I’ve made some tests…
THING
Thing mqtt:topic:mymqtt:sonoff-ABCDEFG "ElectroDragon Relay Board" (mqtt:broker:mymqtt) @ "MQTT" {
Channels:
Type switch : sw1 "Switch 1" [
stateTopic="tasmota/sonoff-ABCDEFG/stat/POWER1",
commandTopic="tasmota/sonoff-ABCDEFG/cmnd/POWER1",
on="ON",
off="OFF"
Type switch : sw2 "Switch 2" [
stateTopic="tasmota/sonoff-ABCDEFG/stat/POWER2",
commandTopic="tasmota/sonoff-ABCDEFG/cmnd/POWER2",
on="ON",
off="OFF"
Type switch : sw1_stat "Status Backup Switch 1" [
stateTopic="tasmota/sonoff-ABCDEFG/stat/STATUS11",
transformationPattern="JSONPATH:$.StatusSTS.POWER1",
on="ON",
off="OFF"
Type switch : sw2_stat "Status Backup Switch 2" [
transformationPattern="JSONPATH:$.StatusSTS.POWER2",
on="ON",
off="OFF"
Type string : version [
stateTopic="tasmota/sonoff-ABCDEFG/stat/STATUS2",
transformationPattern="JSONPATH:$.StatusFWR.Version"
ITEM
// Test Board ElectroDragon
Switch mqtt_sonoff_ABCDEFG_sw1 "ED Switch 1 []" <switch> { channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw1" }
Switch mqtt_sonoff_ABCDEFG_sw2 "ED Switch 2 []" <switch> { channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw2" }
Switch mqtt_sonoff_ABCDEFG_sw1_stat "ED Switch 1 []" <switch> { channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw1_stat" }
Switch mqtt_sonoff_ABCDEFG_sw2_stat "ED Switch 2 []" <switch> { channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw2_stat" }
RULE
rule "update tasmota EletroDragon DEMO"
Item mqtt_sonoff_ABCDEFG_sw1 changed or
Item mqtt_sonoff_ABCDEFG_sw2 changed
val actions = getActions("mqtt","mqtt:broker:mymqtt")
actions.publishMQTT("tasmota/sonoff-ABCDEFG/cmnd/STATUS","11")
LOG - Buttons pushed manually at the device.
2019-10-06 15:31:50.367 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw1 changed from OFF to ON
2019-10-06 15:31:50.415 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw1_stat changed from OFF to ON
2019-10-06 15:31:51.815 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw2 changed from OFF to ON
2019-10-06 15:31:51.878 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw2_stat changed from OFF to ON
2019-10-06 15:31:53.298 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw1 changed from ON to OFF
2019-10-06 15:31:53.348 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw1_stat changed from ON to OFF
2019-10-06 15:31:54.557 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw2 changed from ON to OFF
2019-10-06 15:31:54.645 [vent.ItemStateChangedEvent] - mqtt_sonoff_ABCDEFG_sw2_stat changed from ON to OFF
Until here everything looks ok.
Using this item code it looks ok. But without the status update
Using the 2nd channel to get status updates the item within sitemap isn’t showing the real world
Switch mqtt_sonoff_ABCDEFG_sw1 "ED Switch 1 []" <switch> { channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw1", channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw1_stat" }
Switch mqtt_sonoff_ABCDEFG_sw2 "ED Switch 2 []" <switch> { channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw2", channel="mqtt:topic:mymqtt:sonoff-ABCDEFG:sw2_stat" }
In the log you can see that “sw1” switch from OFF to ON->OFF->ON … This looks very strange.
2019-10-06 19:25:28.096 [ome.event.ItemCommandEvent] - Item 'mqtt_sonoff_33E958_sw1' received command ON
2019-10-06 19:25:28.105 [nt.ItemStatePredictedEvent] - mqtt_sonoff_33E958_sw1 predicted to become ON
2019-10-06 19:25:28.124 [vent.ItemStateChangedEvent] - mqtt_sonoff_33E958_sw1 changed from OFF to ON
2019-10-06 19:25:28.138 [vent.ItemStateChangedEvent] - mqtt_sonoff_33E958_sw1 changed from ON to OFF
2019-10-06 19:25:28.163 [vent.ItemStateChangedEvent] - mqtt_sonoff_33E958_sw1 changed from OFF to ON
2019-10-06 19:25:28.218 [vent.ItemStateChangedEvent] - mqtt_sonoff_33E958_sw1_stat changed from OFF to ON
I just want to have a MQTT topic which shows the right status of a switch.
Any suggestions?
