I configured a Shelly pro 2PM relay, in the local mqtt (openhab on raspberry and I had enabled mosquitto). Commands seems working, but I cannot get any status (current status, voltage, etc.), but I can see in the MQTT Explorer:
and my thing is configured so:
UID: mqtt:topic:MQTTBroker:5ca0cb1a1d
label: Relay piscina
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:MQTTBroker
channels:
- id: Relay0
channelTypeUID: mqtt:switch
label: Relay0
description: null
configuration:
commandTopic: shellypro2pm-ec62608da5f4/rpc
formatBeforePublish: '{"src":"MQTT","method":"Switch.Set", "params":{"id":0,"on":%s}}'
stateTopic: shellypro2pm-ec62608da5f4/status/switch:0
transformationPattern: JSONPATH:$.output
off: "false"
on: "true"
- id: Relay0_Volt
channelTypeUID: mqtt:number
label: Relay0_Volt
description: null
configuration:
unit: V
formatBeforePublish: "%.4f"
transformationPattern: JSONPATH:$.voltage
- id: Relay0_Watt
label: Relay0_Watt
description: null
configuration:
unit: W
transformationPattern: JSONPATH:$.apower
- id: Relay0_Ampere
label: Relay0_Ampere
description: null
configuration:
unit: A
transformationPattern: JSONPATH:$.current
The channel is working switching on and off, but I cannot get any status on the Json, but yes in the mqtt explorer, did you know why?
