I installed Ubuntu on an INTEL computer and did a full backup & restore to openhab that was installed on my Raspberry Pi,
All past and work but Mqtt Sonoff switch does not work for me
I changed the new IP in tasmota mqtt configuration
what am I missing?
The directory /var/log/openhab contains openhab related log files.
There should be two:
openhab.log
events.log
You can open them in a text editor or have a look to the content with command less or command more for example.
tail -f /var/log/openhab/openhab.log
always will show the last few lines on the content.
at org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService.brokerAdded(MqttServiceDiscoveryService.java:105) ~[?:?]
at org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService.lambda$0(MqttServiceDiscoveryService.java:75) ~[?:?]
at java.util.concurrent.ConcurrentHashMap.forEach(ConcurrentHashMap.java:1603) ~[?:?]
at java.util.Collections$UnmodifiableMap.forEach(Collections.java:1505) ~[?:?]
at org.openhab.binding.mqtt.internal.discovery.MqttServiceDiscoveryService.startScan(MqttServiceDiscoveryService.java:75) ~[?:?]
