PLATFORM: LINUX
NODE.JS: V12.22.7
NPM: 6.14.15
1th device: Rpi3: IP 192.168.0.100
- default rasbian image and installed IoBroaker → adapter connection2BeckhoffPLC
2th device: Rpi4: IP192.168.0.101 with setup with openhabian image
- openHAB 3.1.0
expl: DUT:= (data unit type)
#blockly
→ set State of Beckhoff adapter in Iobroaker and PLC Run
→ for trial once received Alivebit In from PLC send delayed back to Alivebit Out
#Settings MQTT Client
- How does I need to configure the MQTT on IoBroaker be able to read or write in Openhab?
I know it is wrong but don`t know what is right…
#Settings OpenHab System
#Settings OpenHab Thing
#IoBroaker_DUT
I have that : beckhoff.0.plc.IoBroker.IoB# [DUT] variable block that is puplished and as seen in log also transmittet to MQTT broker. in that [DUT] I have bool, word, string and so on that I would like to visualize in Openhab. in pic IoBroaker_DUT you can see a smal view of it to give an idea.
I try to setup the connection between IP *.100 and *.101 over MQTT as shown in print screen the connection is eatablished.
- How does I need to proceed to be able to visualize for examble the value of an boolean from that DUT?
I am beginning in openhab, so thank for a few more detailes info and keyword as usual.
thanks
