item file:
Number soffth1604_stan "Pompa mieszajaca" <selfsocket> { mqtt="<[mosquitto:soffth1604/RelayState/Stan:state:default]" }
Number soffth1604_temp "Temp. wody [%.1f]" <selftemperature> { mqtt="<[mosquitto:soffth1604/Temperatura/Temp:state:default]" }
Number soffth1604_rssi "Sygnal Wifi" <qualityofservice> { mqtt="<[mosquitto:soffth1604/SygnalWiFi/moc:state:default]" }
sitemap file:
... Frame label="somelabel" {
Default item=soffth1604_stan label="Pompa mieszajaca"
Default item=soffth1604_temp label="Temp. c.w.o"
Default item=soffth1604_rssi label="Sygnal WiFi"
Now problem - in BasicUI see temperature (soffth1604_temp), BUT I dont see soffth1604_rssi value or soffth1604_stan value (0 or 1).
I checked events.log:
ubuntu@oh2:~$ tail -f /var/log/openhab2/events.log
2017-12-10 20:41:43.853 [ItemStateChangedEvent ] - soffth1604_temp changed from 38.5 to 38.6
2017-12-10 20:44:05.172 [ItemStateChangedEvent ] - soffth1604_rssi changed from -50.00 to -51.00
I tried to change sitemap’s element from “Default” to “Text” for these problematic positions but it wont work.
What is wrong ? What I can not see ?
