Hi everybody,
I wonder how I add all available Exposes via channels of my Xiaomi Honeywell Smoke Detector. The detector is connected via zigbee2mqtt and exposes its values like described here:
The values for smoke, battery_low, tamper, battery, smoke_density and linkquality were easy to add und straight foward. But how do i add sensitivity and selftest?
To read/write the sensitivity you need to add a payload: {“sensitivity”: “”}. Is there a possibility to do this via channel configuration or do I have to do this via rule? Any suggestions?
To execute the selftest i have to publish a message via mqtt. Do i make this within a rule or is there a better solution?
Bridge mqtt:broker:mosquitto [host="zigbee", secure=false]
Thing topic ogFSmokeDetectorTopic "ogFSmokeDetector" {
Channels:
// Works great
Type string : smokeDetected "Smoke Detected" [ stateTopic="zigbee2mqtt/0x00158d000543f53c", transformationPattern="JSONPATH:$.smoke" ]
Type string : batteryLow "Battery Low" [stateTopic="zigbee2mqtt/0x00158d000543f53c", transformationPattern="JSONPATH:$.battery_low" ]
Type string : tamper "Tamper" [stateTopic="zigbee2mqtt/0x00158d000543f53c", transformationPattern="JSONPATH:$.tamper" ]
Type number : battery "Battery" [stateTopic="zigbee2mqtt/0x00158d000543f53c", transformationPattern="JSONPATH:$.battery" ]
Type number : smokeDensity "Smoke Density" [stateTopic="zigbee2mqtt/0x00158d000543f53c", transformationPattern="JSONPATH:$.smoke_density" ]
Type number : linkQuality "Link Quality" [stateTopic="zigbee2mqtt/0x00158d000543f53c", transformationPattern="JSONPATH:$.linkquality" ]
// Does not work
Type string : sensitivity "Sensitivity" [stateTopic="zigbee2mqtt/0x00158d000543f53c/get", commandTopic="zigbee2mqtt/0x00158d000543f53c/set", formatBeforePublish="{\"sensitivity\": %s}", transformationPattern="JSONPATH:$.sensitivity", allowedStates="low, medium, high" ]
// Works great
Switch ogFSmokeDetectorSmokeDetected "OG F Smoke Detector Smoke Detected" <switch> { channel="mqtt:topic:mosquitto:ogFSmokeDetectorTopic:smokeDetected" [profile="transform:MAP", function="honeywell.map"]}
Switch ogFSmokeDetectorBatteryLow "OG F Smoke Detector Battery Low" <switch> { channel="mqtt:topic:mosquitto:ogFSmokeDetectorTopic:batteryLow" [profile="transform:MAP", function="honeywell.map"]}
Switch ogFSmokeDetectorTamper "OG F Smoke Detector Tamper" <switch> { channel="mqtt:topic:mosquitto:ogFSmokeDetectorTopic:tamper" [profile="transform:MAP", function="honeywell.map"]}
Number ogFSmokeDetectorBattery "OG F Smoke Detector Battery" { channel="mqtt:topic:mosquitto:ogFSmokeDetectorTopic:battery" }
Number ogFSmokeDetectorSmokeDensity "OG F Smoke Detector Smoke Density" { channel="mqtt:topic:mosquitto:ogFSmokeDetectorTopic:smokeDensity" }
Number ogFSmokeDetectorLinkQuality "OG F Smoke Detector Link Quality" { channel="mqtt:topic:mosquitto:ogFSmokeDetectorTopic:linkQuality" }
// Does not work
String ogFSmokeDetectorSensitivity "OG F Smoke Detector Sensitivity" { channel="mqtt:topic:mosquitto:ogFSmokeDetectorTopic::sensitivity" }
- Platform information:
- Hardware: Pi3
- OS: openHABian
- Java Runtime Environment: openjdk 15 2020-09-15
- openHAB version: openHAB 2.5.10-1 (Release Build)
