MQTT installed and working, but not accessible from openHAB
Hi there,
I´m new to openHAB and I´m stuck…
Openhabian installed on Raspi 2, Mosquitto and MQTT-addon installed.
MQTT works fine; I can send information to topics from another machine ( mosquitto_pub ) and receive (…_sub)
mqtt.cfg is just:
mqtt:broker.url=tcp://localhost:1883
mqtt:broker.clientId=openhab
mqtt:broker.retain=true
mqtt:broker.async=false
mosquitto.log shows no problems
in the items-folder I have a file called system.items:
Number Garten {mqtt=“<[broker:temp/garten:state:default]”}
I wonder in what place the information available in MQTT could be used/referred to from within openHAB.
Any help would be appreciated!
Horst
Not sure what the question is. Have you tried reviewing the wiki?
I had tried to work along the wiki but apparantly I had messed things up earlier.
So instead of trying to sort out things (could be impossible for a newbie) I did a fresh install and followed things to the letter.
I am not yet at the point of accessing MQTT, but I hope I got a better starting point now.
Thanks for the hint anyhow!
Horst
If using openHAB2, you would write
broker.url=
instead of
mqtt:broker.url=
