Yes, both on the same Pi at 10.0.20.5
Not sure if it has updated itself. How?
Yes, restarted openhab; not sure how to restart mosquitto
One of the first things I checked; I get:
Jul 27 10:28:35 openhab systemd[1]: mosquitto.service: Service RestartSec=100ms expired, schedulin
Jul 27 10:28:35 openhab systemd[1]: mosquitto.service: Scheduled restart job, restart counter is a
Jul 27 10:28:35 openhab systemd[1]: Stopped Mosquitto MQTT v3.1/v3.1.1 Broker.
Jul 27 10:28:35 openhab systemd[1]: mosquitto.service: Start request repeated too quickly.
Jul 27 10:28:35 openhab systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Jul 27 10:28:35 openhab systemd[1]: Failed to start Mosquitto MQTT v3.1/v3.1.1 Broker.
Was working, not sure what happened for it to fail. Always proper shutdown.
sudo systemctl status mosquitto:
● mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset
Active: failed (Result: exit-code) since Mon 2020-07-27 10:28:35 MST; 2 days
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 935 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (c
Main PID: 935 (code=exited, status=1/FAILURE)
[15:18:37] openhabian@openhab:~$ sudo systemctl restart mosquitto
Job for mosquitto.service failed because the control process exited with error code.
See "systemctl status mosquitto.service" and "journalctl -xe" for details.
-- Logs begin at Thu 2019-02-14 03:11:59 MST, end at Wed 2020-07-29 15:25:02 MST. --
Jul 06 13:08:26 openhab systemd[1]: Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
-- Subject: A start job for unit mosquitto.service has begun execution
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit mosquitto.service has begun execution.
-- The job identifier is 1044.
Jul 06 13:08:26 openhab systemd[1]: Started Mosquitto MQTT v3.1/v3.1.1 Broker.
-- Subject: A start job for unit mosquitto.service has finished successfully
-- A start job for unit mosquitto.service has finished successfully.
Jul 06 13:08:39 openhab systemd[1]: Stopping Mosquitto MQTT v3.1/v3.1.1 Broker...
-- Subject: A stop job for unit mosquitto.service has begun execution
-- A stop job for unit mosquitto.service has begun execution.
lines 1-23...skipping...
-- The job identifier is 1109.
Jul 06 13:08:39 openhab systemd[1]: mosquitto.service: Succeeded.
-- Subject: Unit succeeded
-- The unit mosquitto.service has successfully entered the 'dead' state.
Jul 06 13:08:39 openhab systemd[1]: Stopped Mosquitto MQTT v3.1/v3.1.1 Broker.
-- Subject: A stop job for unit mosquitto.service has finished
-- A stop job for unit mosquitto.service has finished.
-- The job identifier is 1109 and the job result is done.
