ing.mqtt.internal.action.MQTTActions] - MQTT publish to R/0c1c57111e38/system/0/Serial failed!
2024-03-29 06:15:00.909 [INFO ] [rg.openhab.core.model.script.VenusGX] - MQTT Keep Alive Trigger
2024-03-29 06:15:02.076 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.11'. Next attempt in 60000ms
2024-03-29 06:15:02.077 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.11' with clientid openhab99
2024-03-29 06:15:03.742 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.95'. Next attempt in 60000ms
2024-03-29 06:15:03.743 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.95' with clientid openhab
2024-03-29 06:15:04.327 [WARN ] [ui.basic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
2024-03-29 06:15:20.588 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'broker.hivemq.com'. Next attempt in 60000ms
2024-03-29 06:15:20.589 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'broker.hivemq.com' with clientid a0b082d5eb75706969
2024-03-29 06:15:22.082 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.11'. Next attempt in 60000ms
2024-03-29 06:15:22.082 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.11' with clientid openhab99
2024-03-29 06:15:23.758 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.95'. Next attempt in 60000ms
2024-03-29 06:15:23.758 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.95' with clientid openhab
