Hello OH Community,
i was using OH2.5 which was running fine quite long time. But then it got struggeling installing new bindinges etc. so i decided to move to OH3.10. Release build.
Basically the installation went fine but i dont get further with settings up the MQTT-Service.
What i did:
- Clean image via SD-Card
- Installed via openhab config the MQTT Service (mosquitto)
- Installed the MQTT binding
- Integrated a MQTT-Broker
- Restored the mqtt.cfg
- Restored sitemap/item/service-files from OH2.5
I wanted to use my old MQTT interfaces, like the garage or the pv inverter.
Here is one example item:
Number Grid_Power_L1 "Leistung Phase L1 (W) [%.0f]" {mqtt="<[mosquitto:Inverter_Information/Grid_Power_L1:state:default]"}
Frame label="Netzparameter L1"
Text item= Grid_Voltage_L1 label="Phasenspannung L1 [%.1f V]" icon="energy"
Text item= Grid_Current_L1 label="Phasenstrom L1 [%.2f A]" icon="flow"
Text item= Grid_Power_L1 label="Phasenleistung L1 [%.1f W]" icon="poweroutlet"
I guess the problem is somewhere between mosquitto in the RPi3 background and the OH Items because i can subscribe the topic from an external app by using my phone that uses the server on the RPi @ 192.168.178.30 where i can see that i have liek 155W right now.
Hope to get some infos
