Hi all,
I have a new Sonoff Mini R2 flashed with Tasmota firmware 3.6.0.
I also have integrated it in openHab using MQTT binding and Mosquito.
I can turn on and off my switch from openHab, but if I change the status outside openHab (for example from tasmota web interface or using a phisical switch) I can’t get the item updated in openHab.
This is my things configuration.
Bridge mqtt:broker:myMqttBroker [ host="192.168.1.11", secure=false ]
Thing mqtt:topic:mythings "AllThings" (mqtt:broker:myMqttBroker) {
Channels:
Type switch : PowerSwitch "Mini" [ stateTopic="stat/sonoff-switch/POWER", commandTopic="cmnd/sonoff-switch/POWER"]
I have configured an external client to see the messages, this is the output:
stat/sonoff-switch/RESULT {"POWER":"ON"}
stat/sonoff-switch/POWER ON
stat/sonoff-switch/RESULT {"POWER":"OFF"}
stat/sonoff-switch/POWER OFF
Where is the problem?
