- Platform information:
- Hardware: Docker container on Synology
- openHAB version:3.3.0
I have a Raspberry pi with a temperure bricklet from Tinkerforge connected via USB.
I can send a mqtt string value ( {“temperature”: 2702} ) from the PI to the Synology mqtt brocker and to the generic mqtt OH3 binding.
Added a channel and linked it and add a JSONPath expression $.temperature to see only the 2702 value instead of {“temperature”: 2702}.
As you can see in the example i get the value 2702.
I would like to see 27,02 °C instead.
I tried to add %.2f °C in the state formatter without success.
I get {“temperature”: 2702} as a result…
What state formatter expression do i have to use to see 27,02 °C ?
Patrick
