MQTT Homie: trigger channel silent after reboot
I’ve set up MQTT 2.4 bindings with Homie and an ESP8266 which has a single button to control some lights. I’ve linked the button to a switch item using the rawbutton-toggle-switch profile (via Paper UI). The first problem I experienced is that a single press triggered multiple events (which makes my lights go crazy):
2019-01-09 19:22:23.580 [vent.ChannelTriggeredEvent] - mqtt:homie300:f4feb5ec:b361d0:button#button triggered PRESSED
2019-01-09 19:22:23.585 [vent.ChannelTriggeredEvent] - mqtt:homie300:f4feb5ec:b361d0:button#button triggered PRESSED
2019-01-09 19:22:23.588 [vent.ChannelTriggeredEvent] - mqtt:homie300:f4feb5ec:b361d0:button#button triggered PRESSED
2019-01-09 19:22:23.592 [vent.ChannelTriggeredEvent] - mqtt:homie300:f4feb5ec:b361d0:button#button triggered PRESSED
2019-01-09 19:22:23.780 [vent.ChannelTriggeredEvent] - mqtt:homie300:f4feb5ec:b361d0:button#button triggered RELEASED
2019-01-09 19:22:23.784 [vent.ChannelTriggeredEvent] - mqtt:homie300:f4feb5ec:b361d0:button#button triggered RELEASED
When I subscribe to the channel via Mosquitto I only observe a single message (so ESP and transmission seem to work fine). I thought a restart of OpenHab may help. However, now I don’t see any such messages in the log and the item does not toggle. I can still see the messages in Mosquitto and also the device status is updated in OpenHab
2019-01-09 20:33:14.874 [hingStatusInfoChangedEvent] - 'mqtt:homie300:f4feb5ec:b361d0' changed from ONLINE (CONFIGURATION_PENDING) to ONLINE
QoS is at least once, which might explain the first problem but not the recent problem. Any ideas?
I think a rawbutton produces events as long as it is clicked.
Does it work without the profile?
What firmware do you use?
Is that button debounced?
As far as I understand a link always has a profile and in case of a button (channel itself is correctly auto-discovered as trigger channel of type system.rawbutton as documented https://www.openhab.org/addons/bindings/mqtt.generic/) the only profile Paper UI let’s me select is Raw Button Toggle. The docs explicitly mention the switching lights example as a use case for that profile.
I use Homie for ESP8266 (Homie v3 patch). Essentially I follow this: https://github.com/bodiroga/homie-esp8266/blob/develop-v3/examples/SingleButton/SingleButton.ino
No, but it’s not the issue as I can confirm by mqtt logs (i pressed the button twice):
$ mosquitto_sub -t '#' -F '@Y-@m-@dT@H:@M:@S@z \e[92m%t \e[96m%p\e[0m' -q 2
2019-01-10T22:01:30+0100 homie/b361d0/button/button PRESSED
2019-01-10T22:01:31+0100 homie/b361d0/button/button RELEASED
2019-01-10T22:01:35+0100 homie/b361d0/button/button PRESSED
2019-01-10T22:01:35+0100 homie/b361d0/button/button RELEASED
Might still be a good idea to add debounce, though.
Removing and recreating the Thing entirely solves the problem. Now, I have exactly one message per button press. But only until the next reboot. A reboot seems to consistently break the setup. Do I need to save something explicitly?
No. There seem to be a bug hidden somewhere. But without knowing your setup it’s hard to replicate.
I think the two issues (no toggle and too many toggles) are related. I can also reproduce the latter. Every time a Homie device goes offline and online again I get an additional log of a press (see above). I suspect that multiple handler run in parallel. And on boot no handler is started.
My setup is OpenHab 2.4.0 on Openhabian (Pi). I’ve created a single switch item and linked the button channel to the item. I’ve noticed in the logs, that on boot all links are recreated (not only mqtt):
2019-01-10 22:59:10.713 [temChannelLinkRemovedEvent] - Link 'Light => mqtt:homie300:f4feb5ec:b361d0:light#on' has been removed.
2019-01-10 22:59:10.716 [temChannelLinkRemovedEvent] - Link 'Light => mqtt:homie300:f4feb5ec:b361d0:button#button' has been removed.
2019-01-10 22:59:10.734 [temChannelLinkRemovedEvent] - Link 'Light => zwave:device:707546a4:node98:switch_binary' has been removed.
2019-01-10 22:59:10.740 [temChannelLinkRemovedEvent] - Link 'Light => mqtt:homie300:66080c3d:button#button' has been removed.
2019-01-10 23:00:37.647 [.ItemChannelLinkAddedEvent] - Link 'Light-mqtt:homie300:f4feb5ec:b361d0:light#on' has been added.
2019-01-10 23:00:37.655 [.ItemChannelLinkAddedEvent] - Link 'Light-zwave:device:707546a4:node98:switch_binary' has been added.
2019-01-10 23:00:37.660 [.ItemChannelLinkAddedEvent] - Link 'Light-mqtt:homie300:f4feb5ec:b361d0:button#button' has been added.
2019-01-10 23:00:37.664 [.ItemChannelLinkAddedEvent] - Link 'Light-mqtt:homie300:66080c3d:button#button' has been added.
Is this on purpose? Is there any other data that might be helpful?
I also tried the embedded mqtt broker. Same behavior.
I’ve also just noticed missing Homie messages after restarting. There is an issue in SmartHome that sounds a lot like the same thing: [MQTT-Binding / Homie]: No communication possible with Homie-Thing after restart · Issue #6828 · eclipse-archived/smarthome · GitHub.
I have the exact same error and it has nothing to do with a button. I have a sensor which is constantly sending messages. When i add the thing, it is working. But if i restart openhab the connection is gone.
I figured it out, it is a bug in the mqtt implementation. It is already fixed. In the current Snapshot version it is already working.
A workaround that was working for me: If you delete all retained messages from the broker (e.g. with mqtt explorer), the devices start working again until the next restart.
