Hello community,
I’m trying to switch from MQTT1 to MQTT2.4. Until now all MQTT stuff is part of the item definition.
Now I would like to switch to Homie Convention and detect the devices and generate things. I’ve constructed an example device topic/value set and have published it using mosquitto_pub.
This is the set copied from mosquitto_sub output:
homie/test2222/$name TEST2222
homie/test2222/$homie 3.0
homie/test2222/$state ready
homie/test2222/$nodes but-left-up,but-left-dn,but-right-up,but-right-dn,system,connection
homie/test2222/but-left-up/$name Taste links oben
homie/test2222/but-left-up/$type Button
homie/test2222/but-left-up/$properties event
homie/test2222/but-left-up/event/$name Button Event
homie/test2222/but-left-up/event/$datatype string
homie/test2222/but-left-dn/$name Taste links unten
homie/test2222/but-left-dn/$type Button
homie/test2222/but-left-dn/$properties event
homie/test2222/but-left-dn/event/$name Button Event
homie/test2222/but-left-dn/event/$datatype string
homie/test2222/but-right-up/$name Taste rechts oben
homie/test2222/but-right-up/$type Button
homie/test2222/but-right-up/$properties event
homie/test2222/but-right-up/event/$name Button Event
homie/test2222/but-right-up/event/$datatype string
homie/test2222/but-right-dn/$name Taste rechts unten
homie/test2222/but-right-dn/$type Button
homie/test2222/but-right-dn/$properties event
homie/test2222/but-right-dn/event/$name Button Event
homie/test2222/but-right-dn/event/$datatype string
homie/test2222/system/$name System
homie/test2222/system/$type Housekeeping
homie/test2222/system/$properties File,Build,MAC
homie/test2222/system/File/$name Filename Source
homie/test2222/system/File/$datatype string
homie/test2222/system/Build/$name Date and Time of Build
homie/test2222/system/Build/$datatype string
homie/test2222/system/MAC/$name MAC-address of WiFi interface
homie/test2222/system/MAC/$datatype string
homie/test2222/connection/$name Connection Properties
homie/test2222/connection/$type Housekeeping
homie/test2222/connection/$properties IP,AP-MAC,RSSI,Uptime
homie/test2222/connection/IP/$name IP address
homie/test2222/connection/IP/$datatype string
homie/test2222/connection/AP-MAC/$name MAC of Accesspoint
homie/test2222/connection/AP-MAC/$datatype string
homie/test2222/connection/RSSI/$name Signal strength
homie/test2222/connection/RSSI/$datatype integer
homie/test2222/connection/RSSI/$unit dBm
homie/test2222/connection/Uptime/$name Uptime
homie/test2222/connection/Uptime/$datatype integer
homie/test2222/connection/Uptime/$unit min
No $stats, no arrays are in use. $type - I’m not sure, what is it for and what are valid values for this attribute.
What’s wrong? And more important: How to debug what’s wrong?
Thanks for help!
Jens
