Hi
I have integrated a bticino roller relay with z2m
The three commands (up, down and stop) work well, but when I try an opening percentage nothing happens
example: the command that is sent is simply 90 instead of { “position” : 90} that would work
UID: mqtt:topic:3f31d0c4ed:2d8a798a3b
label: Tapparella Salotto
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:3f31d0c4ed
channels:
- id: Rollercontrol
channelTypeUID: mqtt:rollershutter
label: Roller control
description: ""
configuration:
postCommand: true
invert: true
transformationPatternOut:
- '{ "position" : %s}'
qos: 0
stop: '{"state": "STOP"}'
commandTopic: zigbee2mqtt/Tapparella_Salotto/set
transformExtentsToString: false
stateTopic: zigbee2mqtt/Tapparella_Salotto
transformationPattern:
- JSONPATH:$.position
off: '{"position": 0}'
on: '{"position": 100}'
this is my configuration, i need this functionality for google and alexa implementation,
i have also tried formatBeforePublish: ‘{ “position” : %s}’ but with the same result
