Hi all,
i created this fancy WiFi enabled wall switch, using and ESP8266 with the arduino framework.
It is a broken alarm switch which i found on the garbage.
Video:
https://www.instagram.com/p/BD4vspysRm6/?taken-by=drohne.me
Pictures
(The size is not perfect…)
I replaced the original electronic with a new Pushbutton. But i am using the original LED.
What am i doing with this switch?
When i leave my house, i just want to switch off all of my electronics.
I have multiple ways to do it:
- Using the OpenHAB App/Web Browser,
- Using NFC Tags glued to the door (Link created with the openHAB App)
- Using geofence (Owntracks)
- via my new touchpanel based on Dashing.
But: My visitors don’t have the first three possibilities, therefore this idea was born.
The code:
OpenHAB Rule
(Double checking variables, otherwise the “fast” reset to zero leads to some errors)
It’s not the final code, i did the test with a Hue lamp,
now it’s another Item used for presence detection
rule "MQTT Button"
Item mqttButton changed
if (mqttButton.state==1 && Hue_Switch_4.state==ON){
Hue_Switch_4.sendCommand(OFF)
mqttButton.sendCommand(0)}
if (mqttButton.state==1 && Hue_Switch_4.state==OFF){
Hue_Switch_4.sendCommand(ON)
Arduino Sketch
Adafruit MQTT Button Script by Dominic Spatz
Must use ESP8266 Arduino from:
https://github.com/esp8266/Arduino
Works great with Adafruit's Huzzah ESP board:
----> https://www.adafruit.com/product/2471
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Tony DiCola for Adafruit Industries.
Adafruit IO example additions by Todd Treece.
MIT license, all text above must be included in any redistribution
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// function prototypes
void connect(void);
/****************************** Pins ******************************************/
#define BUTTON 0
/************************* WiFi Access Point *********************************/
#define WLAN_SSID "WLAN"
#define WLAN_PASS "Your_super_secret_P4SSW0RD"
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER "172.20.0.1"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME "mosquitto"
#define AIO_USER_TOPIC "MQTT_Button"
#define AIO_KEY "Openhab"
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// Store the MQTT server, client ID, username, and password in flash memory.
// This is required for using the Adafruit MQTT library.
const char MQTT_SERVER[] PROGMEM = AIO_SERVER;
// Set a unique MQTT client ID using the AIO key + the date and time the sketch
// was compiled (so this should be unique across multiple devices for a user,
// alternatively you can manually set this to a GUID or other random value).
const char MQTT_CLIENTID[] PROGMEM = AIO_USER_TOPIC;
const char MQTT_USERNAME[] PROGMEM = AIO_USERNAME;
const char MQTT_PASSWORD[] PROGMEM = AIO_KEY;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, MQTT_SERVER, AIO_SERVERPORT, MQTT_CLIENTID, MQTT_USERNAME, MQTT_PASSWORD);/****************************** Feeds ***************************************/
// Setup a feed called 'button' for publishing changes.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
const char BUTTON_FEED[] PROGMEM = AIO_USER_TOPIC "/feeds/button";
Adafruit_MQTT_Publish button = Adafruit_MQTT_Publish(&mqtt, BUTTON_FEED);
/*************************** Sketch Code ************************************/
// button state
int current = 0;
int last = -1;
unsigned long buttonPushedMillis; // when button was released
unsigned long ledTurnedOnAt; // when led was turned on
unsigned long turnOnDelay = 500; // wait to turn on LED
unsigned long turnOffDelay = 10000; // turn off LED after this time
bool ledReady = false; // flag for when button is let go
bool ledState = false; // for LED is on or not.
void setup() {
// set button pin as an input
pinMode(BUTTON, INPUT_PULLUP);
pinMode(5, OUTPUT); // declare LED as output
pinMode(LED_BUILTIN, OUTPUT); // declare LED as output
Serial.begin(115200);
delay(10);
Serial.print(F("Connecting to "));
Serial.println(WLAN_SSID);
for (int i = 0; i < 17; i++){
if (i % 2) {
digitalWrite(5, HIGH);
digitalWrite(LED_BUILTIN, LOW);
} else {
digitalWrite(5, LOW);
digitalWrite(LED_BUILTIN, HIGH);
delay(200);
WiFi.begin(WLAN_SSID, WLAN_PASS);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(F("."));
Serial.println();
Serial.println(F("WiFi connected"));
Serial.println(F("IP address: "));
Serial.println(WiFi.localIP());
// connect to MQTT
connect();
void loop() {
// ping adafruit io a few times to make sure we remain connected
if(! mqtt.ping(3)) {
// reconnect to adafruit io
if(! mqtt.connected())
connect();
// get the time at the start of this loop()
unsigned long currentMillis = millis();
// make sure this code isn't checked until after button has been let go
if (ledReady) {
//this is typical millis code here:
if ((unsigned long)(currentMillis - buttonPushedMillis) >= turnOnDelay) {
// okay, enough time has passed since the button was let go.
// setup our next "state"
ledState = true;
// save when the LED turned on
ledTurnedOnAt = currentMillis;
// wait for next button press
ledReady = false;
// see if we are watching for the time to turn off LED
if (ledState) {
// okay, led on, check for now long
if ((unsigned long)(currentMillis - ledTurnedOnAt) >= turnOffDelay) {
ledState = false;
// grab the current state of the button
current = digitalRead(BUTTON);
// return if the value hasn't changed
if(current == last)
return;
int32_t value = (current == LOW ? 1 : 0);
// check the button
if(value==0){
// update the time when button was pushed
buttonPushedMillis = currentMillis;
ledReady = true;
if (! button.publish(value))
Serial.println(F("Failed."));
else
Serial.print(value);
Serial.println(F(" Success!"));
// save the button state
last = current;
void connect() {
Serial.println(F("Connecting to MQTT... "));
int8_t ret;
while ((ret = mqtt.connect()) != 0) {
switch (ret) {
case 1: Serial.println(F("Wrong protocol")); break;
case 2: Serial.println(F("ID rejected")); break;
case 3: Serial.println(F("Server unavail")); break;
case 4: Serial.println(F("Bad user/pass")); break;
case 5: Serial.println(F("Not authed")); break;
case 6: Serial.println(F("Failed to subscribe")); break;
default: Serial.println(F("Connection failed")); break;
if(ret >= 0)
mqtt.disconnect();
Serial.println(F("Retrying connection..."));
delay(5000);
Serial.println(F("MQTT Connected!"));
Serial.println();
