MQTT Sonoff stuck in on/off loop
Hi
I’m trying to get sonoff working with OH2, I have setup Tosmota and Mosquitto, I can use MQTTLens to turn the sonoff on and off with no issues.
I have now tried to setup OH2 which does send commands to the sonoff but it gets stuck when I press button it starts turning on and off rapidly as though stuck in a loop.
My MQTT.cfg has:
mqtt.url=tcp://192.168.178.42:1883
mqtt.clientId=openhab2
Items:
//Sonoff Basic / Sonoff S20 Smart Socket
Switch LivingLight “Living Room Light” (LR,gLight)
{ mqtt=“>[mqtt:cmnd/sonoff/power:command:*:default],<[mqtt:stat/sonoff/POWER:command:default]” }
and log of some debug information from OH http://txt.do/d96mw
Does anyone have an idea what I’ve done wrong?
You have created a loop with the command :slight_smile:
When requesting incoming status from mqtt, use the status (not the command):
Switch LivingLight "Living Room Light" (LR,gLight)
{ mqtt=">[mqtt:cmnd/sonoff/POWER:command:*:default],<[mqtt:stat/sonoff/POWER:state:default]" }
Thank you! Something so simple :slight_smile:
This helped me as well. Thanks @Dim !
